Is my ScanGauge II faulty?
Discussion in 'Gen 2 Prius Audio and Electronics' started by moredes15, Apr 13, 2007.
  1. moredes15
    moredes15 Junior Member
    30
    I purchased a Scanguage II last month throught the "Pruischat group purchase" and just installed it.
    It turns off 'automagically' on its' own. I can always get it to turn on; it's never failed to turn on and display data, but it turns off at what seems completely random intervals. The longest it's been on uninterrupted, is maybe 10 minutes.
    Is it supposed to behave this way?
    Thank you
  2. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    It's designed to go off when the engine is off. Not a problem in most cars, but it is in a hybrid. In the SG fuel type setup, you need to select "Hybrid." That should correct the problem if you haven't done this already. If you already selected that, then there is a problem.
  3. mrbogie
    mrbogie New Member
    49
    Salina, Kansas
    <div class='quotetop'>QUOTE(moredes15 @ Apr 13 2007, 09:53 AM) [snapback]422672[/snapback]</div>
    I suspect you have not set the scangage to the hybrid setting -- therefore it turns off when the ice does.
  4. moredes15
    30
    Duh. Yup, that was it. I missed the "Hybrid" instructions in the manual, obviously.
    Thanks very much for the quick responses.
  5. JimboK
    2,817
    190
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(moredes15 @ Apr 14 2007, 10:15 PM) [snapback]423454[/snapback]</div>
    My pleasure. Enjoy your ScanGauge! :)
