Possible airflow issue, trying to verify AI advice
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jon Batchelor, Aug 16, 2026 at 8:45 AM.
  1. Jon Batchelor
    Jon Batchelor Junior Member
    33
    FL
    2015 Prius, 350k miles. A few months ago, the hose for the engine air filter was improperly connected for about a month after a repair job. Car had been running great for a while, then one morning started running really rough, and threw off a check engine light, P0303, misfires on cylinder 3.
    Took it to the dealership and got an oil change. Car was then running a lot more smoothly, and a kind of grinding or chittering sound I'd asked about a few weeks ago went away. (Think I'm going to switch to a 7,500 mile oil change schedule.) But they refused to give me any info on the engine code without paying a $99 diagnostic fee.
    So I ran the car to Auto Zone and got the error checked, as I said above, two P0303 errors. Started checking with google AI to try and figure out likely problems. Explained how after oil change, things were much smoother. Was told that the oil change *might* have solved the problem, and if so, the check engine light would turn itself off after a couple of days. (It did.)
    But it also said there was a good chance the airflow sensor might need cleaning, especially after that loose hose for a month, a little while back. It also said very common with the age of the car to develop heavy carbon build-up on the intake manifold or something like that. Said there was a three step process involved in cleaning, and that quite possibly, the first, easiest step might be enough to clear the problem. (Supposedly something about Prius engine design means it's most often the 3rd cylinder.)
    Anyway, I was told the airflow sensor was easy enough to clean, and the four videos I have watched back that up. The air intake thingy is a more involved process, and is going to have to wait a month or so until my handyman heals from a hernia surgery, but I'm told that shouldn't be a problem, and that just the sensor cleaning might fix the problem.
    For the sensor, I got the proper CNC or whatever it was airflow cleaner, and that ought to be a simple project for today.
    Oh, yesterday, rough idle at startup, check engine light came back on, which is why I bought the cleaner for today.
    Does all this sound fairly reasonable, and not completely insane?
  2. Mendel Leisk
    42,372
    Recent acquisition? If so: how long have you had it? Any access to it's previous service/maintenance history?
    350k miles is a LOT for a gen 3. P0303 indicates misfire on cylinder 3. Misfire codes on gen 3 are very often due head gasket failure.
    #2 Mendel Leisk, Aug 16, 2026 at 11:45 AM
  3. CR94
    CR94 Senior Member
    2,837
    1,244
    Northwestern S.C.
    Has coolant level dropped?
  4. PriusCamper
    PriusCamper Senior Member
    13,475
    5,440
    Pacific Northwest, USA
    Unclear on how or when or if this was fixed? But disconnecting the 12v for a few minutes after it was fixed will reset the engine tuning back to factory specs and doing the same when you clean mass airflow sensor and throttle body gets the engine back to normal right away rather than driving it for a long time to get back to normal settings.
    Also throttle body is easy. Just remove air intake and open the butterfly valve and spray car cleaner down in there. Then stuff a rag all the way in with extra long needle-nose pliers and spray more carb cleaner, then use the pliers to move the rag around lots and pull it out and you're done.
  5. Mendel Leisk
    42,372
    You “can” lift it off (requires additional removal of two nuts and two bolts), with its coolant hoses still attached, allows easier and more thorough clean, and affords better view of intake manifold innards. When reinstalling 1/4” drive torque wrench is appropriate, torque for nuts/bolts is 44 inch/pounds (3.7 foot/pounds).
  6. Jon Batchelor
    33
    FL
    I've had it since 40k miles, and for roughly 10 years. Tomorrow before I start driving, I'll check the coolant level.
    The air filter hose was not properly rehooked up after replacing a water pump in March. (It was in position, but not tightened down.) Noticed it in May and tightened it down at that point.
    With my next fill-up I'll add a bottle of Techron Plus (arriving tomorrow). After that, planning to start a 3k mile schedule with a half a bottle of Gumout Re-something during fill-ups to reduce future continued carbon build-ups. IF it is only carbon build-up and not failing gasket seal, am I probably safe waiting a month for my handyman's hernia to finish healing up before actually cleaning out the intake 'pipes' build-up?
