No, that wasn't a mouse in the heater
Discussion in 'Generation 1 Prius Discussion' started by ChapmanF, Aug 30, 2014.
  1. Frontporch
    Frontporch Active Member
    552
    128
    Nj
    dug in again today with my new ultra low profile screwdriver. made getting out the first one easy but the inlet select motor above is a puzzle.
    The harness clips facing away, the lower screw comes out but the upper screw may be buried. There is also a plastic linkage that needs to be depressed to undo it. For a moment I thought I could get at it from above the module that is to the left of all these motors, but I can't see or sense that any screwdriver can reach it.
    I believe this is a motor that a tech would take the dash apart for, but I am not giving up yet.
  2. Frontporch
    552
    128
    Nj
    Got it out. It was possible using a screwdriver above the large silver module thing image.jpg
    priumium likes this.
  3. Frontporch
    552
    128
    Nj
    Want o share how I attack these brittle clips. They usually snap if you pry with a screwdriver. I take an old plastic card like a hotel key and jam them in. One or two to give me just enough to unsnap without breaking image.jpg
  4. Frontporch
    552
    128
    Nj
    OK.. the air selector motor is cleaned up and back in. All things considered, it was probably a lot easier going at this part from under the dash than attacking dash disassembly.
    I was able to get the motor back in place using the same long but small phillips head screwdriver, but I put some duct tape on the screw and screwdriver so it would stay in place long enough to get me started. I fished the screwdriver with screw attached up under the dash and above the silver module box. Basically attacked it straight on like i took it off. Since I couldn't see the hole for the screw to go in, but knew where it should be, I just poked around until the screw fell in a little deeper and then started tightening. Would have been impossible without the tape.
    Noise is gone and the air selector is working as it should.
  5. ChapmanF
    19,087
  6. ChapmanF
    19,087
    Looking for yitznewton's posts about access on gen 2?
    This is embarrassing: I don't know how many people I've referred to this thread, saying "and be sure you scroll down and see how yitznewton got the actuator out on a gen 2" (the HVAC boxes are similar on gen 1 and gen 2, but gen 2 puts a big brake ECU next to it, complicating access to the actuators).
    And then I come and review this thread and realize yitznewton's posts weren't ever on it, they were over in this other thread:
    Removing the A/C blend door actuator | PriusChat
    with a youtube video showing the process.
    Sorry, everybody I sent here who wondered "what posts from yitznewton?". Go look at that thread. :oops:
  7. mroberds
    mroberds Member
    153
    59
    2001 Prius
    I will have to try this soon.
    For a couple of years now, if I was sitting in the Prius in a quiet situation - key on, HVAC blower off, radio off, etc - I could hear a quiet "motor running" sound from somewhere vaguely in front (FRONT) of the steering wheel. More recently, the "mode" dial of the HVAC control mostly quit working - no matter what I turned it to, I got air out of the dash vents and that's it. Occasionally it would work again for a few minutes, and then quit.
    Recently, I had that "motor running" sound again, and I kneeled outside the driver's door, and verified that the motor/actuator on the left side of the HVAC box, just inboard/right of the accelerator pedal, was wiggling back and forth on the the plastic cam/lever that it attaches to. I suspect this might be the source of my troubles.
    26 years and the servo is probably having problems. They just don't make 'em like they used to. :D
  8. ChapmanF
    19,087
    It may be right as rain again after just disassembly and wiping with contact cleaner.
    Somewhere on this board, though, there's a picture from someone who had let it go long enough that the resistance traces on the gear had been worn all the way through in those spots. New-actuator time.
