Battery Charge
Discussion in 'Gen 2 Prius Technical Discussion' started by horpelkrufkin, Feb 18, 2007.
  1. horpelkrufkin
    horpelkrufkin New Member
    Hello everyone.
    We just bought our first Prius a week ago and we're absolutely in love with it.
    Unfortunately, I don't think our salesperson was all that knowledgable, but I thought I would try and get some more accurate information here.
    the sales guy was telling us "Engine Break" was a utility in the car for charging the battery when the user has been away for an extended period of time. So Say, if I come back from a 3 week vacation and the battery is at a low charge, I can get in the vehicle, put it in "Engine Break" mode, and the engine would run for a while specifically to charge up the Hybrid battery.
    So naturally, I come home and try to find this in the manual and it's nowhere to be found. I realize,now, what engine breaking is for (the hybrid version of the downshift) but aside from my frustration with Salesman idiocy, I can't seem to find out if there is a way to get the Hybrid battyer to full capacity. At least nothing documented.
    The battery has been at 80% charge since we bought it but doesn't ever seem to hit full charge.
    Is there a solution for this, or more importantly, are there any advantages to a full charge?
    Thanks
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(horpelkrufkin @ Feb 18 2007, 12:17 PM) [snapback]392384[/snapback]</div>
    Welcome to site. Forget about the idiot salesman. The car will take care if itself. The traction battery's state of charge (SOC) stays in a relatively narrow band. It is never fully charged nor fully discharged. This increases the life of the battery. Relax and enjoy the car.
  3. Tideland Prius
    16,615
    The battery meter on the screen is not the true SOC (state of charge) of the battery.
    6 bars (which I assume is what you're telling us) is really 60% true SOC. A full 8 bars on the battery meter on the screen is only 80% true SOC and 0 bars (which you'll never see) is 40% true SOC. The computer likes to keep the battery at 60%
    The reason for this is to lengthen the life of the battery by keeping it close to a constant SOC.
    Depending on where you live (whether it's hilly or flat terrain) you may or may not see 8 bars at all.
  4. horpelkrufkin
    <div class='quotetop'>QUOTE(Tideland Prius @ Feb 18 2007, 02:14 PM) [snapback]392414[/snapback]</div>
    Thanks.
  5. 8AA
    8AA Active Member
    550
    62
    Maryland
    Another thing to concider is that if the battery were fully charged, you wouldn't have any room to put any energy from regenerative braking. The car tries to store excess energy, but at the same time use that energy when needed and make room for more excess energy.
    If you really want to see all the bars lit, you can drive down a nice long hill. Also, with cold weather, the ICE will probably be running more often than normal, and the excess energy will be sent to the battery. Cars driven in really cold weather will typically stay in the 7 or 8 bar range.
    Some people on here have speculated that "B" will charge the battery faster, and some salesmen have been reported as saying that "B" stands for battery. The "B" mode is just for steep hills where you find that you're riding the brakes to the point of using the friction brakes. Instead of wearing those out, the ICE can be used for compression braking (engine braking). However, like the friction brakes, the energy from compression braking will be dissapated, and will not be recovered.
  6. D0li0
    D0li0 New Member
    118
    Seattle, Wa
    <div class='quotetop'>QUOTE(Tideland Prius @ Feb 18 2007, 11:14 AM) [snapback]392414[/snapback]</div>
    Here's a little more technical information and some graphical representations of the battery SOC from various people on this and other Prius forums: Toyota_Prius_Battery_Specs.
    http://www.eaa-phev.org/wiki/Toyota_Prius_Battery_Specs
    Just in case you ever see that sales guy again, you've already discovered the "B" mode is for "Compression Braking", and you can force charge the battery pack at will by placing the car in gear, keeping your foot on the brake peddle and giving it various levels of accelerator. You won't be able to tell, but the more gas you give it the faster the engine runs and the higher the rate of charge, from about 5 to 50 Amps. The battery is full once you can no longer get the engine to "load up" under the load of the generator that produces the charge. Of course this isn't a particularly helpful, perhaps you might want to do so if you intend to leave the car unused for more than a year, I believe you are supposed to start it up every 3 to 6 months... Anyway...
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(horpelkrufkin @ Feb 18 2007, 01:17 PM) [snapback]392384[/snapback]</div>
    In my personal opinion, your sales "expert" is either a crack addict or so inbred he cannot tie his own shoelaces.
