noise / hiss
Discussion in 'Gen 2 Prius Audio and Electronics' started by Sillyboy, Apr 1, 2007.
  1. Sillyboy
    Sillyboy New Member
    58
    I am getting alot of noise (even w/ the car off) that sounds like a whitenoise "hssssss". It pretty loud'ish... setting my head unit to about 25, and turning the gains on the cleansweep or amp until I can hear the hssss w/o straining... then playing music, I get about 80-85db w/ my spl meter. So, no super loud and easily audible hiss. Unsavory.
    I am fairly sure its coming from the head unit, and I plugged my ipod directly into the cleansweep and it played clean. I also tried nuking the amp turn on that comes from the front cigarette lighter (simply hard wires the amps to the battery)... and that didn't help.
    Anybody have a theory? I would think i was just doomed w/ my crappy head unit, but I know others have nice systems w/o this problem (though, not sure if anyone has non-jbl?)
    Help apprecated.
  2. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    Mine does it, too. Not very loud, but noticeable with no music playing. I chalked it up to my amp wiring from the headunit to the trunk.
  3. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    Are you only getting it while using the iPod as the source?
    Do you also get it from CD playback, AM, FM, Satellite?
    I've read many posts from people picking up noise by going
    in through the aux port in the center consol, especially when
    plugging into the cigarette lighter for powering their auxiliary
    device (e.g. iPod).
    Does the Cleansweep have some kind of adjustable noise gate?
    My amp has a built-in noise gate, which can help with the kind
    of background noise you're describing.
  4. Sillyboy
    Sillyboy New Member
    58
    Happens on *every* input. I don't think my amp nor cleansweep have an adjustable noise gate.
    I want to cry a little.
  5. Sillyboy
    Sillyboy New Member
    58
    Maybe what this party needs is a head unit below the current head unit... in the map pocket. I saw on the web somewhere some got a Mac computer in there... a new head unit has to be easier than that :)
  6. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    <div class='quotetop'>QUOTE(Sillyboy @ Apr 1 2007, 05:37 PM) [snapback]416084[/snapback]</div>
    What pieces of eqipment do you have in line, starting with the head-unit.
    I know about the clean sweep, but what amp are you running? Anything else in-line?
    Line level converter, etc?
    Maybe you can go through and tweak the gains here & there and get a less noisy result.
    Axing the head unit, while probably giving you cleaner sound quality as input, has other undesirable
    side-effects (i.e. loss of MFD integration & steering wheel control).
  7. Sillyboy
    Sillyboy New Member
    58
    k, three pieces of diagnostics:
    1) I routed 1 channel, skipping the eq and amp. Then, on the other channel, I adjusted eq volume / amp gain, such that the volumes on the two channels were roughly equal. Then I compared noise... and the amp/eq channel was way way way way way noiser. Without an amp/eq there was basically no noise. This made me think "oh good, the HU is fine".
    2) I hooked up an ipod to the cleansweep aux in. Very low noise. This made me think "oh crap, my HU is hosed".
    3) Noise doesn't change much from volume 1 to volume 40. However, volume 0 is almost like a "Poof" noise is gone.
    So, I don't really know what to think, I just know its all bad :) Back to your question:
    HU ---speakerwire to trunk---> Clean Sweep ---rca--> Profile AP1040 80W x 4 Car Amp
    amp outputs:
    ---speakerwire (front)---> Factory Speaker Harness
    ---speakerwire (bridged, sub)---> Boston Pro 10.4LF subwoofer
    ---rca via passthrough---> Soundstream D200 2 Channel Amp --->speakwire (rear)
    In playing w/ increasing amp gain vs increasing cleansweep volume... I get more noise via the amp. At any rate, there is no gain at which I can get sufficient spl, yet low enough noise.
  8. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    <div class='quotetop'>QUOTE(Sillyboy @ Apr 1 2007, 11:23 PM) [snapback]416259[/snapback]</div>
    Do you happen to know what the signal to noise ratio is for that Profile amp?
    I assumed it was low enough not to be an issue, but I'm not certain.
    A quick thing to try would be to wire the Soundstream amp up to the fronts (instead of the sub).
    See if it gets lass noisy. I know it's only a 2 channel, but I know Soundstream to be a fairly clean running amp.....can't say the same about the Profile.
