12V battery stuff
Discussion in 'Gen 2 Prius Technical Discussion' started by hobbit, Mar 29, 2007.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    This also got posted over on Prius_Technical_Stuff. I spent
    yesterday exploring the 12V battery and related system issues, to
    determine unit size, charging/regulation, and type. Have fun:
    http://techno-fandom.org/~hobbit/cars/prius-12V/
    _H*
  2. qbee42
    3,081
    Nice write up. Thanks for the post.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Thanks for the experiments and measurements, Hobbit! Great write up.
  4. itsme
    itsme New Member
    68
    <div class='quotetop'>QUOTE(hobbit @ Mar 29 2007, 07:08 PM) [snapback]414589[/snapback]</div>
    Good piece of info and specs. it looks as if the terminal post are of a different size both are not the same by any chance did you get a diameter of each post?
    again thanks for the info
  5. faith2walk
    faith2walk Upgraded again
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(hobbit @ Mar 29 2007, 09:08 PM) [snapback]414589[/snapback]</div>
    Excellent work/write-up!!!
    I spend an inordinate amount of time in my car...upgraded stereo, laptop and several accessories and a frig all running of inverters. I have been looking to upgrade the battery to protect me from running it dry. You research puts me several steps closer.
    Did you happen to measure the terminal/posts?
  6. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    H
    Am I wrong or does it look like, if you remove the Toyota battery bracket, there would be an extra 1-2 inches in length and perhaps an extra inch in width.
    Also would the positive battery terminal assembly bolt on to this Lynx Battery Terminal (thanks to egb6550) if so this would adapt to standard SAE post and hence a easier way to replace the battery.
    As always good work.
    Wayne
  7. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    Excellent write-up. Thank you.
