Does it really matter whether synthetic blend/full synthetic or conventional oil on oil change?
Discussion in 'Generation 1 Prius Discussion' started by peripatetic pri, May 14, 2026.
  1. peripatetic pri
    peripatetic pri Junior Member
    55
    pac nw
    2001 Prius
    HI! Where I am there's a $46 diff in price betw convention oil and full synthetic. Just want to know what others think - worth it to spring for extra $46 or get a synthetic blend?
    Thanks!
  2. Trombone
    Trombone Active Member
    392
    149
    Allentown, Pennsylvania
    2002 Prius
    I'm using Castrol Edge 5W-30, the high-mileage version, and have done for years (I do my own oil/filter changes). IMO it's worth paying whatever the price difference is, and that little 4-cylinder mill seems to thrive on it. Don't know how much longer I can keep on getting down under there to do the work (and getting up is the real fun!), but as we say in PA Dutchland, "May things never change!"
    ronlewis and Merkey like this.
  3. Tombukt2
    13,883
    2,521
    Just change your 5:30 oil and you be good don't sweat it at all even on a 20 plus year old car . The car appreciates you changing it.
  4. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    I can’t even find non synthetic 5/30 oil anymore.
  5. BiomedO1
    4,641
    2,435
    Left Coast
    If your doing 5K mile oil changes, any certified 5w30 would be OK. If you doing 10K mile changes; I'd stick with full synthetic - since it's more stable and doesn't break-down as easy as the old dino-oil. I know some people that'll change their oil every 5K and the filter every 10K. To me, that's like taking a shower and putting your old dirty smelly clothes and underwear back on - what's the point??? An OEM filter on-line is less than $5.
    Just my 2-cents....
    MArcin91t, 6079smithw, Merkey and 2 others like this.
  6. Trombone
    392
    149
    2002 Prius
    That. Also, it just now occurred to me--when removing the old filter, put a plastic bag around it. No more messy hand(s) and drips.
  7. Leadfoot J. McCoalroller
    8,295
    7,814
    Pennsylvania
    2018 Prius c
    I use a 'red solo cup' mostly because it can be used for that task more than once.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,358
    988
    Monument, Colorado USA
    100% agree with this!! (But do 5,000 mile oil changes....too many YouTube videos of the gunked up inside of engines to prove 10,000 mile oil changes is a horrible idea...might seem okay for a few years, but ends in disaster.)
    BiomedO1 and Merkey like this.
  9. Tombukt2
    13,883
    2,521
    Man I got four engines out here laying in the yard there articulated on pallets in such a way where oil and nonsense isn't getting inside of them they all had hap hazard oil changes at best .. take the valve cover off any of them I don't see anything alarming for 180K if driving in SE USA. A few flakes of dried oil n whatever mixed compressed air blows it down to the silver brown color it starts to get the minute the engines pumping oil. Pull the head off you can still see this cross hatch marks from the original honing 180K ago . Pull main n rid caps see light copper just starting to show thru grey babbit material . This is all perfect for cleaning and re fitting std sizes thru out engine. At the point you're at you'll have it all assembled and most of it back together ready to go into the car by this afternoon . Only thing that won't come from Walmart for this whole operation is the lisle ring compressor . By the red plastic unit with the corrugated 1.3 inch metal band .
  10. BiomedO1
    4,641
    2,435
    Left Coast
    I do 10K mile changes because I'm 70%-80% EV and get more than 1K miles a tank. I also spend the extra dollar on the 20K mile full synthetic formulation, instead of the standard 10K mile full synthetic. Worse case is around 7.5K actual on ICE, that's usually done in the summer months, where I'm <800 miles/tank. I've hit the one year point on occasions; so it get changed because I've hit the time-line wall, not mileage.
    This is on a PHEV; so if you have longer commutes or just a regular hybrid - YMMV........;)
    #10 BiomedO1, May 16, 2026
    ColoradoBoo likes this.
  11. mroberds
    mroberds Member
    153
    59
    2001 Prius
    Maybe I'm dumb, but I've been doing it every 3,000 miles with plain old dinosaur juice, and I'm at 265,000 miles in my Gen1 so far.
    I used to run Castrol, because an old hippy mechanical engineer said it was good, for an engine that basically had its design freeze in 1940. I switched to Valvoline when BP dumped 210 million gallons of crude oil in the Gulf of Mexico (Deepwater Horizon). I probably need to switch from Valvoline now that it's owned by the
    bonesaw
    people, but I haven't decided to what, yet.
    If you run 100,000 miles in a Prius, getting a solid 50 mpg, you're going to use 2,000 gallons of gasoline. Each oil change in a Gen1 is 1 gallon. Given that, it kind of doesn't matter at all if you use 20 gallons of oil (every 5,000 miles) or 33 gallons of oil (every 3,000 miles) over that distance.
    Trivia 1: I've heard, but can't verify, that "synthetic blend" doesn't mean anything in the US - you can put 30 mL of synthetic oil in 55 gallons of dinosaur juice, and that's enough to call it "synthetic blend". This was due to legal maneuvering by, I've heard, Castrol. Pure synthetic still has to be pure synthetic, though.
    Trivia 2: Where I lived when I bought the Prius, the standard offer at the Toyota dealerships was that if you bought 3 filters, you would get the 4th for free. If you ordered 4, the man at the parts counter would get 4 filters, and then get in his big bag of drain plug washers and slip one into every filter box. Where I live now, the only deal is buying a case of 10 filters, and you have to buy the drain plug washers yourself. Sic transit gloria mundi. (Tuesdis are worse!)
  12. Mendel Leisk
    42,386
    Searching our 3rd gen owners manual pdf, the only instance of “synthetic” is in reference to seat material.
