2006 Prius Coming up on 10K
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Seagull6, Feb 24, 2007.
  1. Seagull6
    Seagull6 New Member
    42
    My 2006 Prius is coming up on 10K and I was planning on changing the oil and rotating the tires this weekend, which I will do anyways, but I have misplaced my maintenance schedule booklet. Besides changing the oil and rotating the tires, what else is required at 10k? Also, is there someplace online where I can get a copy of the maintenance schedule?
    This is a great website, thanks for all of the helpful information - you folks are doing a wonderful job.
  2. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(Seagull @ Feb 24 2007, 11:02 AM) [snapback]395802[/snapback]</div>
    That's it, basically, I think the manual has a bunch of "inspect" items, too, but oil and rotate tires are the only to-do's.
  3. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Here's a great site at Edmund's that tells you what's in the maintenance schedule and any recalls and service bulletins you may need. It also gives you an estimated price for your area. Someone else posted it a few weeks ago.
    http://www.edmunds.com/maintenance/maintenance.do
    - Tom
  4. Seagull6
    Seagull6 New Member
    42
    Thanks, that's just what I was looking for! :D
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Be careful of that Edmonds recommendation. They suggest a coolant flush at 30K miles; BAD IDEA!
    You'd be better off going to the Toyota Service site and following the manufacturer's recommendations.
  6. qbee42
    3,079
    Don't forget that at 10K you have to put in fresh batteries. I think it uses 18,000 D cells. I usually use alkaline. :lol:
