Front License Plate Sensor
Discussion in 'Gen 2 Prius Main Forum' started by Capemayal, Apr 13, 2007.
  1. Capemayal
    Capemayal Junior Member
    26
    Curiosity is getting to me.
    On many cars - not just Toyotas, I see a rectangular attachment to the license plate frame. It appears to have a sensor at each side, along the front.
    Does anyone know what this is?
    It's about 1-1/2" high and is long enough to attach to the license plate bolts.
    I've never been able to catch up with an owner of one of these vehicles.
    Thanks.
  2. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    <div class='quotetop'>QUOTE(CapeMayAl @ Apr 13 2007, 10:00 AM) [snapback]422607[/snapback]</div>
    If it's black, it's probably an external EZ-Pass device. If I had a good picture of the front of my car, I'd post it. But you might be able to see just a little bit of it in the pictures (click here) Rand took at our Nov 11 meet. Check the front of the black Prius ... the plate is blacked out, but a corner is just visible.
  3. coonbutt
    coonbutt New Member
    40
    <div class='quotetop'>QUOTE(Proco @ Apr 13 2007, 10:20 AM) [snapback]422627[/snapback]</div>
    On a similar note, what is the circle on the driver's side front bumper? :huh:
  4. Submarine Dude
    Submarine Dude Junior Member
    73
    Glendale, AZ
    <div class='quotetop'>QUOTE(prickly commute @ Apr 13 2007, 08:28 AM) [snapback]422638[/snapback]</div>
    That's the knockout plug for the emergency tow ring.
  5. Highly ImPriused
    Highly ImPriused Impressive Member
    250
    Western NY
    Could it be one of these?
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(prickly commute @ Apr 13 2007, 10:28 AM) [snapback]422638[/snapback]</div>
    Machine gun port. .30 caliber is standard but .50 will fit. ;)
  7. Tideland Prius
    16,597
    <div class='quotetop'>QUOTE(JimN @ Apr 13 2007, 06:23 PM) [snapback]423063[/snapback]</div>
    Can also be retrofitted with a plasma autorifle.
  8. mooney
    mooney Junior Member
    52
    Melrose, MA
    <div class='quotetop'>QUOTE(Proco @ Apr 13 2007, 11:20 AM) [snapback]422627[/snapback]</div>
    That would be my guess, I can go out and take a pic of mine if that would help.
  9. Capemayal
    26
    <div class='quotetop'>QUOTE(mooney @ Apr 14 2007, 10:41 PM) [snapback]423461[/snapback]</div>
    I did go to the EZ pass sight, and found that it is a external ezpass device.
    Apparently certain vehicles must use it because of metal in the windshield.
    Thanks to all who responded.
  10. mooney
    52
    Melrose, MA
    <div class='quotetop'>QUOTE(CapeMayAl @ Apr 15 2007, 12:33 PM) [snapback]423630[/snapback]</div>
    Well, I had the external tag because I had a Jeep Wrangler and there was no way to secure it inside the vehicle. I just decided to use it on the Prius as well.
