I've designed a board that fits in the original Hybrid Vehicle Control ECU case and create a man in the middle setup for connecting for example the openinverter controller. I have boards available if someone want one.
Welcome to PriusChat!! Impressive first post. What are you currently using your installed board for? What are some of the other things that people could use this board for? How much does a finished (populated) board cost, and are there DIY kits available? FYI : you're moderated until you've posted 5 times.
Thanks SFO! Running with an openinverter controller Run custom inverter controller, trouble shooting, training. Board design is available open source so you can print some your selves on jlcpcb or similar search for PriusHVConnector in github for gerber and bom files. wiki has details on what other parts need to build one. Please note that there are a few issues on the current board design (see issues in in github) To follow my progress with the openinverter controller search for "Toyota Prius gen2 plug and play" in openinverter forum and "Toyota prius gen2 with openinverter in manual mode" on youtube.
I'm trying to run the OEM Hybrid Vehicle Control ECU together with the openinverter controller but the OEM ECU opens the contactors when I start the openinverter controller (Initial test worked when only MUU, MVU, MWU (GUU, GVU and GWU when disconnected from the OEM ECU). Currently I have: MG1 and MG2 disconnected from OEM ECU (MUU, MVU, MWU, GUU, GVU and GWU) and Engine Control Module disconnected Encoder from MG2 to connectedto openinverter (MRF,MRFG,FMCS,MCSG,MSN and MSNG). MCS,MCSG,MSN,MSNG from OEM Hybrid Vehicle Control ECU connected to GCS,GCSG,GSN,GSNG on the inverter (MRF,MRFG left disconnected) GVIA, GVIB, MVIA, MVIB, GWIA, GWIB, MWIA, MWIB from OEM ECU connected to GVIB and GWIB on the inverter (I don't see any "power transfer" on the screen any more also no voltage on GVIB and GWIB from controller). No codes other then P0A87 (MUU, MVU and MWU disconnected), P0A7A (GUU, GVU and GWU disconnected) and U0100 (Engine ECU disconnected). Anyone have any idea what might trigger the OEM Hybrid Vehicle Control ECU to open the contactors, what code to look out for on the CAN interface to trouble shoot or anything else I need to emulate to keep the OEM Hybrid Vehicle Control ECU happy?
Still haven't figured out issue above but it seems MFIV is tripping (reported by the openinverter controller). I now have access to Techstream to trouble shoot issue. Started work on setting up SOC spoofing etc following eaa-phev pages to keep the OEM ECU's happy (Search for Prius gen 2 SOC spoofing on youtube). I plan to use stm32-car or stm32-template for software and hardware. Anyone mind sharing how the forced EV mode/out of gas/forced stealth works? do you just shut off the fuel pump or is there some can messages involved?
I've wheels spinning with non Toyota HV controller for more information see: https://openinverter.org/forum/viewtopic.php?t=2516 Is Attila's priusCodes.xls kept updated any where? I've some additions like VL is displayed in pid 3A 6th byte
