Advice on Best Way to Cool Florida Garage - Prius 4-2016
Discussion in 'Gen 4 Prius Main Forum' started by Betrock, May 22, 2026.
  1. Betrock
    Betrock Junior Member
    22
    Tampabay Area
    The garage door faces west, and is painted white. The small window is in an north facing. Door and is quite small.I would say one and a half by two. I haven't had a chance to take a look at window.Fans and see if they make them that small.But that was really a good idea. Thanks so much for your thoughts and time.
    Anne
  2. John321
    John321 Senior Member
    1,548
    1,452
    Kentucky
    We also live in the south.
    We have a plug in hybrid that we not only keep in the garage but also charge it there. We have no special ventilation, and the car has done just fine. The car is now almost 7 years old and has 78,000 miles on it, battery is just fine.
    The car we traded in on the plug in hybrid was a 2008 Prius - it was kept in the same garage- the Prius was 12 years old with 120,000 miles on it - still got over 50 mpg when we traded it in.
    A cool garage is of course preferred - but I don't believe a hot garage is going to cause you big problems - many hybrids are parked outside with windows rolled up and the hot sun beating down on them during the day.
  3. Betrock
    22
    Tampabay Area
    THANK YOU!
    Frankly, i'm tired of worrying about it.And I think I like your idea best.I'm just not gonna worry about it.I keep a thermometer out there in the temperature.Doesn't go above ninety five, which is the maximum that prius says is okay. Thanks again for your encouraging examples!
  4. Mendel Leisk
    42,384
    Not to be argumentative, what’s the source of that, temp that hybrid battery fan starts up, or?
    for a personal data point: when I was using a ScanGauge II (discontinued, it’s constant weight on OBD port was apparently triggering alarms), I distinctly remember an evening drive, ambient temp 35C (coincidentally 95F), and fan speed “2”. There’s maybe five speeds, with “1” being slowest.
    FWIW, when the car’s on at least, at 95F active fan cooling was deemed necessary.
    my garage ventilation project was mostly motivated by a freezer install, but I did have concerns for some years regarding our Prius with hybrid battery. Perfect storm is summer afternoons, parking hot car after a drive, and shutting all the doors, it would get like slow-death in there. :(
    As a renter, I’d consider incremental, easily reversible measures at the least, in hot weather. Say: leave garage doors open a few minutes, pop and raise the hood (accelerates engine cool-down “some”), window fan if practical.
    Betrock likes this.
  5. ETC(SS)
    7,585
    You're overthinking the battery......but to break with tradition and actually answer the question:
    Attic fan.
    A small one will fit into the window unless you live somewhere that encourages security bars instead.
    The Home owner or realter may split the cost with you for having one installed - or you can do what my favorite USN Admiral would to to....um.....'debug the issue' and ask for forgiveness later.
    Also, if you have a freezer or fridge running in the garage consider relocating it.
    Best of luck!
  6. Betrock
    22
    Tampabay Area
    I'll check out the smaller attic fans - it seems they do make some small enough to fit in my window! Thanks!
  7. rjparker
    11,152
    6,989
    Mendel is being argumentative to justify his position that we now find was to mitigate an active heat source in a closed garage. Plus he lives in a mild Canadian environment.
    Best advice: don't worry about it. As someone who has several decades of hybrid experience and over 500,000 miles of hybrid driving, combined with years of 10 second data collection in a very hot Texas environment, I suggest you enjoy your nice hybrid and be thankful you have a garage which to park it in which will protect it.
  8. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    I hope my situation can help put your mind at ease.
    I used to park my 2020 Prius Prime 5 days a week in a spot with no shade and with windows up, but sunshades on all the windows. This is in inland southern CA. It gets quite hot in the summer. The internal temperature would get as high as 120 degree F. Then it would charge in covered parking for the remaining 2 hours and the internal temp would get down to the mid 90's. Then it would drive 35 miles to be parked in a hot garage overnight, so the battery probably never got the chance to cool down in the summer. My parking permit has changed and I now get covered parking, but even with the covered parking my battery still spends plenty of time around 100 degrees F during peak summer weather. It now has 115,000 miles on it and is still doing fine.
    I also have a 2013 prius C. The first 5 years were also parked in a spot without any shade and the cabin probably got at least to 120 degrees F. I didn't even have sunshades back then, except for maybe a windshield sunshade. It now has 175,000 miles on it and is still on the original battery. It is getting 60-70 mpg in light to moderate traffic with very conservative driving and 50-56 mpg with normal conservative driving in no traffic. It did get it's hybrid battery fan cleaned twice.
    #28 pasta4breakfast, Jun 14, 2026
    John321 likes this.
  9. PriusV17
    PriusV17 Active Member
    443
    208
    CA
    2017 Prius v wagon
    Finally got a thermal camera and yep, the hottest spots are the garage doors. The doors are over 100F. The thermal camera is a good way to find all the hot spots all over the house so you can insulate those areas if you can.
  10. PriusV17
    443
    208
    CA
    2017 Prius v wagon
    I was shocked to get my last electric bill. It was only $1.34 and it was during the hottest month of summer here in SoCal.
    I do have solar and the house is very well insulated. So I don't use AC as much and I sell back to the grid.
    I'm shocked because I hear from friends that don't have solar and use the AC a lot that their electric bill can be as high as $800. I also wonder whether EV is really worth it without home solar, especially during these hot summer days.
  11. PriusV17
    443
    208
    CA
    2017 Prius v wagon
    According to Google AI. Owning a modern Toyota hybrid is as cheap as owning an EV (only when charging at the cheapest off-peak rate at home). But when charging at fast DC charging stations, it still does not compare to owning a hybrid. It costs twice as much. Regular gas is still about twice as much than a good hybrid.
