MFD Problems NOW in Russia :(((
Discussion in 'Gen 2 Prius Technical Discussion' started by Prius_Russia, Mar 9, 2007.
  1. Prius_Russia
    Prius_Russia New Member
    Hello !
    Best Regards From Russia !
    My Used Prius NW20 (exported from Belgium) has problems exactly like in
    http://priuschat.com/TSB-EL002-05-Multi-Di...ive-t18112.html
    But in Russia we have no official service for Hybrids cars and new MFD - VERY EXPANCIVE (5 000 US $ at list) .
    Is it some body nows how to repaire my existing MFD (Its look like bad solder inside - if yes were is it??)
    I Russia (and in Moscow ) we have small group of Hybids Crazy Users
    All the Best and Thanks !!!
  2. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    Ungh,
    I seem to remember a few posts here about people buying used MFDs mcuh cheaper then list price. If you are lucky maybe you can find a junk yard shop in Belgium and buy a working/used one cheaper?
    I have no idea about the solder.
  3. qbee42
    3,074
  4. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    In Soviet Russia, MFD fails you!
    (sorry. . . I couldn't resist)
  5. Prius_Russia
    <div class='quotetop'>QUOTE(Betelgeuse @ Mar 9 2007, 12:01 PM) [snapback]402829[/snapback]</div>
    Yes, and it looks as diversion of Japan Сapitalist
    :rolleyes:
  6. Prius_Russia
    <div class='quotetop'>QUOTE(Prius_Russia @ Mar 9 2007, 12:12 PM) [snapback]402837[/snapback]</div>
    OK !
    No Ideas - so BAD ! Is it hardware or software problems ??????
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Prius_Russia @ Mar 12 2007, 11:52 AM) [snapback]404200[/snapback]</div>
    Almost certainly a hardware problem with the MFD itself. This is a known issue here in North America, especially with the 2004 Prius cars. So far, my 2004 Prius has not exibited any symptoms. Perhaps the climate controlled parking at my condo helps in that regard.
    I'm unsure if you can source the much cheaper rebuilt MFD's from your country, without worrying about VAT, duty, etc. Is it possible to check with Toyota dealers in the EU?
    Wishing you luck with the MFD issue. Although it's certainly a high-tech gadget, a failure really locks you out of many functions. The steering wheel buttons only help a little. Sometimes, old fashioned knobs work best, especially for climate control.
  8. Prius_Russia
    <div class='quotetop'>QUOTE(jayman @ Mar 12 2007, 08:38 PM) [snapback]404501[/snapback]</div>
    I contacted with Local Toyota (and with Toyota Europe) - just 1 solution - NEW DISPLAY - 5000 $ .
    And no any Ideas how to repair my display (Prius is unofficial car for Russia market - it Toyotas answer :(((
    In any case I happy with Prius - and dont stop WAR is Toyota Europe ......
    Mybe I will contact with Japan CS department in future ..
    Thanks !!!
    Dima
  9. Hobbs
    Hobbs New Member
    Glasgow, UK
    Have you got part number(s) for the bits you are looking for?
  10. Prius_Russia
    <div class='quotetop'>QUOTE(Hobbs @ Mar 13 2007, 08:25 AM) [snapback]404773[/snapback]</div>
    I have check !!!!
  11. Prius_Russia
    <div class='quotetop'>QUOTE(Prius_Russia @ Mar 13 2007, 08:33 AM) [snapback]404778[/snapback]</div>
    NHW20..EUR;EMV(W/NAVIGATION SYSTEM)-WITHOUT (EUROPE) 86110-47070 (86110-47071)
  12. Hobbs
    Hobbs New Member
    Glasgow, UK
    86110-47070 list price in the UK is £2142. I'm not sure how taxes, exchange rates, shipping costs might affect this. You might be able to get part 86110-47070-EX instead. This is an exchange (reconditioned I think) unit. The list price is £1823 but you have to pay £1000 over this till you return your damaged part. As you are in the trade you might get a trade discount.
    I get the impression that it is extremly rare that this part needs replaced. The part is either very reliable or maybe mechanics manage to fix most problems with it. I suspect most dealers won't have it in stock and they will need to order it.
    E&OE
  13. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    <div class='quotetop'>QUOTE(Hobbs @ Mar 14 2007, 08:35 AM) [snapback]405298[/snapback]</div>
    here in the US it is special ordered from the refurbisher, they do not keep them in stock at the dealership. we have no idea how to fix it as they come from the refurbisher already fixed back up.
    new one here costs about $4000-5000 and a refurbished costs around $500. and the price difference until the part is returned is also normal, we have something set up for NA and the owner has to send the defective unit before we can even order a refurb. liability, the dealer is liable for the cost of a new one until they receive it in as a defective part.
  14. Prius_Russia
    <div class='quotetop'>QUOTE(galaxee @ Mar 14 2007, 11:07 AM) [snapback]405389[/snapback]</div>
    ОК!
    Thanks for all!
    I shall try to repair MFD by own !
    If happens - I shall inform result!!!
    Best Regards
  15. godzy49
    godzy49 New Member
    Hello (from Spain)
    well it's my first post here...
    Have you think about contacting a dealer in Latvia or Lithuania? I belive it is not far away, may be you can go there on friday and pass the weekend... i believe they could reaplace it the same day...
    just an idea
    Regards
  16. Prius_Russia
    <div class='quotetop'>QUOTE(godzy49 @ Mar 19 2007, 04:50 PM) [snapback]408577[/snapback]</div>
    Ok ! Thanks !
    But 2 problems - Baltic its so far from Moscow 1200 km + I Visa in my passport needed :(((
    I contacted with central CS in Europe - he cant help me (just New MFD)
    Ok - MFD its not main part of car .... I can make good script space instead of MFD :)))))
  17. kenmce
    kenmce High Voltage Member
    1,536
    511
    NY