    If I'm showing coolant levels dipping, obviously it is much more serious and needs immediate intervention. Will report back after I get out to the car tomorrow morning.
  7. Jon Batchelor
    33
    FL
    OK, my car, and probably myself, are pretty much doomed. While the driver reserve is full, the passenger reserve is low, and I'm told that's the one that counts in this case. While I can try to say maybe Toyota didn't top it up while doing the oil change last week, I know they almost certainly did. So it looks like the gasket is going, and I'm going to have no way to get that taken care of. Damn!
    [edit]OK, just talked to the dealership, and they assure me they would have filled it to the proper level, but that the proper level would NOT be to the full line. So can somebody look at the picture and tell me if it is at the proper level, or low?[/edit]
    #7 Jon Batchelor, Aug 17, 2026 at 3:02 PM
  8. CR94
    CR94 Senior Member
    2,837
    1,244
    Northwestern S.C.
    Hard to tell, because the full mark is near the seam, and we don't know exactly how full they filled it. Keep monitoring the level closely.
  9. Jon Batchelor
    33
    FL
    OK, AI says if there is a leak, currently it is a tiny one, because the car starts rough, then behaves for most of the day. As long as I don't run out of coolant, I should be fine for a shift of driving passengers, keeping an eye out of an overheating warning, just in case. Tomorrow I will check the coolant level again, and see where it is. I don't want to damage the car, but it seems I may have been overreacting, and it should still be driveable for the moment, while I look for evidence of whether it is leaking or not. If I'm wrong, for God's sake tell me quickly, before I head out to drive in about an hour.
    [edit]Oh, and if Toyota says they wouldn't fill it to the full line, and when I had the water pump replaced in March, they filled it to the full line, is it possible they filled it too full, and that caused problems in the system somewhere? To me, that's the point of a full line...if you don't fill it to the full line, then having a full line seems very confusing.
    And if it seems low, and I should fill it before monitoring the level, I could do so, as I still have a half-bottle of the coolant from when they changed the water pump.[/edit]
    #9 Jon Batchelor, Aug 17, 2026 at 4:16 PM
  10. Jon Batchelor
    33
    FL
    Second pic two days later. Doesn't seem like I'm losing any coolant! Yay!
    Which means less pressure from a friend asking me to use something called Blue Devil!
      File size:
      135.3 KB
  11. Mendel Leisk
    42,372
    That’s pretty low:
    Don’t listen to that friend.
  12. Jon Batchelor
    33
    FL
    Well, I don't know how far to fill it, because the dealership said they wouldn't fill it to the full line. But to me the most important part is that it doesn't seem any lower than the first picture two days ago, so it doesn't seem to be currently leaking. I have some of the Toyota coolant, how far up should I fill it?
  13. Jon Batchelor
    33
    FL
  14. Jon Batchelor
    33
    FL
  15. Mendel Leisk
    42,372
    I’d fill to FULL line, with cold engine, continue to monitor. Coolant loss starts slow.
    Dealership statement that they wouldn’t fill to that line sounds like service writer bluff.
  16. rjparker
    11,135
    6,984
    There is no need to ever top off coolant if you don't have a leak. These cars can go two years between coolant changes with no observable reservoir drop. I have seen ten year old cars with no coolant changes, no drop in level, no overheating ever but with early stage hg failure. Old coolant can cause hg erosion. Neglecting coolant changes on gen3 Prius is an often overlooked hg root cause.
    Yours is low. It should be at the seam. It may be going down by 10 drops a day and not every day.
    Classic hg leak symptoms. No AI crutch needed. By the way, AI just looks for repeated advice from places like this. If it says egrs cause hg leaks its because that is a mantra by some around here.
    If you needed a water pump the car may have overheated.
    Neglecting a leak can and will cause more damage and perhaps stranding.
    #16 rjparker, Aug 20, 2026 at 7:30 AM
  17. Mendel Leisk
    42,372
    Not me, nope, no connection.
