Prius is lower on the driver's side
Discussion in 'Gen 2 Prius Technical Discussion' started by newpath, Mar 12, 2007.
  1. newpath
    newpath New Member
    I've had my Prius a couple of months and noticed yesterday that the driver's side is lower by 1/4 inch - both front and back. I determined that by measuring the bottom trim to the floor on a flat surface. I took the car into the dealer and they confirmed the difference, but they're not sure if this is an issue.
    Anyone else have this difference?
    Thanks,
    - a newbie owner
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    How much do you weigh?
    :lol:
    (Just kidding)
  3. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(newpath @ Mar 12 2007, 07:37 PM) [snapback]404566[/snapback]</div>
    That has come up before. Apparently Toyota concluded that this was a good idea since most roads are crowned on what would be the left side of the car and a level car is better than one which is tipped. Frankly it has never been an issue for me.
    What are the implications of the fact that many cars have just the driver as an occupant? That, alone, would cause the car to be tipped a little, wouldn't it?
    Edit: IsrAmeriPrius types faster!
  4. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    Probably within specs. If it bothers you, consider that the crown of the road is typically 2 to 4 percent, so you aren't really level anyway. In fact, having the driver's side lower on the springs would offset the crown a bit.
  5. newpath
    newpath New Member
    Thanks everyone, for your insight - this is a great website!
    Anyway, I feel better knowing this is part of Toyota's design. I only weigh 150, BTW. One thing I did learn is that Toyota service is exceptional. I went back into the garage and worked through the measuring/comparing, etc. with the technician for about an hour - extremely patient person. He actually brought in another new Prius and also put it on the alignment rack to compare (that one was off by 1/8 inch).
    Thanks again, all.
  6. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    It's built in Stagger for your oval racing needs :)
  7. onree
    onree Junior Member
    49
    Central NJ
    <div class='quotetop'>QUOTE(Allannde @ Mar 12 2007, 11:48 PM) [snapback]404624[/snapback]</div>
    I'm just curious about this explanation -- does this mean that on a multi-lane highway, anyone driving in the left lane would actually be MORE tipped?
  8. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    Personally, I don't think this is "by design". Note that the hybrid system under the hood is asymmetrical (left-right) compared with traditional ICE. The weight balancing (left-right) was probably overlooked by Toyota to fit into the narrow engine bay. 1/4-1/2 inch lower on one side does not bother me at all. No other vehicle I owned had this difference, though. Don't tell me this actually helps handling. That would be interesting... :blink:
  9. fshagan
    fshagan Senior Member
    1,766
    Noneofyourbusiness, CA
    <div class='quotetop'>QUOTE(ceric @ Mar 13 2007, 09:22 AM) [snapback]404899[/snapback]</div>
    Its the future NASCAR design ... built to go fast, and turn left.
  10. newpath
    newpath New Member
    <div class='quotetop'>QUOTE(ceric @ Mar 13 2007, 12:22 PM) [snapback]404899[/snapback]</div>
    The only reason I do think it is by design is that when we put the car up on the alignment rack we could measure the distance from the bottom of the rear shock to a reference point on the alignment rack - 1/4" lower on the drivers side. Measuring in that manner eliminates load variables.
    Whether by design or not, just knowing my car is not the only one with a difference is enough for me.
  11. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Most likely the reason the Prius is low to the left, is that the 60 HP motor is right next to the wheel well on the left side.
    In right hand applications, the balance is probably pretty good, due to driver weight.
    Maybe future front wheel drive hybrids will figure out a way to put MG2 next to the engine, and MG1 outboard. That would be advantagous for Plug-in Hybrid cars, as MG2 could be made more powerful.
    The GS-450H already has the MG2 near the centerline of the car, as its rear wheel hybrid drive. They are very quick too. I have seen a few blow by me already.
  12. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    My old VW beetles and the Rabbit had front seats that could be swapped; this helped even out the wear although it put the adjustment controls in the center instead of at the doors. I never thought about one side of the car being higher/lower than the other. A quarter of an inch is a pretty tiny amount and one would think that this could be within the margin of error in measuring, tire pressure differences, etc. The idea that this difference is by design in order to offset the crown in the road, doesn't make sense because Japan, England, Australia and other countries drive on the left side. Unless, maybe, if it is an intentional design feature, the difference in height is part of the installation / location of the steering wheel, pedals, etc.
  13. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(newpath @ Mar 12 2007, 08:37 PM) [snapback]404566[/snapback]</div>
    Although I saw this post some time ago, I just decided to reply.
    Mine is a lot more than 1/4 inch lower. I can see it sagging on the left side when I stand behind it.
    That's looking at the body, not doing any measurements.
    Dave M.
  14. jon11
    jon11 New Member
    <div class='quotetop'>QUOTE(dmckinstry @ Mar 19 2007, 07:54 PM) [snapback]408674[/snapback]</div>
    ...same with mine.
    jon
  15. ibmindless
    ibmindless Member
    206
    I noticed that my 2007 Touring #6 seemed to lean left - and it seemed to pull left. I never measured the suspension for lean, but it always felt like it favored the left side. I finally took it in for service @ 2900 miles and they adjusted the front alignment - the left was out of spec. I've barely driven it in the past couple of days since the realignment, but it feels much better --- no lean or pulling that I can detect. Oh, and the alignment was covered under warranty.
