Honk me up!
Discussion in 'Gen 2 Prius Main Forum' started by Rxmxsh, Apr 5, 2007.
  1. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    I have a base Prius. I LOVE it! The only thing that I wish I had is a feature of the honking horn when I lock my car. Is there a mod, or something I can do to make this happen? I hate having to look to see if the lights flash, or listen out for the soft "click" of the locks... :rolleyes: I know, it's dumb, but I figure it's worth the ask... :D
  2. qbee42
    3,079
    Ours makes a little toot when it locks. I thought that was standard.
  3. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Priapus goes [beep] when I remote lock.
    When I remote unlock him, he goes [beep beep].
  4. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Apr 5 2007, 09:13 PM) [snapback]418609[/snapback]</div>
    yea, but it's very base. no sks...
  5. iaowings
    iaowings New Member
    450
    I too have the bas model and am so glad it does not toot. I hate absolutely hat that. My mini did that I took it back to the dealer and made them program it not to do that. At first they said they cant but I had looked it up so they had to do it. like I said I hate that toot.
  6. adam1991
    adam1991 New Member
    218
    The Honda system is way superior--the beep is optional on a case by case basis. All you have to do is hit the lock button a second time in a row, and that's when it gives a little toot.
    OTOH, Toyota's key unlock system is superior (well, ok, maybe not really relevant anymore, but still). Two twists of the key in the driver's door and all doors unlock. Honda: twist and hold for a few seconds, then all doors unlock. The two twists is MUCH better.
  7. qbee42
    3,079
    <div class='quotetop'>QUOTE(IAO @ Apr 6 2007, 12:15 AM) [snapback]418611[/snapback]</div>
    The beep on the SKS is very quiet. I also dislike a horn blowing every time someone locks or unlocks, but the one on our Prius doesn't bother me. It's a good compromise.
  8. Tideland Prius
    16,549
    I prefer a soft beep over Honda's loud horn. I get the message. A soft beep is all I need to know it's locked. Also, if the beep is soft, I can hear the actual doors lock (cause sometimes with SKS, it beeps but doesn't lock if I don't close the door fast enough).
  9. adam1991
    adam1991 New Member
    218
    My 94 Lexus gives a soft beep--it even has a volume control on the dash to control the volume of the beep.
    One beep for locked, two beeps for unlocked. Of course, the key itself has only one button on it, which simply triggers the locks to do the opposite of whatever they're doing now--so you have to know by the beeps what it's doing.
  10. edselpdx
    edselpdx Member
    191
    Portland, OR
    Mine has SKS and it does beep (a pretty quiet electronic beep, not the horn) when I lock with either the door button or the fob itself. I had a neighbor who worked odd hours who used to wake me up with the horn beep on his lock. I'm soooo glad he moved. If I'm in loud surroundings, I also look at the lights when I lock, since the lights flash too.
  11. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    ok - well now i know how everyone feels about the honking.... :rolleyes: does anyone know if i can enable this feature or modify my car to do this? B)
  12. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(Rxmxsh @ Apr 6 2007, 04:07 PM) [snapback]419022[/snapback]</div>
    I've also got a package 1 and as far as I know, unless you get a car alarm installed...no beep.
    I would have liked one too. My old Saturn would beep when I locked it. I liked that anyone seeing me leaving my car could hear that I locked it. I also liked the implication that the car had an alarm system, even though it didn't.
  13. jgills240
    jgills240 Member
    190
    Palmdale, CA
    I've been trying to figure out a way to get all the doors to unlock when pushing the unlock button on the fob ONCE. Mine unlocks the drivers door the first press (beep-beep) then all doors upon the second press (another beep-beep). Manual only tells me how to get all the doors to unlock when using the auto unlock sensor in the outside door handle.
