Fuel Injection
Discussion in 'Gen 2 Prius Technical Discussion' started by bredekamp, Apr 2, 2007.
  1. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    :unsure: Hi all, I'm curious...Who makes the fuel injection system for the Prius' internal combustion engine? Surely the control unit (DME) is proprietary, but that still has to interface to stock standard injectors, O2 and nock sensors.
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(Albertus @ Apr 2 2007, 02:06 PM) [snapback]416613[/snapback]</div>
    Asian with maybe some Denso thrown in nothing special probably the same components as used in the Echo/Yaris.
  3. Tideland Prius
    16,554
    probably Denso