    Just something to try.
  9. Sillyboy
    Sillyboy New Member
    58
    <div class='quotetop'>QUOTE(GeoGeek @ Apr 2 2007, 09:50 AM) [snapback]416376[/snapback]</div>
    Ya, suppose I can try the Soundstream, but the profile has reasonable stats:
    THD at Rated RMS Power 0.05%
    Signal to Noise Ratio 103 dB
    And the fact that running an ipod directly into the cleansweep gives no noise sorta relieves the amps from blame, doesn't it?
  10. Sillyboy
    Sillyboy New Member
    58
    Please. Kill. Me. :angry:
    Here is tonights interesting and sad testing results:
    - crank gains on eq/amp
    - play a zero bit cd track, with head unit volume on 1
    - stick an spl meter against tweeter ... 90db of noise
    - turn head unit volume to 0. 75db.
    - disconnect speaker inputs from eq. 67db.
    - add an ipod into eq w/ same speaker inputs... stays 67db. (yeah for quiet ipod!)
    Hard for me to take that as anything but noisy head unit. Though, I still don't understand why the head unit sounds mostly okay w/ no amp/eq (in terms of noise :)). Someone the process of converting high level to low and back to high... seriously amplifies whatever noise was already present from the head unit.
  11. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    <div class='quotetop'>QUOTE(Sillyboy @ Apr 3 2007, 03:07 AM) [snapback]416913[/snapback]</div>
    Okay, agreed.....probably not the amp in that case.
    There are several different kinds of line-level in-line noise filters out there....most of these are for
    alieviating engine whine or mysterious RFI. They're cheap and might be something easy to try.
    I don't get the levels of noise you're describing in my system (non-JBL head unit).....although I can get some
    white noise (even at 0 or 1 on the volume knob) if I really crank up the volume (read: input sensitivity)
    on my Three.1.
    The head unit has a max level of 63 (strangely arbitrary)...I set my gains as low as possible so that I can crank it all the way up to 63 and just begin flirting with distortion/clipping. This sort of "idiot-proofs" the system and optimizes the line levels for minimum noise.
    If you're serious about doing the aftermarket head unit, you should be able to use the Metra kit (I'm fairly certain) in the '07. To keep your steering wheel controls, you'll need the PAC SWX device. I think it marries up nicely with most of the Alpine head units these days....most of which also have built in iPod interfacing.
    Check the aplication guides to make sure you get compatible components.
  12. Sillyboy
    Sillyboy New Member
    58
    You are clearly more brave than me, I don't like to get the factory head unit above 40'ish, but I just assume it sucks and would clip/distort/whatever. Of course, this doesn't help my hiss situation.
    I am getting pretty close to pulling the trigger on a new head unit. Between the cleansweep and the dice unit, I could have saved money w/ a new head unit w/ built in ipod support, better frequency response and line level outputs -- and probably been way ahead.
    You have any linky's or direct knowledge of the steering wheel control situation? No chance I would have to give up climate controls to get audio controls w/ the PAC unit is there?
    I *think* this should make it look relatively okay: http://www.metraonline.com/_assets/manuals/INST99-8213.pdf
  13. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    <div class='quotetop'>QUOTE(Sillyboy @ Apr 4 2007, 04:16 AM) [snapback]417509[/snapback]</div>
    Check out the SWI-X at: http://www.pac-audio.com/products/products...eel%20Interface
    I think that the Metra kit installation instructions also give some specifics about adding a diode between two wires to preserve function of something.....I think climate control related.....you can read their .pdf to see the details.
    Good Luck!
  14. Sillyboy
    Sillyboy New Member
    58
    <div class='quotetop'>QUOTE(GeoGeek @ Apr 4 2007, 09:25 AM) [snapback]417557[/snapback]</div>
    Ya, that reference to "GM Vehicles" makes me nervous :) I sent off e-mail to their tech support, will have to see if they are swell enough to write back.
    Guess I am off to research good head units for ipod integration.
  15. FishCandy
    FishCandy Active Member
    220
    292
    I have a gen 3 and getting a Hiss sound on a stock system. What is the problem? I plugged in a regular iPod mini using the 3.5 mm jack.
