Cold weather MPG? Always charging?
Discussion in 'Gen 2 Prius Fuel Economy' started by gbergma1, Feb 15, 2007.
  1. gbergma1
    gbergma1 New Member
    Quick question for 06 Prius owners: my MPG has decreased from around 45 MPG to about 30 MPG, is this typical for cold weather? Driving conditions haven't changed that much, I do not let the car warm up for extended/wasteful times in the garage, tire pressue is good, air filter is good. On my display the engine is always charging the battery unless I am coasting or braking. I took the car to the dealer and they said this was normal. I don't think so, but the diagnostic check says all systems are good. Any advice? Is this normal? Thanks and looking forward to plugging in my Prius in the near future.
    Thank you al for working towards a solution. It is refreshing to see a group of people that instead of always saying "we can't", you and your organization ask the question "how can we?". My wife and I own a Prius as well as an old diesel mercedes I converted to run on veggie oil.
    V/r, Geoffrey
  2. qbee42
    3,082
    Cold weather and snow will cause a mileage drop in any car. You see it especially in a high mpg vehicle like the Prius, since the numbers are so high to start. We average around 54 mpg in the summer, but are getting about 42 mpg now.
    As for constant charging, the Prius will run the ICE more often and for longer times in the winter. It needs to keep the catalytic converter warm, and heat the inside of the car. As a result, more electricity is available for charging, so it might as well use it. There are also so more subtle effects involving the ability of the battery to store a charge.
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :unsure: I'm experiencing the same "cold weather" effect as Geoffrey... about 8-10 MPG reduction with OAT running 25ºF - 40ºF. Part of the loss is due to the ICE running more to keep the cabin warm. Still, I get about twice the fuel efficiency in the Prius as in our Camry, so I really can't complain. I have done the 'partially blocked grill' thing which seems to help a little.
    Another factor in my case is only ~2,000 miles on the odometer so my '07 Prius is still not broken in. It took about 8,000 miles for my 2004 to achieve its best fuel economy.
  4. jimnjo
    jimnjo Member
    117
    2015 Prius c
    My mileage numbers are almost identical to Tom's - 54 summer to mid 40's winter. I have always seen substantial decreases in winter, in part because we have always driven high - mileage cars that show the difference more dramatically.
    Cabin heat is a factor, no doubt - and we leave the heater off until the engine is warmed up (don't know if this really helps, but it seems to). Sometimes we forget...and it feels like our old VW bug!
    Lower efficiency must be a factor in winter cold.
    Compromised rolling resistance (snow on road, slush) seems particularly troubling for this car.
    We always see a sudden decrease as winter approaches, and I have always figured the formula for the gasoline changes a bit for cold weather, with a noticeable difference in fuel economy.
    Jim
  5. bgdrewsif
    bgdrewsif New Member
    497
    Phoenix, Arizona (formerly Bowling Green, Ohio)
    Here I was averaging around 46-49 MPG in the summer and now im averaging around 33 MPG in town and around 42 MPG on the highway.... and we just got 10 inches of snow and It has been holding in the 0's - low 10's for about 3 weeks now... still, I m getting far better mileage than most people so I do not feel too bad... although I miss my 48 MPG average from this summer
  6. onerpm
    onerpm New Member
    477
    MN
    My current Prius (a 2006) was purchased about 8/1/06. For the last 5 months of 2006 (half of which time I had the snow tires on), I averaged about 44 mpg. For the first 5 tanks in 2007 (and it's been very cold here in MN for the last 3-4 weeks), it's dropped to an average of 37. I have a fairly short commute, under 6 miles one way.
    rpm
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My first winter with the Prius, we had about a week of -35 to -40. I didn't have a winter front. The ICE ran constantly, I just about froze, but the battery SOC was fully green. I think it's normal for cold temps.
    This winter we've had almost 6 weeks of bitterly cold weather. With the winter front, I'm toasty warm and the battery will usually be in the high blues.
  8. member
    member New Member
    197
    <div class='quotetop'>QUOTE(Geoffrey B. @ Feb 15 2007, 06:22 AM) [snapback]390767[/snapback]</div>
    If cold enough, absolutely. Also, if you're not using the block heater - definitely.
    Coasting and braking (and park) are when the batteries charge - normal.
    Hang in there through summer and I'll bet you'll be happy with it.
