Extending Range - Adding Aux Fuel Tank
Discussion in 'Gen 2 Prius Technical Discussion' started by faith2walk, Apr 21, 2007.
  1. faith2walk
    faith2walk Upgraded again
    154
    Alpena, MI
    A little background...I work for UPS Logistics and drive 75K+ per year (some years 120K). I drive the prius cause it gets me the best MPG. Since most of my driving is freeway (65mph to give me the best compromise), I normally get about 50mpg AVG during the summer and 43mpg AVG during the winter. Based on how cold/hot it is, I usually get 300-500 miles per tank (winter-summer flex).
    I sometimes drive upwords of 1100 miles nearly consecutively, and would love to extend my range between fillups, especially when some of the areas I have to go through are quite remote (40 miles with no services, 60 miles no rest areas, and gas prices through the roof, it must be a rare commodity in some of those outlying areas).
    What would it take?
    Could it be gravity fed/inline?
    I keep a fullsize spare, so could it be made to fit in the now useless trunk space where the "dumby" spare was?
    Know any sources for tanks about that size?
    What about ventilation and filler cap placement?
    Lots of questions, just looking for feasibility
  2. bwilson4web
    16,012
    <div class='quotetop'>QUOTE(faith2walk @ Apr 21 2007, 09:58 PM) [snapback]427582[/snapback]</div>
    You should be doing a little better. What sort of trip distances? Do you carry much in the back?
    There are some pretty impressive, metal fuel cans available. If you could strap it somewhere so it won't risk tipping, spilling or solar heating, carry the can?
    A second option is to get a receiver hitch and carry the gas can on one of those oversize platforms. This has the advantage of getting the attention of a tailgater. Heck, you might even add a few lights to make sure they see the 'horribly explosive' gasoline can even at night. <grins>
    I'm not sure a can in the spare tire well makes a lot of sense. As you've already realized, there would be plumbing and access issues.
    GOOD LUCK!
  3. faith2walk
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(bwilson4web @ Apr 22 2007, 12:16 AM) [snapback]427634[/snapback]</div>
    Most of my distances keep me within a 5 state region, but round trips can be a bear...I AVG 2000 miles per week, almost all of it freeway miles.
    The low mileage does have something to do with the upgraded tires (lost 3-4 MPG) and about 200lbs of gear in the back (overnight bag, emergency tool kit, full size spare tire, first aid kit, large box of misc fluids, hand cart for specialty trips, portable refrigerator-I pack my own meals so I don't have to stop, etc.). Also MI has lots of wind, and huge temperature variances from summer to winter, and as much as 45 degrees difference in a day, especially if I have to travel the Upper Peninsula. Although there isn't any huge mountain ranges, a simple trip from GRR to DTW (roundtrip of 270 miles) has lots of rolling hills (gps shows 150ft elevation gains) and on any given day directional winds (20+mph) that will give you 55+ mpg one way and 41- mpg the other, for an avg of about 48-52 mpg (assuming 60-80 degree weather).
    On average I do that sort of trip 5-9 times per week, depending on the clients that I need to meet and the weather. About 15% is city driving, but not enough to bring my averages up. I have researched this site quite thoroughly, and have even spent a whole week just learning the in's and out's of this car (got nearly 111 mpg on one 200 mile trip learning to P&G).
  4. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    <div class='quotetop'>QUOTE(faith2walk @ Apr 21 2007, 11:56 PM) [snapback]427658[/snapback]</div>
    Feasible?
    Probably.
    You would just have to maintain vacuum.
    Another bladder hooked up, maybe???
    Dangerous?
    e^(lot more than probably).
    Unless you encased it in steel.
    And wore a fire suit.
  5. 8AA
    8AA Active Member
    550
    62
    Maryland
    Keep in mind that you'll also take a MPG hit for the added weight of carrying the extra gas.
  6. daniel
    14,487
    1,519
    Spokane, WA
    The problem you face is that the gas tank contains a flexible bladder whose purpose is to prevent evaporation, thus reducing pollution. Tapping into that would be problematic. The easiest thing would be to carry a spare gas can, as bwilson suggests, but that raises safety issues. Do you really want gasoline all over the place if you are rear-ended? Do you want gas fumes inside the car from a gas can inside?
    You could probably install a gas tank in the spare-tire well and have it vented to the outside, with a small hand pump to pump it into the car's tank. You'd lose the benefit of the gas bladder in the main tank, because now you'd have evaporative emissions. And you'd have to deal with the gas-soaked hose you'd use to pump from the spare tank to the car's tank, unless you installed permanent plumbing between them with a sealed valve. All in all, I think it's not practical.
    Personally, while I think you could extend your range, I also think you're better off just to stop every 300 to 500 miles to fill up at a gas station.
    And BTW, I used to live in North Dakota, so I know what you're talking about regarding the temperature extremes and the winds. I think your numbers sound about right to me.
  7. bwilson4web
    16,012
    I'd like to suggest an engine tachometer (not trivial for a Prius) and drive within some rpm limits. Several of us have found staying below 3,200 rpm helps a lot and it is even better if you can stay under 2,400 rpm. These limits are possible even for most highway driving while still maintaining good cross country speed.
