Weird Scantool
Discussion in 'Gen 2 Prius Technical Discussion' started by hobbit, Mar 4, 2007.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    It's well know that the Vetronix Mastertech MTS3100 is the "official"
    OEM tool aka the "toyota handheld tester" in the US, but what the
    heck is this? It is part of the kit used by a guy in the
    Ukraine, and apparently toyota folks over there get a somewhat
    different tool than the US. Can any of our EU colleagues provide
    some insight?
    _H*
  2. hobbit
    4,089
    469
    Bahstahn
    Here's another link to a little more info:
    _ http://dealerscan.ru/download/IntelligenttesterIIToyota.pdf
    Looks to be entirely touch-screen based; I wonder how long that's
    likely to hold up in a busy shop environment... it's pretty well
    known that PDA-based tools crap out in very short order.
    _H*
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    In Japan, The official tool is called "TaSCAN", Toyota's P/N is 09991-70200 (274,400 JPyen).
    Ken@Japan
  4. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    From Ken's sketch, looks like Japanese dealers use the same/similar scan tool as the Europeans. I guess we are the one with the "weird" scan tool?
  5. hobbit
    4,089
    469
    Bahstahn
    Iiiiinteresting. Looks like the same widget, all right. Not cheap,
    either. But word on the street is that Toyota has flushed Vetronix
    as the stateside OEM, and is rolling out something else -- anyone
    know what exactly that is yet? I heard a vague mumble of "SPX" or
    Snap-on, but haven't heard the real deal so far.
    _H*
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    My local Tech said there would be a new Scan Tool comming. Faster and much easier to use. Could this be what he is talking about?
  7. ScottY
    ScottY New Member
    1,250
    Long Island, NY
  8. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    <div class='quotetop'>QUOTE(ScottY @ Mar 5 2007, 02:13 PM) [snapback]400421[/snapback]</div>
    The new scan tool is called TechStream. It is a Panasonic Toughbook notebook computer installed in a SnapOn designed Vehicle Interface Module / protective cage which has the ODB II /DLC 3 cable on it. It is INCREDIBLE!!! Wireless internet connection which gives the Toyota Tech the ability to connect to the car, retrieve DTC's, view live data from the car, record data from any and all sensors, graph the data, send the data to other locations, (Tech Assist engineers etc.) program keys, program remotes, reprogram ECUs, reprogram Immobilisers, (both reprograms require TIS connectivity, which use to mean hook up the scan tool and bounce back and forth from the TIS computer to the car. Now it can all be done sitting in the driver seat) We are one step closer to Star Trek here, and I have only scratched the surface of the TechStream's abilities. As a Toyota Tech, I even considered buying my own TechStream ($6500.00!! Ouch!!) but then found out the one cost that stopped me. $1000.00 a year per TechStream to be connected to ToyoNet which provides 50% of the abilities of the tool. Without that connection, the tool is crippled. It becomes a fancy codepuller.
