Turn car from [ON] to [Accessories Mode]
Discussion in 'Gen 2 Prius Technical Discussion' started by iseven, Apr 6, 2007.
  1. iseven
    iseven New Member
    I just got my 2007 Prius (pkg #2) 2 weeks ago. With regular gas cars, you are able to turn back the key 1 notch on the ignition to just leave the radio and fan on. How do I do this with the Prius wihtout having to press the POWER BUTTON [OFF] then back [ON] again without the brake pedal pressed in?
    Thanks in advance =)
  2. priussoris
    priussoris New Member
    1,005
    with foot off the brake press the start button once for radio etc..ACC
    and if you want to roll windows down press it twice
  3. iseven
    iseven New Member
    <div class='quotetop'>QUOTE(priussoris @ Apr 6 2007, 01:59 PM) [snapback]418942[/snapback]</div>
    thanks for helping out a noob. i'll try that. :D
    and just to make sure, this is when the car is already [ON] and in [Park], correct?
  4. priussoris
    1,005
    <div class='quotetop'>QUOTE(iseven @ Apr 6 2007, 01:14 PM) [snapback]418950[/snapback]</div>
    Well if the car is on and in the ready mode it is allready for you to just turn on the radio.
    if you park and press the power button it will shut off, then press power button once no foot n brake will get you to the acc for radio if press again windows can work
    hope that helps
  5. adam1991
    adam1991 New Member
    218
    <div class='quotetop'>QUOTE(iseven @ Apr 6 2007, 02:56 PM) [snapback]418939[/snapback]</div>
    You don't.
  6. INPrius
    INPrius New Member
    36
    I do not believe you can do that...
  7. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    From "Off," you can either go to "ACC" (foot off brake) or "Ready" (foot on brake).
    From "ACC," you can either go to "IG-ON" (foot off brake) or "Ready" (foot on brake).
    From "IG-ON," you can either go to "Off" (foot off brake) or "Ready (foot on brake).
    From "Ready," you can only go to "Off" (foot either on or off brake).
  8. iseven
    iseven New Member
    <div class='quotetop'>QUOTE(Betelgeuse @ Apr 6 2007, 05:17 PM) [snapback]419062[/snapback]</div>
    ah i c. thanks!
  9. KMO
    KMO Senior Member
    1,939
    671
    Finland
    2023 Prius Prime
    Actually, you can go from READY to ACC. But I don't think you're going to like it... B)
    You have to do it when the car is moving. Hold down the POWER button for three seconds. You'll drop into ACC mode (and Neutral).
  10. adam1991
    adam1991 New Member
    218
    yeah. That whole "push the power button twice with your foot OFF the brake pedal" is just SUCH an inconvenience.
  11. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    While your question has been answered, my advice is don't run the radio and fan in ACC or IGN-ON. Your 12 volt battery will get run down VERY quickly in ACC. In IGN-ON the hybrid battery cannot be charged by the engine. Just leave the car in ready and enjoy.
    Wayne
