Window wiper fluid indicator
Discussion in 'Gen 2 Prius Main Forum' started by jmann, Feb 18, 2007.
  1. jmann
    jmann Member
    201
    30
    Cleveland, OH
    So, I discovered that the Prius does not warn you when the wiper fluid reserver is low. Or does it, in a way that is so inconspicuous that I did not see?
  2. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    Well, it wouldn't be a bad idea to pop the hood once in a while and check the dipstick for your oil level...you can check your washer fluid at the same time. :)
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :) One of the Prius "POSITIVES" is the FULL GALLON reservoir for windshield wiper fluid. In freezing weather, I use a generic, auto-parts-store anti-freeze solution.
    I've never felt the need of a gauge or indicator for fluid level. I like the suggestion of taking a look 'under the hood' occasionally to check around including ICE oil level, windshield wiper fluid level, etc. You might even find that a squirrel or possum has established a nest under there... :D :D
  4. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    The hood latch is under the dash, left side of the steering column. Just pull it, the hood will open, and the fluid bottle is on the left. :)
  5. Tideland Prius
    16,547
    Yeah, there isn't one.
    retneprac likes this.
