Changing temp diaplay to C from F
Discussion in 'Gen 2 Prius Main Forum' started by Gurmail, Sep 17, 2004.
  1. Gurmail
    Gurmail Member
    247
    Oakland, CA
    I sthere any way to change the temp to Centigrade/Celcius from Farenheit??
  2. victor
    victor New Member
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    Im sure I saw this in the settings somewhere, but I dont have the book to hand.
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    the dealer could probably toggle it using the scantool. It's probably in there, I seem to remember a thread about it wwaaaaaayyyyyyy back.
  4. glscheil1
    glscheil1 New Member
    150
    Raytown, MO.
    Centigrade vs. F.
    <div class='quotetop'>QUOTE(Frank Hudon\";p=\"40214)</div>
    That was my post a loooong time ago. When I first start the car, it shows centigrade. Later on, it will show fahrenheit. I have never been able to have it show fahrenheit only. I'm too old and slow to do the conversion in my head.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Is it possible to enter the service menu (extended), then change the country of origin from USA to CAN?
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Re: Centigrade vs. F.
    <div class='quotetop'>QUOTE(glscheil1\";p=\"40358)</div>
    That was my post a loooong time ago. When I first start the car, it shows centigrade. Later on, it will show fahrenheit. I have never been able to have it show fahrenheit only. I'm too old and slow to do the conversion in my head.[/b][/quote]
    There is a trick for doing a quick approximation. I am too old to remember it, but when I saw it I thought is was great. Oh well. I will start looking into the memory care units.
  7. Gurmail
    Gurmail Member
    247
    Oakland, CA
    I know the formula and can do it easily without paper.( approximately).
    To convert F to C subtract 32 X 5/9. Easy. Eg:
    72 F = 72-32= 40 x 5= 200/9 = 22.22 C approx 22.
    To convert C to F, x9/5 + 32.
    I can easily get rough figures without paper.
  8. tms13
    tms13 Member
    174
    Lochcarron, UK
    Business Ed. Plus
    For rough figures (at normal outdoor temperatures), subtract 30 and divide by 2. Or from C to F, multiply by 2 and add 30.
    e.g. 72°F -> 72-30 = 42 -> 42/2 = 21
    Pretty close to the correct 22.2/9 :)
  9. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Centigrade is no longer in use since 1949. Celsius (°C) is the SI (United States measuring system) unit of temperature measurement. The media continues to cling to °F, despite federal agencies moving to SI (US measuring units) effective October 1992.
  10. Steve Goldenberg
    Steve Goldenberg New Member
    126
    Aspen, CO
    When the ODO is set Miles the temperature is in F. When it's in KM, the temp is in C.
  11. losaltosprius
    losaltosprius Junior Member
    Actually, that's clearly the way it's supposed to be.
    However, I have noticed a bug (I believe only since I had the SSC-40D reprogramming):
    Sometimes (seemingly at random) upon starting the car up, the outside temperature in the upper right of the screen comes up in Celsius even though the ODO is set to miles.
    A workaround for what is clearly a bug is to select the "Climate" display. The Outside temperature will be on the upper left, still in Celsius. However, if you push the "Climate" button again, you will get the Energy Monitor display with the Outside temperature in Fahrenheit.
    Go figure.
  12. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(tms13\";p=\"41256)</div>
    Yep that's the one! I am going to write it down and put the paper in a safe place. Of course I will not remember where that is.
  13. daniel
    14,487
    1,518
    Spokane, WA
    Boy, that happens to me all the time: I make a note to myself to remember something, and then I forget to look at the note.
  14. Steve Goldenberg
    126
    Aspen, CO
    I just had the SSC-40D reprogramming done on Wednesday and have not had the Centegrade display problem. I have an early built #9 (October 2003)
  15. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(daniel\";p=\"41613)</div>
    Me, too -- which is why I'm grateful to live in the age of Palm PDAs.
    Search: celsius. Bing!
  16. daniel
    14,487
    1,518
    Spokane, WA
    As a gadget-freak I want a PDA. My problem is, I have absolutely no use for it whatsoever, and it's just one more bulky thing to carry around. I use a pocket-size notebook instead. (I don't even carry my cell phone around with me. It sits in the car, always off, waiting until I need to make a call.)
  17. tms13
    tms13 Member
    174
    Lochcarron, UK
    Business Ed. Plus
    I would have thought that the solution was obvious - write yourself a note to tell you to look at the note! ;)
  18. tms13
    tms13 Member
    174
    Lochcarron, UK
    Business Ed. Plus
    <div class='quotetop'>QUOTE(Steve Goldenberg\";p=\"41371)</div>
    That must be a North America thing. Here, it's in °C all the time (which is good, as temperatures in Fahrenheit mean nothing to me, but we don't use km in the UK - well, not on road signs, anyway).
  19. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(daniel\";p=\"41771)</div>
    Daniel, wait for the Treo Ace to come out - all the features of a Palm, integrated with a wireless phone, plus bluetooth!
    You won't leave your phone turned off in your car ever again :)
  20. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I only do C in increments of 36 through 40. Before and after that everything is in degrees F.
