[ KB ] How to eliminate Reverse Beep & Seatbelt Beep
Discussion in 'Knowledge Base Articles Discussion' started by Danny, Mar 15, 2004.
  1. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Category: 4 Known Issues
    Type: Modifications
    Article Name: How to eliminate Reverse Beep & Seatbelt Beep
    Author: AdminCoop
    Description: Step by step instructions on how to eliminate the Reverse & Seatbelt Beeps
    >>Read Full Article
    2 people like this.
  2. howie
    howie New Member
    Portland, Maine
    There is one caveat to this procedure. No one can sit in the passenger seat while attempting to complete this task.
    A funny story: This weekend my wife and I decided to turn off the beeper. We like to support each other and do things together. So I would touch the buttons from the driver's seat while she read the directions to me from the passenger's seat. Each time we tried to turn off the beeper "b-on" would never appear. We tried it at least 6 times. Then she got out of the car to do something else and the directions worked perfect. Except I didn't know how to change the setting - she was reading the directions and left. I got all excited and called her back to show her that it worked. She sat in the seat and it didn't work. I tried a couple of more times and then realized - it might not work when someone is sitting in the passenger seat. Sure enough, when she got up it worked again.
    Howie
  3. JJay
    JJay New Member
    123
    Vancouver, WA (near Portland)
    That explains why it didn't work the first time I tried it, too. I had some books on the seat!
    Thanks for the info!
  4. jamarimutt
    jamarimutt New Member
    985
    Wouldn't it be much simpler if the screen had a settings menu in which you could turn the beep on or off? I can't believe that Toyota would make a simple procedure so complex, especially in a car equipped with four computers and an LCD screen. :roll:
  5. bobmcgregor
    bobmcgregor New Member
    Emergency Brake On to Disable Reverse Beeper
    Like the previous reply my wife and I were both in the car and finally after dozens of attempts she suggested we try it with the emergency brake on - low and behold the elusive "b on" appeared!
    We were then able to disable the annoying beeping!!
    She was sitting in the passenger's seat when we disabled the beeper.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Brian and I were helping someone disable their reverse beep at the Sierra Club event. We couldn't seem to get it done together, but when Brian went to his car to do it alone, it worked in his. I then moved from the passenger seat to the driver's seat, and of course it then worked. In the cars we were trying it in, the passenger seat needed to be unoccupied.
  7. aknee87
    aknee87 Junior Member
    39
    Central Coast California
    While the recipe for disabling the back-up beeper worked great in my car, when I tried doing it for a friend in her car, it wouldn't work. (She was sitting in the passenger seat, I in the driver's seat.) For kicks and out of desperation, we fastened our setabelts and then performed the sequence and voila, it worked. I honestly don't know whether she had the emergency brake engaged or not.
  8. peter
    peter Junior Member
    29
    gothenburg, sweden
    I cant get this to work in a brand-new european prius. Belt warning does work however, so i seem to be close.
    What happens is that when i release the odo button the odo readout will
    roll over to odoA
    Any more clues ?
    Peter
  9. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    I'm renting a Prius this weekend (Know Thy Obsession). Besides being an education for myself, it's the first time my partner has had a chance to ride in a Prius.
    Last evening, I was about to back into a parking space; I turned to her and said, "You're not going to like this." And then, of course, BEEP-BEEP-BEEP.
    I parked, and she looked at me and said, "Can you turn this off?" I replied to the affirmative, at which point she said, "Good -- 'cause that noise would drive me crazy when I get one of these!"
    ...It's a very addictive car. :)
  10. swepri
    swepri New Member
    71
    Motala, Sweden
    Peter, on our European Prius we can't disable the reverse beep. Sad but true :cry:
    /Paj
  11. peter
    peter Junior Member
    29
    gothenburg, sweden
    Is toyota listening here ?
    I have no problems cutting the speaker if that is what is needed. But i do
    have the opinion that this is a "field changable" feature that toyota
    should be happy to offer ( yes i'm willing to pay).
    That car is damn good, but as with everything there is place for improvement.
    Another thing on my list is the "forced engine breake" when i lift my
    foot from the accelerator. As born up with SAAB twostrokw and freewheel
    i still find it natural to freewheel whenever i lift the accelerator. Speed
    reduction is what the breakes are used to !
