1G Prius engine reseal
Discussion in 'Gen 2 Prius Technical Discussion' started by galaxee, Mar 22, 2007.
  1. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    phone camera pics, kinda low quality, but you get the idea.
    oil leak where the head meets the block, along the edge of the timing chain cover.
    exhaust port on head. on the port on the right, you can see the valve stem through the port.
    rear main oil seal and end of crankshaft
    transmission minus engine
    lower oilpan removed, oil pickup tube exposed. on lower right is where the oil filter screws on, with the threaded centerpost missing
    carbon and oil buildup on intake port
    flywheel: note in the next 3 pics the very small area clutch plate actually contacts.
    clutch plate
    pressure plate
    engine minus valve cover
    engine, upside down, timing cover removed, timing chain exposed
    ends of camshafts. on the left is the vvt sprocket.
    camshaft lobe sticking up
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    lots of varnish build up on the interior and from the angle it looks like a lot of play in the timing chain. How many miles on this car and any history on the oil change interval and the brand of oil used? Thnx the DH for providing them.
  3. galaxee
    9,810
    471
    MD
    109k on it, and DH also noticed the varnish. no clue as to the oil change history, he hasn't looked it up in the customer service history.
  4. tochatihu
    tochatihu Senior Member
    9,807
    3,782
    Kunming Yunnan China
    2001 Prius
    Would like to see if there is less varnish in a big-odometer Prius that has been on a diet of synthetic motor old. Perhaps the simplest place to look would be in the sump, at the expense of a new gasket.
  5. bwilson4web
    16,252
    <div class='quotetop'>QUOTE(galaxee @ Mar 22 2007, 12:43 AM) [snapback]410011[/snapback]</div>
    Great photos but can you tell if the crank throws impact the oil in the pan if it is overfilled?
    One of the hypothesis about overfilled oil is the crank throws impacting the oil in the pan.
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
  7. glenk
    glenk Member
    109
    Fairfield, CA
    Does the title of the thread sugggests that this engine was in for repair of an oil leak(s)?
    Anyways, thanks for the pictures. My guess is this Prius was just "driven". I've seen less varnish on engines with twice the mileage.
    It appears that the water passage looks clean though.
    Interesting to find out about the clutch mechanism. Maybe to reduce the shudder during engine shutdown/startups?
  8. duanelaugh
    duanelaugh New Member
    57
    Bradenton fl area
    <div class='quotetop'>QUOTE(glenk @ Mar 27 2007, 05:31 PM) [snapback]413164[/snapback]</div>
    That's odd, I have always read that the Prius has no clutch....what gives?
  9. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(Duane @ Apr 1 2007, 05:06 AM) [snapback]415912[/snapback]</div>
    all Prius have the "drive plate" as show to reduce the pulses from the ICE to the drive train. And yes there have been reports of them slipping.
  10. nwprius
    nwprius Member
    227
    35
    Thanks so much for the pictures.
    Clutch???? Please let us know just how it works.
  11. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    Gak! Someone wasn't changing their oil. . .
  12. galaxee
    9,810
    471
    MD
    updated to put pics back into text.
  13. Patrick Wong
    18,210
    6,511
    Hi Galaxee,
    Thanks for reposting this string, I had not previously seen it when I was a PriusChat lurker. I understand that the root problem was an oil leak on the timing chain cover, and that it was necessary to remove the engine and transaxle to gain access to said cover. Considering the mileage and the interior condition of the engine, perhaps the owner would have been better off installing an engine from a salvage vehicle of lower miles, since it seems a salvage engine is relatively inexpensive.
  14. galaxee
    9,810
    471
    MD
    with higher mileage engines like that, it's not unusual to see carbon buildup and a little varnish. they keep running fine that way. besides, anything you want can be tossed in a parts washer. generally speaking, if it fits it goes in when it's disassembled like that. ;)
    considering the cost would be about the same for a replacement engine, plus the seals would not be new and replaced as such, and condition of the replacement is unknown vs the known engine you've been driving on... it's kind of a toss-up as to whether it would be worth it.
    when DH swapped the engine from our smashed camry into our es250, we stuck with that one because [a] we were cheap and we already knew what to expect from it. (toyota learned their lesson about bottom ends with the 2vz)
