Line by line Limericks or Limerick-Like Poems
Discussion in 'Fred's House of Pancakes' started by jared2, Dec 7, 2006.
  1. jared2
    jared2 New Member
    1,615
    My Prius is in love with a Hummer.
    Could it have chosen a mate any dumber?
    Give it 2 months at most
    Then that Hummer is toast!
    Size matters, but no brain - that's a bummer!
    Three dollar gas is a pain
  2. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    Feels like cash down the drain
  3. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Three dollar gas is a pain;
    Feels like cash down the drain.
    So I walk 'til my feet hurt,
  4. larkinmj
    larkinmj New Member
    1,996
    And I'm covered with dirt,
  5. jared2
    jared2 New Member
    1,615
    As I curse oil company profits in words profane
    I wish I could plug in my car
  6. jeneric
    jeneric New Member
    442
    Redmond, WA
    I tried once and got this big scar
  7. jared2
    jared2 New Member
    1,615
    Now I'm called scar-face
  8. jeneric
    jeneric New Member
    442
    Redmond, WA
    Reminding the Human race
  9. MarinJohn
    3,945
    304
    The beat of this lim'rik doth mar!
    A lim'rik which doth not mar...
    There once was a man from Nantucket
    Who kept all his cash in a bucket
    But his daughter, named Nan
    Ran away with a man
    And as for the bucket, Nantucket
    There once was a Prius from Jersey
  10. jared2
    jared2 New Member
    1,615
    I wish I could plug in my car [3 beats]
    I tried once and got this big scar [3 beats]
    Now I'm called scar-face [2 beats]
    Reminding the Human race [2 beats]
    The beat of this lim'rik doth mar! [3 beats]
    I think it is fine. Where's the problem?
    That suddenly went topsy-turvy
  11. jeneric
    jeneric New Member
    442
    Redmond, WA
    Using more gas
  12. jared2
    jared2 New Member
    1,615
    Using more gas
    Than a black hole has mass
  13. larkinmj
    larkinmj New Member
    1,996
    Using more gas
    Pamela Anderson sure is curvy!
    (I wasn't sure if I was supposed to rhyme "Jersey" or "turvy".) <_<
    <strike>There once was a lawyer named Alberto</strike>
    Sorry about that- I sure couldn't think of a word that rhymes with "Alberto"!
    Let's try again:
    There once was a man named Rove
  14. jeneric
    jeneric New Member
    442
    Redmond, WA
    Who's name actually rhymed with love
  15. jared2
    jared2 New Member
    1,615
    It was very confusing
  16. jeneric
    jeneric New Member
    442
    Redmond, WA
    What was he musing?
  17. jared2
    jared2 New Member
    1,615
    What was he musing?
    It was Rove, like a glove, not Rove, like a stove
    If there's one thing that I can't stand
  18. jeneric
    jeneric New Member
    442
    Redmond, WA
    I put it in an equation with NAND
  19. MarinJohn
    3,945
    304
    <div class='quotetop'>QUOTE(jared2 @ Apr 3 2007, 11:36 AM) [snapback]417174[/snapback]</div>
    Jared, I am certainly no expert in limerickery, I thought they had to follow the syllables as well as the beat of the Nantucket example. I was wrong as some quick research shows the beat is important, but no mention of syllables. BTW No one ever called me Aunt Bee, so I leave it to the more experienced for further comment.
    FYI of participants, here are some things I found:
    http://www.poetry-online.org/limericks.htm
    Limericks - The form
    Limericks consist of five anapaestic lines.
    Lines 1, 2, and 5 of Limericks have seven to ten syllables and rhyme with one another.
    Lines 3 and 4 of Limericks have five to seven syllables and also rhyme with each other.
    http://www.sfu.ca/~finley/discussion.html
    Rhyme Scheme
    Limerick must have five lines with aabba rhyme scheme. This much is well known.
    Rhythm
    The beat must be anapestic (weak, weak, strong) with three feet in lines 1, 2, and 5 and 2 feet in lines 3 and 4. This will be explained further below. However the following exceptions are allowed:
    The first foot of an line may have only one weak beat in front of the strong beat.
    Trailing weak beats that continue the rhyme are allowed at the end of the each line. Naturally these sounds must be identical over rhyming lines.
    The following covers most cases, where S equals a strong beat, w indicates a weak beat, and the brackets indicate that the beat is optional. Note that on the same line, different strong beats are always separated by exactly two weak beats. The options apply only to the leading and trailing beats.
    Lines 1,2,5: w [w] S w w S w w S [w] [w]
    Lines 3,4: w [w] S w w S [w] [w]
    Restriction on Rhyming Beats.
    The last strong beats in the lines must rhyme (125 and 34) and the any weak beats at the end must match and must have the same sound over rhyming lines. Limericks with two weak beats at the end are less common than those with one or none. In poetry books, single beat rhymes are called masculine rhymes; two-beat rhymes are called feminine rhymes. A combination of wwS is called an anapest; a combination wS is called an iamb.
    Beginning weak beats
    Note that each line can start with either one or two weak beats. Various writers have proposed special restrictions (such as requiring just one weak beat at the start of lines one and two, or requiring matching the initial number of weak beats over certain lines), but all such restrictions fail the empirical test of describing what good anthologies and recognized masters have produced.
    caution the following link has sound:
    http://www.limericks.org/pentatette/whatis.htm
    What is a Limerick?
    To be a Limerick, a verse MUST have:
    Five lines
    Lines one, two, and five MUST each have exactly three metric feet
    Lines three and four MUST each have exactly two metric feet
    The metric feet MUST be anapests ( da da DUM ) although the leading foot of each line may be an iamb ( da DUM) and the last foot of each line may have a trailing unaccented syllable ( da da DUM da). The classic Limerick is consistent in the use of iambs and trailing unaccented syllables, but this is not mandatory in recreational Limericks.
    Lines one, two, and five MUST rhyme
    Lines three and four MUST rhyme
    A good Limerick will have a clever, unanticipated punch line as line five
    A good Limerick will not be insipid or pointless
    A good Limerick often has puns, word play, eccentric spelling, or some other witty feature
    Any nonsense poem that lacks five lines, thirteen metric feet, or the aabba rhyme pattern is simply not a Limerick. It might be a sing-song or a la-de-da, but it's not a Limerick.
  20. jared2
    jared2 New Member
    1,615
    It is solved in a flash
