CNW rears ugly head again
Discussion in 'Gen 2 Prius Main Forum' started by Reddog15, Apr 12, 2007.
  1. MSantos
    MSantos EcoAccelerometry
    588
    257
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(skruse @ Apr 13 2007, 02:59 PM) [snapback]422946[/snapback]</div>
    Yep, most of the industrialized countries that signed that protocol are inately irrational. Let's see...
    Depending on those countries that did not sign is a better option - they must have an awesome environmental record that demostrates how archaic Kyoto is. Indeed, a better alternative they are. :huh:
    Cheers;
    MSantos
  2. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(MSantos @ Apr 13 2007, 09:55 PM) [snapback]423115[/snapback]</div>
    The Japanese didn't invent the hybrid or the planetary gear system (both of these were thought up decades ago). The HSD system is the result of Argonne lab critiques of THS. The difference is that the Japanese have more impetus than the Big 3 and their thinking seems to be longer term. We do things differently. Sometimes we're right, sometimes they're right. It's not a black and white issue.
    <div class='quotetop'>QUOTE(MSantos @ Apr 13 2007, 10:06 PM) [snapback]423120[/snapback]</div>
    Kyoto is, sadly, a joke. Look at Canadian GHG trends from 1990 to present. Further development of the oil sands will make it worse. Has anybody come close to their Kyoto targets? I don't know of a single country that has.
  3. MSantos
    588
    257
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    LOL... :lol: fascinating Tripp!... fascinating indeed.
    Take care;
    MSantos
  4. iaowings
    iaowings New Member
    450
    <div class='quotetop'>QUOTE(David Beale @ Apr 13 2007, 12:38 PM) [snapback]422714[/snapback]</div>
    10 gallons of gas
    Prius based on new epa 450 miles
    Hummer 80 miles
    That is almost six times as far in favor of the prius.
    Oh both with a single occupant going to and from work with some grocery shopping thrown in.
  5. nfschlaack
    nfschlaack Junior Member
    95
    <div class='quotetop'>QUOTE(tripp @ Apr 13 2007, 11:04 PM) [snapback]423119[/snapback]</div>
    Now don't be rounding up numbers when we don't have to! It would be 0.9%. ;)
    Regards
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    <div class='quotetop'>QUOTE(IAO @ Apr 13 2007, 10:30 PM) [snapback]423136[/snapback]</div>
    No, according to your govt. EPA "estimates" (the only real way to compare fairly, other than real measurements - and who would ever think of using real numbers ;) ) Prius is 46 MPG and Hummer H3 is 15 MPG both overall ratings. That's just over three times (3.1). Did you compare using the H3 (it was the one mentioned in the article)?
    This is funny, as my anti-Prius (see below - called that because it consumes a lot more fuel than the Prius) is rated the same as the H3. I'm embarassed. :p
  7. iaowings
    iaowings New Member
    450
    <div class='quotetop'>QUOTE(David Beale @ Apr 14 2007, 12:12 PM) [snapback]423237[/snapback]</div>
    Nope I just looked up the mpg of the hummer. Guess I should have been specific as to the one I wanted.
