No temperature gauge in the Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by PriusJay, Feb 14, 2007.
  1. PriusJay
    PriusJay New Member
    I always wondered why there is no temperature gauge in the Prius. We all know it uses coolant, so why no temp. gauge??
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(PriusJay @ Feb 14 2007, 09:13 PM) [snapback]390639[/snapback]</div>
    I think it's just one of those things of "why do you want a temp guage"...it would be one of those things you could look at, but not do anything about. If the ICE gets too hot you'll get an idiot light telling you so.
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(PriusJay @ Feb 14 2007, 07:13 PM) [snapback]390639[/snapback]</div>
    it uses oil but no oil pressure gauge.
  4. Tideland Prius
    16,554
    There's no low windshield washer fluid warning either
  5. qbee42
    3,079
    How about a "driver intelligence" gauge, or a "am I driving or am I talking on the cell phone" gauge?
  6. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I think there should be a gauge for the cumulative stupidity of OTHER drivers within a 100 foot radius. Then again, that gauge would always be pegged.
  7. Rest
    Rest Active Member
    1,210
    CA
    <div class='quotetop'>QUOTE(efusco @ Feb 14 2007, 11:49 PM) [snapback]390666[/snapback]</div>
    And at that point the damage is already done to the engine. A temp gauge can alert you so you can shut down without causing engine damage.
  8. KV55
    KV55 Member
    126
    43
    Northamptonshire, UK
    Excel
    <div class='quotetop'>QUOTE(Rest @ Feb 16 2007, 09:49 AM) [snapback]391342[/snapback]</div>
    Maybe but I had a hose fail on my last car (Nissan Primera) and the temperature went up so fast I'd say there was no difference between a read out and a too hot warning lamp. I was alerted by the engine knocking on acceleration, not by the gauge. I heard the knocking, looked at the gauge and pulled over. I fixed the hose back on, filled up with tap water and drove on. No damage.
  9. KMO
    KMO Senior Member
    1,954
    682
    Finland
    2023 Prius Prime
    <div class='quotetop'>QUOTE(Rest @ Feb 16 2007, 10:49 AM) [snapback]391342[/snapback]</div>
    A curious assertion. Are you saying that the warning light on the Prius is mis-calibrated, and doesn't indicate early enough? How have you concluded this?
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    A little reality here. Cars with temp gauges are no better off than ones without. At least in my experience, measuring coolant temps and watching the gauges, on five different vehicles (models and manufacturers). What the manufacturers do is set the gauge up to move quickly to the "normal" position, and stay there without moving much throughout the temp range of the coolant. When it gets to overheating, the gauge finally moves up showing it's overheating. Again, as others have posted, maybe too late.
    The reason is they kept being bothered by owners noticing the temp gauge moving around. I "recalibrated" the gauge in my RX-7, and it now is linear, and moves constantly (before the mod it never moved, once it indicated "warmed up"). Climb a long hill and it slowly moves up. This kind of operation "freaks out" a lot of people, even though it's normal, so they make the gauges in such a way that they indicate "normal" until the engine is overheating.
    Same effect as the outside temp gauge. Just scan over this forum and others and see the people worried that the temp reading is out 2 deg! Chill out people - engineering accuracy is only 5% and the guages aren't there for exact readings, they are there for "trends". Things like "it's close to freezing - watch out for ice".
  11. Ichabod
    1,794
    Newton, MA
    And to add one point to what David Beale said, If you're not the type to be freaked out unnecessarily by the temp gauge going up and down, then you're likely the type who might not even notice it until a warning light comes on anyway. Get a CAN-View if you really want to know stuff like coolant temp in real-time.
  12. sebapisa
    sebapisa Junior Member
    <div class='quotetop'>QUOTE(qbee42 @ Feb 15 2007, 07:00 AM) [snapback]390787[/snapback]</div>
    Now THAT was funny. :lol:
    Back to the temp gauge, it would be nice to have something there not only to know if the engine temp is going up and stop before it's too late, but I also use it to know when the car is warmed up and I can do some more serious acceleration. I try to be nice to the engine while it's not fully warmed up. But maybe that's just me.
  13. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    <div class='quotetop'>QUOTE(ByWire @ Mar 3 2007, 09:05 PM) [snapback]399760[/snapback]</div>
    You are clearly a candidate for CAN View or Scan Guage. All the information about your car's operation is available. Ain't electronics wonderful?!?
  14. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    I'm with you. That makes at least two of us.
  15. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    A temp gauge is actually pretty useful, because it lets you know
    when you can or can't make stage transitions yet during warmup. If
    you go one of the digital routes for instrumentation you get the
    ability to read temp along with, or you can crock something together
    out of junkbox parts.
    _H*
  16. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    <div class='quotetop'>QUOTE(Bill Merchant @ Mar 4 2007, 12:25 AM) [snapback]399770[/snapback]</div>
    There is currently a scangague group order right here on PC run by Danny..... I believe there are still a few slots open to place an order.
  17. brick
    brick Active Member
    1,083
    79
    Upstate NY
    <div class='quotetop'>QUOTE(Ichabod @ Feb 15 2007, 09:07 AM) [snapback]390790[/snapback]</div>
    I think a sticker would be more cost effective and get the job done just fine.
  18. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well considering the additional cost of the hybrid components, the fact that i am blocking my radiator and will continue to do so until OAT gets over 50º, i think it was a wise decision by Toyota engineers to cut the cost of providing that information.
    even in the most extreme summer conditions last year when i had CANVIEW, i never saw high temps. didnt do any major mountains, but did do some pretty good passes that involved a few thousand feet of climbing and it didnt phase my Prius a bit.
  19. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    It would have been nice for Toyota to include a drill-down menu in the MFD to allow some of us to actually look at things like ICE temp, ICE oil pressure, HV temp, etc. It isn't hard to program one extra touch target, I started doing that 22 years ago on Honeywell industrial TDC 3000 operator consoles.
    Some cars do actually provide a drill-down option. I very recently sold my parents 2003 Buick LeSabre, it had a regular needle temp gage "calibrated" from C to H. However, one could access the Driver Information Center and get raw data like battery voltage, oil pressure, and coolant temp. Especially the oil pressure was fluctuating all the time, just like an old fashioned mechanical oil pressure gage.
    I can accept that the car makers had to "debounce" or dejitter car gauges as most drivers would have been alarmed by a fluctuating oil pressure or a engine temp that was all over the place. But for the rest of us, it's a PITA.
    I've looked into adding something like an Autometer mechanical oil pressure gauge, or an Autometer temp gauge. It looks like a lot of work, but would be a nice summer project.
  20. hobbit
    4,089
    469
    Bahstahn
    If you find the appropriate plumbing and pressure sensors, lemme
    know. I'd be really interested in bringing the output of an
    electric sender up to the panel...
    _H*
