bluetooth phone
Discussion in 'Gen 2 Prius Audio and Electronics' started by ywbird, Mar 28, 2007.
  1. ywbird
    ywbird New Member
    I have had my new Prius for 4 days now and am absolutely loving it. I am still adjusting to the keyless entry; really have to stop and think if my car doors are locked or not. Spent many hours trying to navigate around directions for the Blue Tooth system. Is there a quick fix or button to use that allows me to install the voice recoginition? Can't seem to get it activated.
  2. hill
    8,936
    <div class='quotetop'>QUOTE(ywbird @ Mar 28 2007, 10:25 PM) [snapback]413914[/snapback]</div>
    We all joke about voice recognition ... OFTEN. You ask for home and it show (for example) coffee shops. Oh well, there's kind of a truth in that :D
  3. ywbird
    ywbird New Member
    <div class='quotetop'>QUOTE(ywbird @ Mar 28 2007, 07:25 PM) [snapback]413914[/snapback]</div>
    Geez, even navigating around this chat space is a bit confusing. I think my brain is on overload with my new car, new phone and a chat site that I have never used before! So from the sounds of it the phone system isn't as easy as the seller at TMobile says it is!
  4. Skynight
    Skynight New Member
    67
    MIDDLESBORO, KY (SE KY, WHERE KY, TN., AND VA. MEE
    and welcome!!
    We are new too...we realllllly tried to read a lot to get all the info...but it is too much to soak in ...in such a short time...we learn something new each week. Try a few key words in the search menu...and just wait...people will help with info, too.
    john/teresa
    <div class='quotetop'>QUOTE(SKYNIGHT @ Mar 28 2007, 09:52 PM) [snapback]413921[/snapback]</div>
  5. ywbird
    ywbird New Member
    <div class='quotetop'>QUOTE(SKYNIGHT @ Mar 28 2007, 07:55 PM) [snapback]413921[/snapback]</div>
    thanks for the comments. Looks like patience is what this all calls for! Is that a Cirrus?
  6. Renocat
    Renocat Member
    363
    Rochester, NY
    Once you add contacts to the phonebook in the Prius, you have to record voice tags to go with each entry to be able to use dial by name. On the edit screen for the contacts, I think you scroll to the next page and you will see where to enter the voice tags.
  7. ywbird
    ywbird New Member
    <div class='quotetop'>QUOTE(Renocat @ Mar 29 2007, 07:54 PM) [snapback]414621[/snapback]</div>
    Thank you! :)
