"Info" button on steering wheel
Discussion in 'Gen 2 Prius Main Forum' started by Joel, Sep 24, 2004.
  1. Joel
    Joel New Member
    108
    Houston, TX
    Just noticed mine has new behavior since I had my TSB update to the ECM and my MFD replaced. Now when I press the Info button, it will toggle between "Consumption" and "Energy". Pretty cool.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Yea, it seems to be the MFD that is the thing for that. Maybe the ECM has a roll, but a couple other people that had to have MFDs replaced got the new functionality. Kinda wish they'd drop my MFD at the service dept. or something so I could get that! :( :roll:
  3. BobA
    BobA New Member
    731
    Denver CO
    my car has always done that...got it on 8/4... someone must have fixed it before giving it to me....
    Bob Andersen
  4. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(BobA\";p=\"41591)</div>
    The later releases had that feature, us early guinea pigs don't have it and can't get it unless our MFD fails and has to be replaced. Not sure I've ever wished for my car to break before, but I sure wish I could switch b/w Energy and Consumption without touching the MFD.
  5. BobA
    BobA New Member
    731
    Denver CO
    <div class='quotetop'>QUOTE(efusco\";p=\"41621)</div>
    Evan, I think that's called TWEAKING... or up grading... or lastly...from the engineers point of view..."Damn, that's cool...we should have done it sooner"
  6. peart75
    peart75 New Member
    104
    san diego
    Evan, maybe you need to come up w/ a prius MFD version of the Ethernet Killer =]
    -drew
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I have to say that I don't get it. Is this not wholly managed in software. Why can't the early adopters have this done?? I would think that there is a "update" of the software. I think and I expect this to be done. I can not believe that this is hard wired!
  8. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(hdrygas\";p=\"41713)</div>
    hydry, I hope you're right. But, the Japanese Prius guys were, as usual, the first to discover this and aggressively looked for a way to implement it on the early versions, but were (AFAIK) unsuccessful.
    It's probably one little circuit or something that makes all the difference.
