1. nwpa
    nwpa New Member
    48
    Erie PA
    Soon after we purchased our Prius last year I managed to get the fuse box, under the hood, open. I thought I had fixed the process in my mind but have now forgotten how I did it.
    I would appreciate some step-by-step instructions on the process of getting the fuse box open, please.
  2. KMO
    KMO Senior Member
    2,012
    735
    Finland
    2023 Prius Prime
    On the bottom (very short) edge there's a catch in the middle which you can depress to release that edge. Then it hinges upwards.
    Once you've found the catch, it comes away easily - if you're forcing it at all, you haven't found the catch yet.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    <div class='quotetop'>QUOTE(KMO @ Mar 28 2007, 03:20 PM) [snapback]413808[/snapback]</div>
    This applies to the fuse box near the left front fender, right side looking into the engine compartment. The fuse box in the center near the cowl clips on the sides and is easy. The other fuse boxes are in the cabin and behind panels and under the dash.
  4. qbee42
    3,081
    Darn it guys, you gave away the secret too easily. I was going to write a long, involved procedure that started with "First remove the left tail light assembly..." and went forward from there. :D
  5. nwpa
    nwpa New Member
    48
    Erie PA
    <div class='quotetop'>QUOTE(Perk @ Mar 28 2007, 05:56 PM) [snapback]413787[/snapback]</div>
    Well I finally got the cover off this afternoon. I discovered that the latch on the front, short end of the cover, has to be depressed to unlatch it. Then the latches at the rear end come undone as the cover comes off. I preacticed it several times so I hope that I will remember when I really need to get it off.
    Thanks for all the help.