Wrote a small Prius Battery ECU decoder using an ESP32 and a couple of 3.3V Can Boards before I get ahead of my self over sharing the Toyota hybrid batteries: // === ESP32 Prius CAN Parser === // Monitors Prius Gen2 Battery ECU on 2 CAN buses #include <ACAN_ESP32.h> #include <mcp_can.h> #include <SPI.h> #include <WiFi.h> #include <ESPAsyncWebServer.h> AsyncWebServer server(80); // === Battery 1 (ESP32 CAN) === float packVoltage1 = 0.0; float packCurrent1 = 0.0; int soc1 = 0; int ccl1 = 0, cdl1 = 0; int temp1a = 0, temp1b = 0; uint16_t faultCode1 = 0; uint8_t deltaSOC1 = 0, flags1 = 0; uint16_t calibX1 = 0, calibY1 = 0, calibZ1 = 0; float blockVoltages1[14] = {0}; uint8_t isoTPBuf1[64]; size_t isoTPLen1 = 0; // === Battery 2 (MCP2515 CAN) === float packVoltage2 = 0.0; float packCurrent2 = 0.0; int soc2 = 0; int ccl2 = 0, cdl2 = 0; int temp2a = 0, temp2b = 0; uint16_t faultCode2 = 0; uint8_t deltaSOC2 = 0, flags2 = 0; uint16_t calibX2 = 0, calibY2 = 0, calibZ2 = 0; float blockVoltages2[14] = {0}; uint8_t isoTPBuf2[64]; size_t isoTPLen2 = 0; MCP_CAN can2(15); unsigned long lastTesterPing = 0; const unsigned long testerPingInterval = 3000; // 3 sec int pid = 1; void setup() { Serial.begin(115200); WiFi.softAP("PriusMonitor", "hybridpower"); Serial.println(WiFi.softAPIP()); server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) { String html = "<html><head><meta http-equiv='refresh' content='2'></head><body><h1>Prius BMS Data</h1>"; html += "<h2>Battery 1</h2>"; html += "<p>Voltage: " + String(packVoltage1) + " V</p>"; html += "<p>Current: " + String(packCurrent1) + " A</p>"; html += "<p>SOC: " + String(soc1/2.0) + " %</p>"; html += "<p>Delta SOC: " + String(deltaSOC1/2.0) + " %</p>"; html += "<p>CCL/CDL: " + String(ccl1) + "/" + String(cdl1) + " A</p>"; html += "<p>Temps: " + String(temp1a) + ", " + String(temp1b) + "</p>"; html += "<p>Flags: 0x" + String(flags1, HEX) + "</p>"; html += "<p>Blocks:</p><ul>"; for (int i=0; i<14; i++) html += "<li>Block "+String(i+1)+": "+String(blockVoltages1)+" V</li>"; html += "</ul>"; html += "<h2>Battery 2</h2>"; html += "<p>Voltage: " + String(packVoltage2) + " V</p>"; html += "<p>Current: " + String(packCurrent2) + " A</p>"; html += "<p>SOC: " + String(soc2/2.0) + " %</p>"; html += "<p>Delta SOC: " + String(deltaSOC2/2.0) + " %</p>"; html += "<p>CCL/CDL: " + String(ccl2) + "/" + String(cdl2) + " A</p>"; html += "<p>Temps: " + String(temp2a) + ", " + String(temp2b) + "</p>"; html += "<p>Flags: 0x" + String(flags2, HEX) + "</p>"; html += "<p>Blocks:</p><ul>"; for (int i=0; i<14; i++) html += "<li>Block "+String(i+1)+": "+String(blockVoltages2)+" V</li>"; html += "</ul>"; html += "</body></html>"; request->send(200, "text/html", html); }); server.begin(); ACAN_ESP32_Settings settings1(500000); settings1.mRxPin = GPIO_NUM_16; settings1.mTxPin = GPIO_NUM_17; if (ACAN_ESP32::can.begin(settings1) == 0) { Serial.println("Internal CAN OK"); } else { Serial.println("Internal CAN FAILED"); } SPI.begin(); while (CAN_OK != can2.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ)) { Serial.println("MCP2515 init failed. Retrying..."); delay(1000); } can2.setMode(MCP_NORMAL); Serial.println("MCP2515 CAN OK"); } void loop() { CANMessage frame; if (ACAN_ESP32::can.receive(frame)) parseCAN(frame, 1); long unsigned int rxId; uint8_t len = 0, buf[8]; if (can2.readMsgBuf(&rxId, &len, buf) == CAN_OK) { CANMessage m; m.id = rxId; m.len = len; memcpy(m.data, buf, len); parseCAN(m, 2); } if (millis() - lastTesterPing >= testerPingInterval) { lastTesterPing = millis(); uint8_t req1[] = {0x02, 0x21, 0xCE,0,0,0,0,0}; uint8_t req2[] = {0x02, 0x21, 