2008 Prius engine won't start, red triangle after radiator replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by b0814, Aug 21, 2026 at 9:22 AM.
  1. b0814
    b0814 New Member
    Charlotte, NC
    I'm trying to fix a Prius that was in an accident. The accident damaged the radiator and inverter coolant circuits and the AC condenser causing loss of both fluids.
    The radiator, fan assembly, inverter mounting brackets, air intake cleaner box, throttle actuator wiring harness, and the inverter coolant reservoir have been replaced. I've filled and bled the inverter loop with OEM coolant.
    The 12v battery was entirely discharged since it has been sitting for weeks so I had to jump it. I tried to start the engine so that I could bleed the engine loop, it sounded like the engine was failing to catch and I heard a knocking/clacking sound accompanied by the red triangle. It did go into ready mode but the engine wouldn't start. I have tech stream on my laptop but haven't had a chance to hook it up yet. Any ideas what it could be? What should I check first?
  2. BiomedO1
    4,639
    2,434
    Left Coast
    You've got a weak traction battery and you need to get the 12V battery back into a decent condition. Check for blow fuses and clear all ECU error codes; AFTER you noted all of them. An accident that severe is likely to short out a few things.
    Good luck.
  3. Tombukt2
    13,878
    2,521
    Charge the 12 volt first don't just jump the vehicle with the crappy 12 volt charge it up if thY AGM so register 12.4 up not going to be using it .
