First Drive: 2008 Ford Escape and Escape Hybrid
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Apr 19, 2007.
  1. Tideland Prius
    16,556
    Another option is the Escape Hybrid (starting at $31,499 with FWD). Its combination of continuously variable transmission (CVT), electric motor and gasoline engine delivers a combined 155 hp, and can considerably lower fuel consumption, especially in city driving. However, all Escapes will return excellent mileage for this class of vehicle if you use a light foot when driving them.
    Inside, the fabric surfaces are made from 100 percent recycled materials, which Ford believes to be an industry-first. The company that supplies the fabrics, Interface Fabrics Inc., estimates that Ford's use of these materials will conserve approximately 2.5 million litres of water, almost a million kilograms of carbon dioxide equivalents, and seven million kilowatt hours of electricity annually. The entire vehicle is about 85% recyclable.
    Full Article
  2. Arroyo
    Arroyo Member
    217
    45
    Los Angeles area
  3. Tideland Prius
    16,556
    The FEH's EV mode feels stronger. You can accelerate harder in EV than the Prius (w/out EV mod). I hope the quality of plastics have improved.
  4. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    I test drove the '08 Mercury Mariner hybrid ... felt really heavy ... it is nicely redesigned over last year's model though. The back seats seemed a little flat (no contour). I did get about 30 mpg on my 8 mile drive with a little interstate driving in there. One nice thing was 6 months of Sirius radio ... stereo was really nice as well. I believe the sticker was $32,700 (loaded). It had an economy button that you can engage which will disengage the A/C at stops so the engine can shut off (since it's completely tied to the ICE).
  5. Tideland Prius
    16,556
    <div class='quotetop'>QUOTE(Husker4theSpurs @ Apr 19 2007, 03:10 PM) [snapback]426331[/snapback]</div>
    How's that different from "A/C" and "MAX A/C" on the Classic Prius? (MAX A/C keeps the engine running with cold air blowing, regular A/C shuts off the engine and A/C).
    Also it seems they didn't upgrade their hybrid system with this new vehicle.
  6. Husker4theSpurs
    656
    128
    Papillion, Nebraska
    I believe the sticker said 29 city, 27 hwy ... revised '08 sticker fuel economy. This was an AWD version.
  7. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 19 2007, 03:13 PM) [snapback]426334[/snapback]</div>
    Are you sure regular AC shuts down when the engine turns off? I don't think that's the case because when I've been stopped for a long time in the sun the big battery will run into the purple running the AC and then the engine kicks on to do a recharge. I don't remember being on MAX A/C in this situation.
  8. acdii
    acdii Active Member
    1,124
    131
    <div class='quotetop'>QUOTE(San_Carlos_Jeff @ Apr 19 2007, 05:39 PM) [snapback]426353[/snapback]</div>
    I believe on the Ford the A/C compressor runs off the ICE, the Prius has an electric Compressor, one of the first things I noticed when I looked under the hood. The battery drives the AC on the prius, thats why the engine can shut off, if I am correct with the Ford using conventional AC compressor, that would be the reason the engine runs at a light.
  9. Tideland Prius
    16,556
    <div class='quotetop'>QUOTE(San_Carlos_Jeff @ Apr 19 2007, 03:39 PM) [snapback]426353[/snapback]</div>
    How's that different from "A/C" and "MAX A/C" on the Classic Prius ?
    You skipped over the most important bit of my post :)
  10. acdii
    acdii Active Member
    1,124
    131
    How many here know the difference between the two? I do, but not going to say until others respond.
  11. Tideland Prius
    16,556
    <div class='quotetop'>QUOTE(ACD @ Apr 20 2007, 11:26 AM) [snapback]426883[/snapback]</div>
    the two what? cars or A/C system?
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 20 2007, 05:15 PM) [snapback]427077[/snapback]</div>
    me thinks he is referring to "classic"
  13. dipper
    dipper Senior Member
    1,242
    252
    <div class='quotetop'>QUOTE(Husker4theSpurs @ Apr 19 2007, 03:17 PM) [snapback]426337[/snapback]</div>
    Wow.... Toyota must be doing something right since the 2008 THH is bigger and more HP.... still get more MPG
  14. Tideland Prius
    16,556
    <div class='quotetop'>QUOTE(dipper @ Apr 21 2007, 11:29 AM) [snapback]427364[/snapback]</div>
    2 extra hp.
  15. Frank Hudon
    Frank Hudon Senior Member
    4,147
    on the Classic the ICE cycles off and on with the A/C compressor. Unless it's on Max Air, just like Jon said. I'll say it again Toyota should have used the compressor that the HAH uses, electric and belt driven, so if the ICE is running it drives the compressor when needed and when in stealth it's powered by the Hybrid battery. No sense converting gas to electric to drive the compressor when the ICE is running and burning gas. Yes I know it's a variable speed compressor but so is a belt driven one, it just cycles on and off more often.
  16. Husker4theSpurs
    656
    128
    Papillion, Nebraska
    <div class='quotetop'>QUOTE(dipper @ Apr 21 2007, 01:29 PM) [snapback]427364[/snapback]</div>
    I would imagine the '08 Highlander Hybrid will have LOWER listed fuel economies. The Escape and Mariner currently out are '08 early models and the new process for determining fuel economy is in effect for ALL '08 vehicles. The Escape and Mariner had higher sticker fuel economies than the Highlander Hybrid for the '07 model.
  17. Tideland Prius
    16,556
    <div class='quotetop'>QUOTE(Husker4theSpurs @ Apr 22 2007, 05:44 PM) [snapback]428025[/snapback]</div>
    Nope. It has identical mpg (under new EPA) which means it increased a bit (if we used the old EPA).
  18. Husker4theSpurs
    656
    128
    Papillion, Nebraska
    How do we know if they aren't out yet? The only thing I've seen is that they've said that it (the '08 Highlander) won't have any reduction in FE vs the '07 version.
    It appears under the new testing procedures the '07 Highlander is rated at 27 city, 25 highway.
  19. Tideland Prius
    16,556
    Aren't they estimates? (the 08 I mean).
    The new HiHy will be heavier even though the 3.5 litre is lighter than the 3.3 litre.
  20. Husker4theSpurs
    656
    128
    Papillion, Nebraska
    They are, but the only thing we heard for sure is that the FE of the '08 won't be worse than the '07 ... Highlander Hybrid that is.
    I would imagine the Ford and Mercury will be higher in economy, but I still wouldn't get one ... significantly smaller than the Highlander Hybrid/400h