0xCE,0,0,0,0,0}; uint8_t req3[] = {0x02, 0x21, 0xCE,0,0,0,0,0}; uint8_t req4[] = {0x02, 0x21, 0xCE,0,0,0,0,0}; CANMessage tx; tx.id = 0x7E3; tx.len = 8; if (pid==1) memcpy(tx.data, req1, 8); if (pid==2) memcpy(tx.data, req2, 8); if (pid==3) memcpy(tx.data, req3, 8); if (pid==4) memcpy(tx.data, req4, 8); ACAN_ESP32::can.tryToSend(tx); can2.sendMsgBuf(0x7E3, 0, 8, tx.data); pid++; if (pid>4) pid=1; } } void parsePIDMap(uint8_t* data, size_t len) { if (len < 4) return; uint8_t base = data[2]; Serial.printf("[PIDMAP] Base 0x%02X\n", base); for (int i=0; i<4; i++) { uint8_t b = data[3+i]; for (int bit=7; bit>=0; bit--) { if (b & (1<<bit)) { uint8_t pid = base + (i*8 + (7-bit)) + 1; Serial.printf(" -> PID: 0x%02X\n", pid); } } } } void decodeBlocks(uint8_t* data, size_t len, int bus) { float* blocks = (bus == 1) ? blockVoltages1 : blockVoltages2; // We expect at least 2 bytes of header + 14 * 2 = 30 bytes of data if (len < 2 + 14 * 2) { Serial.printf("[BUS%d] decodeBlocks() called with insufficient data!\n", bus); return; } Serial.printf("[BUS%d] data:", bus); for (size_t i = 0; i < len; i++) { Serial.printf(" %02X", data); } Serial.println(); for (int i = 0; i < 14; i++) { uint8_t D = data[2 + i * 2]; uint8_t E = data[2 + i * 2 + 1]; blocks = (2.56f * D) + (0.01f * E) - 327.68f; } Serial.printf("[BUS%d] Blocks:", bus); float sum = 0.0; for (int i = 0; i < 14; i++) { Serial.printf(" %.2f", blocks); sum += blocks; } Serial.printf("\n[BUS%d] Sum of blocks: %.2f V\n", bus, sum); } void parseCAN(const CANMessage &frame, int bus) { float &packVoltage = (bus==1) ? packVoltage1 : packVoltage2; float &packCurrent = (bus==1) ? packCurrent1 : packCurrent2; int &soc = (bus==1) ? soc1 : soc2; int &ccl = (bus==1) ? ccl1 : ccl2; int &cdl = (bus==1) ? cdl1 : cdl2; int &tempA = (bus==1) ? temp1a : temp2a; int &tempB = (bus==1) ? temp1b : temp2b; uint16_t &faultCode = (bus==1) ? faultCode1 : faultCode2; uint8_t &deltaSOC = (bus==1) ? deltaSOC1 : deltaSOC2; uint16_t &calibX = (bus==1) ? calibX1 : calibX2; uint16_t &calibY = (bus==1) ? calibY1 : calibY2; uint16_t &calibZ = (bus==1) ? calibZ1 : calibZ2; uint8_t &flags = (bus==1) ? flags1 : flags2; switch (frame.id) { case 0x03B: { int16_t raw = ((frame.data[0]&0x0F)<<8)|frame.data[1]; if (raw & 0x800) raw -= 0x1000; packCurrent = raw*0.1; packVoltage = (frame.data[2]<<8)|frame.data[3]; break; } case 0x3CB: { cdl=frame.data[0]; ccl=frame.data[1]; deltaSOC=frame.data[2]; soc=frame.data[3]; tempA=(int8_t)frame.data[4]; tempB=(int8_t)frame.data[5]; break; } case 0x3CD: { faultCode=(frame.data[0]<<8)|frame.data[1]; packVoltage=(frame.data[2]<<8)|frame.data[3]; break; } case 0x3C9: { calibY=(frame.data[0]<<4)|(frame.data[1]>>4); calibZ=((frame.data[1]&0x0F)<<8)|frame.data[2]; calibX=(frame.data[3]<<4)|(frame.data[4]>>4); break; } case 0x4D1: { flags = frame.data[7]; break; } } if (frame.id==0x7EB) { uint8_t* buf = (bus==1) ? isoTPBuf1 : isoTPBuf2; size_t &isoLen = (bus==1) ? isoTPLen1 : isoTPLen2; uint8_t pci = frame.data[0]; if ((pci & 0xF0)==0x00) { isoLen = pci&0x0F; memcpy(buf, frame.data+1, isoLen); if (buf[1]==0x61 && (buf[2]&0xF0)==0x40) parsePIDMap(buf, isoLen); else decodeBlocks(buf+3, isoLen-3, bus); } else if ((pci&0xF0)==0x10) { isoLen=frame.data[1]; size_t cpy=frame.len-2; memcpy(buf, frame.data+2, cpy); isoLen=cpy; // Send Flow Control CANMessage fc; fc.id = 0x7E3; fc.len = 8; fc.data[0] = 0x30; // Flow Control fc.data[1] = 0x00; // No block size fc.data[2] = 0x05; // 5 ms for (int i = 3; i < 8; i++) fc.data = 0; if (bus == 1) ACAN_ESP32::can.tryToSend(fc); else can2.sendMsgBuf(fc.id, 0, fc.len, fc.data); } else if ((pci&0xF0)==0x20) { size_t cpy=frame.len-1; memcpy(buf+isoLen, frame.data+1, cpy); isoLen+=cpy; if (isoLen>=14) decodeBlocks(buf+3, isoLen-3, bus); } } }
