Engine idle changeover (ICE to ELECTRIC)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by smokey1, Mar 4, 2007.
  1. smokey1
    smokey1 New Member
    36
    Hi everyone,
    I just purchased my 2007 prius less than a month ago. I just recently noticed that when the car is in the ICE mode and switches to the electric mode it sometimes idles rough (almost like it appears to stall) then switches to electic and seems finel. Has anyone else experienced this?
    Thanks
  2. D1CK1E
    D1CK1E New Member
    30
    <div class='quotetop'>QUOTE(smokey1 @ Mar 4 2007, 12:13 AM) [snapback]399801[/snapback]</div>
    Yeah, that's your ICE turning off. When the car is at a stop or moving very slowly it's more noticeably rough. I wish I could go around in stealth mode all the time. =)
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    This is something that's much more pronounced in cold weather, it virtually disappears in the summer. I think it may decrease with time/age as well as I rarely notice it any more.
  4. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    It almost like a small, almost imperceptible shudder.... indeed it is the enging shutting off. If you think thats bad, and in order to properly appreciate how truly smooth it is, just think about how much noise and vibration your regular ICE vehicle made when starting and turning off. The Prius does that many, many times during each trip, mostly imperciptable.
    So in reality, that little shudder is not much at all. You'll get used to it, and as the Dr. says, its a little more prounounced in the winter than summer.
    Welcome to PriusChat!! :lol: :lol:
  5. brick
    brick Active Member
    1,083
    78
    Upstate NY
    I think that has to do with the atkinsonized intake valve timing. To increase efficiency the Prius actually blows some of the intake charge back into the manifold before the valves close for compression. That way the compression stroke is shorter than the power stroke. But since this is going on, there will always be some fuel vapor left in the intake that needs to be burned before the engine cuts off. That means you might get a couple of cycles during shutdown where the engine is burning off that fuel, and those cycles aren't going to be terribly smooth. It may be worse in the winter if fuel gets a chance to condense and collect outside of the combustion chamber.
  6. afed
    afed New Member
    <div class='quotetop'>QUOTE(smokey1 @ Mar 4 2007, 01:13 AM) [snapback]399801[/snapback]</div>
    My two week old '07 Prius does exactly the same thing. I was wondering about it just as you were. I'm glad to see that's "normal".
