Are we not treating our bladders right?
Discussion in 'Gen 2 Prius Main Forum' started by YoDaddyAlex, Apr 2, 2007.
  1. YoDaddyAlex
    YoDaddyAlex Member
    271
    Would the solution to the problem of the fuel bladders becoming smaller just be to never let the tank go below 50% or so?
    Just wondering if the design of the bladder could be slowly expanded by making sure there is always an almost full load in it. I can't seem to fill in anything above 6 or 8 gallons
  2. ohm86
    ohm86 New Member
    Do you always visit the same gas station? The 7-11 just up the street from my house NEVER lets me put more than 6-7 gallons in, even when I'm down to one flashing pip. If I go a little farther down the street (to a no-name kind of place), I can get a full tank: no special "tricks" required and no topping off. It clicks off right around 10 gal like I would expect.
    It might also help to use the middle hands-free locking position on the pump handle instead of the fastest. That's just what I've culled from other threads.
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(YodaddyAlex @ Apr 2 2007, 09:11 PM) [snapback]416774[/snapback]</div>
    I only buy at half a tank when I see prices rising. I don't save much money, it's the personal satisfaction. I can't say it makes any difference. The speed setting on the pump probably makes a bigger difference.
  4. jeneric
    jeneric New Member
    442
    Redmond, WA
    The car is programmed to try to keep the gas at 60% Full (about 5 pips). It tries very hard to do this but still uses the tank as a buffer to store gas energy and as a source for extra gas when it's needed. As the SOF gets further from the 60% target the harder the bladder tries to get it back to the 60% number.
    Remember, also, that even when you see all bars filled the gas tank is still at or below 80% actual SOF...and when you see 1 blinking bar it's still above 40% SOF...at least that's what people claim when they run out of gas or can't put as much in as they think they should be able...
    Sorry, totally ripped off this post referring to battery instead of gas tank, but am claiming parody.
  5. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(jeneric @ Apr 3 2007, 09:21 PM) [snapback]417442[/snapback]</div>
    :lol: :lol: :lol:
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I don't know about you guys, but my bladder seems to be getting smaller. Another coffee and oops, time to visit the gas station again... :D