    I think i'll talk to some representatives in sweded. I'll report whetever
    information that pop's up.
  12. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(peter\";p=\"41950)</div>
    I don't know if you can always do it, I haven't had mine long enough to test everything but: If you press just enough after letting off the acellerator, you can get the display to show no arrows at all. I do it coming to a traffic light when I don't think regen is needed because it will change before I get there but I would have to get back up to speed if I used the brakes. I can feel the drag let up when I do this.
  13. betshsu
    betshsu Member
    302
    Washington, DC
    Hm, so I wonder if they've changed the 2005 so you can't disable the seatbelt beeper. The reverse beeper disable worked for me no problem, first try. But when I tried the seatbelt version, when I unbuckled the seat belt I got the "b-on/b-off" thing again for the reverse beeper. I tried it a couple of more times, and still same result. Or perhaps I'm doing something wrong? Not a big deal because I always wear my seatbelt and it doesn't beep for very long if I don't buckle it right away for some reason.
  14. Benevento
    Benevento New Member
    26
    Traverse City, MI
    I've had the same experience as Betshsu on my 2005 Prius. I turned off the reverse beep, no problem, but the seatbelt still beeps. However, I've only had the car for about 48 hours, so I'm not 100% sure what's "normal." The seatbelt only beeps 3 times now, and I think it used to go into hysterics with an increasing frequency of beeping. So maybe I did fix it.
    Also, does anyone know how to get rid of the "snowflake" in the display? I live in Northern Michigan, and it doesn't come as a surprise to us that it's cold out.
    PS: I love Betshsu's tag line!
  15. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    And here I wasn't going to say anything because I figured I was doing something wrong.
    I easily turn off the reverse beep, but the seatbelt beeps everytime. Even when I fasten the seatbelt before powering the car, I get one long beep. Yeah, I know that there's a reason for the seatbelt beep, but as long as I've been driving I've been wearing seatbelts. It's not going to change just because Priapus doesn't beep at me.
    Interesting thing is that I have an '04, not an '05. I spent this past weekend trying all I could think of to defeat the push-button beeps but with no success. yet.
  16. betshsu
    betshsu Member
    302
    Washington, DC
    I too don't recall what the seatbelt beeping was like before I attempted to turn it off. It might have been more frantic than it is now.
    I don't think you can get rid of the snowflake, it's just a permanent reminder that your mileage may suffer due to the cold (though people have suggested taping something over it so you don'thave to see it). I don't know where it appears, since I have yet to experience the snowflake (and wonder if I ever will, living in Texas. when I think it's cold out, the car doesn't seem to think so).
    Thanks! Though ironically, I've never had a baby, nor delivered one like some people in this forum. It seemed appropriate though :D.
    I haven't noticed the long beep (and I usually fasten my belt before starting the car). But I am oblivious to beeps, as I didn't realized the touchscreen beeped until I read someone complaining about it here (but of course now I noticed it all the time). Curses to whomever started that thread! :D
  17. TonyPSchaefer
    14,816
    2,500
    66
    . . .and now, dear betshsu, you will notice the seatbelt beep every time you start your car. And it serves you right for displaying a picture of my cat, Nina. Who, by the way, you can see a picture of in my album. She's very well traveled and likes to scratch just about everything. (link under signature)
  18. betshsu
    betshsu Member
    302
    Washington, DC
    Clearly Tony, I kidnapped Nina and forced her to sit in a sink for my avatar picture to taunt you. That's just how devious I am :D.
    Nina does look incredibly like Noel (the cat in the sink), particularly the picture of her curled up under the Christmas tree. The picture with the duck is too cute!
  19. mkapor
    mkapor New Member
    The reverse beep is, of course, truly annoying. I have made at least half a dozen attempts to eliminate following the directions above and have been unsuccessful in getting the "b on/b off" to appear. After I shift into R and pack to P and then let get of the Trip/ODO button it always displays "Trip A" (as it does under normal operation).
    I have a 2005 U.S. Prius. No one is sitting in the pasenger seat. I am careful to hold the Trip/ODO button for at least 10 seconds (long enough that the gas engine starts).
    I throw myself on the mercy of the experts here in asking for help.
  20. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    The shift back to P thing is what usually throws people. That actually means to push the "Park" button, not just letting the shifter return to center....are you doing that?