    Once you power down the car, the HV relay is open. The NiMH battery is electrically isolated from the rest of the car, and should be fine for 6 months. Maybe a year.
    The little 12 vdc auxilary battery is crucial, if it goes dead you cannot boot the computer to command the HV relay to close. The 12 vdc battery is about the size of a lawn tractor or motorcycle battery, so it doesn't take much to run it down. However there is an emergency jump point under the hood, which is well documented in your owner manual.
    One of the best ways to reduce electrical drain on your 12 vdc battery is to poke the SKS disable button under the steering column. I've checked my car a few times and the standby draw is around 28 mA. If the brake boost pump should happen to run that takes a few amps, not sure how many as I haven't had the meter hooked up when it was running.
    I'm frequently away on business and have a VDC Battery Minder hooked up to my 12 vdc battery. It keeps a float charge on the battery, and will also desulfate the battery too. Have been using it for a year now, works fine.
  8. horpelkrufkin
    <div class='quotetop'>QUOTE(D0li0 @ Feb 18 2007, 07:48 PM) [snapback]392553[/snapback]</div>
    Not completely sure I understand this part. Are you saying to put the car in "Drive" mode, hold the break and give it gas? that's what it sounds like you're saying. Would this have any adverse effects on the vehicle?
    Also, I assume that there is never really a reason to use "B" mode unless you are traveling down a very steep hill for a considerable distance.... correct?
  9. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(horpelkrufkin @ Feb 18 2007, 08:15 PM) [snapback]392636[/snapback]</div>
    Yes. I really only use 'B' when I'm coming out of the mountains, the battery is 'fully' charged, and I need to limit my speed. 'B' works really well for this. For regular in town driving it's not useful unless you want poor gas mileage. You probably won't use it too much in OK but you may find it useful from time to time.
    Oh, and welcome to PC! Glad to hear that you're enjoying the car.
  10. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    The best advice I can give you is to not actively do anything to try to affect the SOC of the battery....the car will take care of this. If it's low when you return from vacation...drive your car like normal.
    if it's high while on a trip...drive it like normal.
    If it always seems to stay at 6 blue bars and you're wondering if everything is working ok....drive it like normal.
    The car will take care of that battery, and if it can't you won't be able to do anything about it b/c something is badly broken.
  11. Stepclimb
    Stepclimb Junior Member
    44
    San Antonio, TX
    <div class='quotetop'>QUOTE(horpelkrufkin @ Feb 18 2007, 10:15 PM) [snapback]392636[/snapback]</div>
    Welcome to Priuschat! I'm sure that this site will let you enjoy your car more via a more thorough understanding of its inner workings.
    If you hold the brakes with the car in D and press the accelerator pedal, the engine will spin the 2 Motor-Generators and charge the traction battery. However, as efusco indicated, doing so is not necessary in the normal course of driving the vehicle. It will largely take care of itself. The onboard computers strive to keep the traction battery in a narrow window of charge. Doing so allows the battery to last longer.
    minor side note:
    Break:(v) to smash, split, or divide into parts violently
    Brake:(n) a device for slowing or stopping a vehicle or other moving mechanism by the absorption or transfer of the energy of momentum, usually by means of friction
  12. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Sheesh. Have that *salesdroid* read this. Getting him to
    *care* about getting his fact straight may be another matter, though.
    There is actually rationale for why force-charging works. A common
    testing scenario that auto techs do is called "transmission loading"
    in which an automatic transmission is put in gear, brake held, and
    given gas for the sole purpose of putting a load on the engine. The
    energy produced goes up as heat in the fluid torque converter in the
    tranny. Well, the Prius doesn't have that so the most logical place
    to put the energy is ... guess where. But you can only do that up
    to a point; once the battery is at 80% [showing "full" on the MFD],
    the "loading" scenario gradually stops and you can't do it anymore.
    No place to dissipate the energy any more.
    So Toyota appears to have made a nod toward this common testing
    trick, but with certain limitations.
    _H*
  13. horpelkrufkin
    <div class='quotetop'>QUOTE(Stepclimb @ Feb 19 2007, 12:22 AM) [snapback]392671[/snapback]</div>
    :lol:
    No need for that. I have a language professor calling out all of my verbal mistakes at work.
    Thanks for all the help.
