Mr. Clean Autodry really really works!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by richard schumacher, Sep 27, 2004.
  1. richard schumacher
    7,663
    1,038
    United States
    Yes, it's as good as they claim: it left an utterly spotless finish as shiny as a new wax job. It feels hard and frictiony in contrast to the velvety feel of wax (no, it does not strip the existing wax). No more chamoising for me.
    Beware buying a box that does not contain an owner's manual, or if you do, review the .pdf manual from http://www.homemadesimple.com/mrcleanautodry/ before first use.
  2. jamarimutt
    jamarimutt New Member
    985
    I have not yet seen this product in stores. What is the approximate cost per wash?
    Water accumulates under the hood, hatch, and behind the doors. These areas still have to be hand-dried.
  3. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    I have been using the (high) pressure brushless car washes since they first became available. That was because I noticed "swirl like" scratches developing either from my hand washing or brush-type car washes. Expensive but effortless. I had wash the wheels.
    I would like to try the Autodry system but since there is still dirt on the surface at the stage you use the sponge or mitt does this not just continue to scratch the original pristine surface/wax and leave these swirls?
  4. richard schumacher
    7,663
    1,038
    United States
    <div class='quotetop'>QUOTE(jamarimutt\";p=\"41944)</div>
    $US20 for the starter kit, good for about 3 washes. Soap and rinse water filter (demineralizer and de-ionizer) refills are, uhh, $5? each and should give about 10 washes.
    Yes, if the final rinse water doesn't get there, and if one cares about spots in those areas. Even so it's much less hand drying to be done.
  5. richard schumacher
    7,663
    1,038
    United States
    <div class='quotetop'>QUOTE(Canuck\";p=\"41949)</div>
    As before I use an all-cotton wash mitt and pre-rinse the car thoroughly before washing to soften the dirt. No scrubbing; let the soap do the work. After each use the mitt gets pressure rinsed from the inside, and if it remains visibly dirty I launder it before the next use. No swirls so far after five washes (four without and one with Autodry).
  6. Dion
    Dion New Member
    128
    Jersey City, NJ
    I use the Mr. Clean Autodry system every week. There's nothing better. The soap really cleans the car well. Everyone should try this. It's so easy to wash your car. No buckets. I just use the device and a microfiber towel. That's all you need for a perfect shine.
  7. jamarimutt
    985
    What is the approximate cost per wash? Apparently Richard tried to answer this question but I don't see the reply.
  8. Saruman
    Saruman New Member
    I really like the high pressure touchless washes too... They really do a great job. With advanced multiple wash purchase card, they work out to about $3 per wash... much less than Mr. Clean - which works very well but costs too much per wash, IMHO, and still reqquires the hose wrestling etc.
    I use a wool mitt and a big bucket of warm sudy water to hand wash once a month or so to get all the bugs off. I launder it between uses and ALWAYS RINSE THE CAR VERY WELL BEFORE TOUCHING IT to prevent picking up and swirling grit. Rinse the mitt after every wipe in the bucket so sand goes to the bottom. No swirlies after 4 washes
  9. DaveG
    DaveG Member
    806
    Vancouver, BC
    A few wash tips I picked up a while ago when I first got my Prius in January:
    -Always pre-rinse the car. This will eliminate a lot of the loose debris that can scratch your paint.
    -Wash from the top down and shake out the cloth/mitt in the wash bucket after every few strokes. Some people use a different cloth/mitt for different areas of the car if the car gets dirty quickly.
    -Do not let the soap dry on the car! If you find that the soap is drying before you finish washing, do half the car (or less, depending on your climate), then rinse that portion before proceeding to the next area.
    -When washing, use left/right or forward/backward strokes. Circular strokes are the absolute worst because any scratches will "swirl" and will show from any angle you view the car from. At least if there are minor scratches when you go left/right or forward/back, you'll need to be at a very precise angle to see the scratches
    -When you've finished washing and rinsing, take the nozzle off of the hose, and use a low-pressure flow of water to "rinse" the small water droplets off so they bead together and flow off the car. This will help the drying time tremendously if you're using a shammy/chamois!
    I always wipe down the black portions of the car with a cotton towel to make sure I don't get any water spots.
    My car still looks as good as the day I picked it up, aside from a few miniscule chips on the front bumper from rocks and the back bumper where someone very slightly scraped me.
    Dave.
  10. Dion
    Dion New Member
    128
    Jersey City, NJ
    After the initial investment of $20 for the device. The per wash cost is about one dollar. You get 10 washes per filter and soap refill that cost $5 each. I purchased my Mr. clean autodry on sale for $16. Comes with starter kit for three washes. I think I got 4 or 5 washes out of the start kit. If you pay 26K for the car, you can pay $20 for something to keep the car clean.
  11. Canuck
    Canuck Member
    605
    And on the other hand you may not have enough $$ left. ;)
  12. richard schumacher
    7,663
    1,038
    United States
    Refresh your browser, or try another browser. I can read that reply using Mozilla 1.2 and Netscape 7.1, but both of them have trouble scrolling past replies that contain quoted material.
    Anyway: US$20 for the starter kit (about three washes), and about US$1 total per wash thereafter.
  13. rocketman7
    rocketman7 Junior Member
    73
    Central Coast California
    I haven't been as successful with the Autodry. It still leaves spots on the car. I've tried making sure that I get all of the 'normal' water replaced by the 'ionized' water but I still get spots. Anyone else have this problem?
  14. outoftown
    outoftown Member
    125
    66
    Cary, NC
    You can get a $3 off coupon by going to http://www.homemadesimple.com/mrcleanautod...ry/coupon.shtml
    You can also download the manual as a pdf file.
    I'm still waiting for my coupon to be sent to me. Testament from a friend with a new BMW 330 sold me on trying it, plus the used chamois I had left ugly greasy streaks on the first wash.
    Bill
    04 Black BC "HIGHBRED"
    04 White BC
  15. kjb516
    kjb516 New Member
    104
    Troutdale, OR
    Also having a black Prius, I have experienced minor spotting even with the Autodry product (though it does help a lot).
    I have been able to get around this by waiting a few minutes after rinsing with ionized water for the larger sections of the car to dry, and then hand drying the remaining wet spots. Though I still have to hand dry, it is much less work (and nearly spotless) than without this product.
  16. richard schumacher
    7,663
    1,038
    United States
    Uhh, good point. Any remaining spots would be more conspicuous on black than on silver.
    Stupid questions (don't be offended!): you're certain that the filter is not exhausted and not plugged in backwards? (There's a plug and socket thingy to discourage that, but it could be defeated...) And you haven't swapped the "rinse" and "de-ionized" settings?
  17. Brian
    Brian Member
    480
    Bakersfield
    I really like it too. I have been using it since May. It does wounders. Saves my back like crazy, because I don't need to dry it. :)
  18. richard schumacher
    7,663
    1,038
    United States
    One more point is that they don't claim good results unless you use their special soap. Resist the urge to refill the unit with other soaps you may already have on hand.
  19. rocketman7
    73
    I thought that maybe the original 'starter' filter may be the culprit so I purchased a new 'about 10 washes' filter and have used it three times with spotting every time (and it is installed correctly). And no, :lol: I haven't swapped the dial settings (you forgot to ask if I connected the garden hose to the Autodry and turned on the water :wink: ).
    On another problem, I've noticed that it uses quite a bit of soap solution and if you accidently store it on the fill side the soap will leak out of the soft fill cover.
  20. richard schumacher
    7,663
    1,038
    United States
    Drat. Sorry, man.
