Bike Transport
Discussion in 'Gen 2 Prius Main Forum' started by vincentsantafe, Mar 12, 2007.
  1. vincentsantafe
    vincentsantafe New Member
    Hello, I will receive delivery of our new Prius tomorrow and I have been wondering about transporting bikes. I have been searching this board and have had some trouble figuring out the best way. I was reading about "melting bumpers" etc.. and thought I would ask the experts. I assume I will need a receiving hitch. If so, which should I buy. Thanks. Any advice will be appreciated.
  2. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    With the rear seats folded down, I transport my bicycle in the rear (through the liftback). With more than one bicycle, I use a Yakima rack on top (with nylon bras to reduce insect and microdust impacts). Either method, the Prius sits low enough to make loading and unloading very easy.
  3. dspguy
    dspguy Junior Member
    49
    Boston
  4. jgills240
    jgills240 Member
    190
    Palmdale, CA
    This is how I transport mine, along with one more bike, and two surfboards, all at once.
  5. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I just bought a Saris Bones, a trunk-mount hitch, based on the experience of john1701a. I haven't used it yet, so I can't cite any personal experience. I chose the trunk mount because I wanted to avoid the cost and time of having a hitch installed, and because I didn't want anything mounted on the roof for aerodynamic and cosmetic reasons.
  6. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    <div class='quotetop'>QUOTE(JimboK @ Mar 12 2007, 08:00 PM) [snapback]404486[/snapback]</div>
    It's been working really well for me, carrying oddly shaped bikes no less. See:
    There are larger photos are on this webpage and there are close-ups of that rack here.
    Being able to fit that other recumbant inside at the same time, while still being able to seat 3 people too is pretty impressive.
    [​IMG] . . [​IMG]
  7. JimboK
    2,817
    188
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(john1701a @ Mar 12 2007, 08:12 PM) [snapback]404490[/snapback]</div>
    Hey, John, what are you currently using to keep the straps from rubbing on the spoiler?
  8. john1701a
    12,833
    5,310
    58
    <div class='quotetop'>QUOTE(JimboK @ Mar 12 2007, 08:33 PM) [snapback]404499[/snapback]</div>
    Just a piece of cheap foam pipe-insulation does the trick.
  9. jgills240
    jgills240 Member
    190
    Palmdale, CA
    When the rack's not in use, it pops off by pushing 4 (lockable)buttons:
    In my eyes, not at all cosmetically unappealing. I actually like it better (there are caps that cover the silver bars).
    Plus this way it's expandable for future hobbies; snowboards/skis, kayaks, canoes, cargo boxes, longboards... will not fit thru the hatch. I have noticed no loss in MPG in this configuration.
    Also, check out similar topic: HERE
  10. edselpdx
    edselpdx Member
    191
    Portland, OR
    <div class='quotetop'>QUOTE(jgills240 @ Mar 12 2007, 09:13 PM) [snapback]404594[/snapback]</div>
    Is this a Thule system? I like the looks of this better than the warts Darrell has (sorry Darrell). Does this require drilling through the roof to attach, I assume? I anticipate a cargo box, bike carrier and future kayak use (not all at once), so am trying to research.
  11. jgills240
    jgills240 Member
    190
    Palmdale, CA
    <div class='quotetop'>QUOTE(edselpdx @ Mar 13 2007, 12:56 PM) [snapback]404923[/snapback]</div>
    Yes, I chose Thule as I already had all the attachments for surfboards and bikes. Yakima also has an identical system, but they use round bars instead of square, which may make it easier to use different configurations. Darell's system is the Yakima, just without the tracks. Drilling is required, I ended up using 6 holes per side (10 are available per side) which turned out to be 4 more than Darell had to drill. So there are some + & - to each way, I just decided the track way would be more versatile, and it looks badass!