Hey there! I've been preparing to build a high-current testing jig reusing the Battery ECU. Questions in order of importance: - Do you have a Git repo for this / what is your licensing for this snippet? - If not, can I create one for you with implementation notes? - Can you confirm - seems you're using Arduino IDE with the ESP platform? (https://espressif.github.io/arduino-esp32/package_esp32_index.json for packages, from here) - Looks like this uses an MCP2515 instead of the integrated CAN support on the ESP32 with an external transceiver. I use primarily ESP8266 (D1 Mini clones), but don't regularly shop for ESP32 boards -- do you have an ESP32 board that you prefer, that ships with the MCP2515 and CAN PHY/transceiver IC? - I'm in particular focused on slapping parts together, and don't want to fry my parts with the 12V (?) differential Prius CAN emitted by the BSU.
Clip of decoder in action https://youtube.com/shorts/N6uje5jFpM0?si=1vFEIk5cjs5QN6Eq I'll make a Github page soon with all details.
GitHub - hakanrolsson/PriusGen2BatteryMonitor: This project monitors Toyota Prius Gen2 Battery ECU's using dual CAN buses
Is this using the Zombie Inverter board that Damien Maguire developed, or another design? I see Johannes also built a board and used it in an Audi conversion, but he is only driving MG2 and not using MG1 ...... T1 Terry
I'm currently using two toyota prius gen2 openinverter.org boards (Johannes boards). One for Inverter control and one as car ecu. I've made some updates to the car ecu software to support the Toyota gear shifter etc (see my Github ). I'm currently working on plug in charging. Hoping to use the A/C inverter as a rectifier.
define "plug in charging" as with a grid charger, I've been "Plug-in charging" my Gen 2 HV battery just so i can drive it from parking spot to parking spot while the gas engine has three holes in the bottom of it...
I assume you're skipping the VCU "boost" stage and connecting QTY336 NiMH cells directly to the motor bus? How was the experience acquiring (cost, time) and installing the boards -- are the Gen2 inverter boards are still available for sale?
The Zombie inverter boards are the better supported choice now, VCU Boards and can run both MG1 and MG2 from the single board. Damien Maguire has quite a few videos on building and tuning these boards, and the Open Inverter forum has a lot of very smart cookies that can help guide you through any problems. Damien has also reverse engineered the Buck/Boost section to make a battery charger, so the two units, liquid cooled, in one container T1 Terry
So many updates... Bought a new daily driver (id4) so my old daily driver is now my main project car (2007 prius) Took the ice out and installed 12kwh bmw hybrid battery. Big thanks to @ghia66 and everyone in the dublin openinverter group for helping getting it ready ish for maker dublin.
Zombie only support gen3. For gen2 you still need a toyota prius gen2 openinverter.org board (Johannes boards).