    Not to 'toot my own horn,' but I've been collecting 'lessons learned' in a FAQ. Mostly 'low hanging fruit,' not a bad place to double check.
  8. faith2walk
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(8AA @ Apr 22 2007, 09:16 AM) [snapback]427723[/snapback]</div>
    True, but adding another 120 pounds won't hit much more than the couple hundred I already have.
    <div class='quotetop'>QUOTE(bwilson4web @ Apr 22 2007, 11:25 AM) [snapback]427764[/snapback]</div>
    I have never hooked up a tach before...is there a feed for it on the prius? Where would I pick up a good one? Digital would look better on the already techy prius, but is that an option without installing canview or scangauge?
  9. alexstarfire
    alexstarfire New Member
    220
    Not to sound like a know-it-all, but he could make his own gas bladder out of some rubber, probably best to find some round rubber one online, possibly incase it in a medal box, and then just tap into the gas line on the Prius. I'm talking about the line to the tank, not the one to the engine. You'd need a valve, so you don't ruin the Prius's gas tank, that could be triggered via a button from the drivers seat. There would be lots of work involved and a voiding of any warranty on the car.
    All in all it's not worth it just so you don't have to fill up as often.
    Didn't even mention that the spare tank won't have all the safety features of the original tank. So something bad could happen and you wouldn't even know.
  10. faith2walk
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(Alexstarfire @ Apr 22 2007, 12:12 PM) [snapback]427786[/snapback]</div>
    I am about convinced it is not worth my time, but what about using something like this...it already has a sending unit and would only need the switch and an exterior fill spout.
    http://www.iboats.com/Tempo_TP12L_11_Gallo...--view_id.40329
  11. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    I used to have a van with a second add-on fuel tank. There was a switch on the dash so you could choose between them. I believe that each one had its own pump and what you were doing was deciding which one got power. I think each one had its own gauge too. You may need a second fill pipe also. You would need a "Y" fitting so either one could send gas to the engine. What I see as being the hard part is finding a place on the outside of the vehicle where there is physically room to place a tank. I wouldn't be wild about having a tank inside the car, even in the trunk.
  12. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Is your employer reimbursing your fuel costs?
    If so, then perhaps you should re-think your use of the Prius and consider a different vehicle. You already carry 120lbs of stuff, which is almost equivalent to another person.
    The Prius fuel tank just isn't designed for long-range driving like you do, and changing it is a huge job.
    PS: Your auto insurance company will hate anything that changes the factory security of the fuel system, and you may fail state pollution requirements.
  13. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    <div class='quotetop'>QUOTE(faith2walk @ Apr 21 2007, 07:58 PM) [snapback]427582[/snapback]</div>
    Not a good idea. <_<
    Safety , polution & warranty issues. Suggest planning ahead and fill up as soon as you get to a gas station.
    Any mod in the fuel system is at best a risky undertaking.
  14. daniel
    14,487
    1,519
    Spokane, WA
    Actually, when I take a road trip I need to stop to use the rest room more often than I need gas. Figuring 8 usable gallons per fill-up, at highway driving, that's about 400 miles. And at 65 mph that's 6 hours of driving. I certainly cannot drive for 6 hours without a pit stop. Even at 75 mph, that's 4 1/2 hours of driving at 42 mpg.
    I generally average two to three pit stops per fill-up. At the very least, I need to stand up and walk around for 5 minutes after 2 or 3 hours of driving!
    srellim234 likes this.
  15. Per
    Per New Member
    232
    San Antonio
    Any chance of swapping out the standard gas tank with the European version that does not have the bladder? The tank is supposed to hold 12 gallons, but it seems noone can get anywhere close to that much in their tank. There is no requirement for the bladder anyway--I believe the Prius is the only car that has it.
  16. TheAnnoyingOne
    318
    <div class='quotetop'>QUOTE(Per @ Apr 23 2007, 08:24 AM) [snapback]428337[/snapback]</div>
    The US PRIUS has the bladder and associated tank components to improve the gas vapor handling. As Daniel said, driver’s bladder needs “servicing†much more often than the PRIUS.
  17. hill
    8,640
    We've driven on more than a couple occasions from our southern CA home to our MT home (1,250 miles) and we only have to stop 2X for gas. Getting between 500 - 600 miles per tank allows us to pick a station any where within a 100 miles, easily. So where's the need for more gallons?
  18. Earthling
    Earthling New Member
    441
    Somewhere, NY
    <div class='quotetop'>QUOTE(hill @ Apr 23 2007, 12:35 PM) [snapback]428399[/snapback]</div>
    My thoughts exactly.
    After an hour or so on the road, I'm looking to stop to get out and walk around, take care of business, etc. The range on a Prius gas tank has to be one of the best available, and to me, there are plenty of reasons to stop before the gas gets low. I'd probably do 2 rest stops to every gas stop, if not more.
    Harry
  19. faith2walk
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(daniel @ Apr 23 2007, 11:08 AM) [snapback]428324[/snapback]</div>
    The issue isn't rest areas, but gas and stations, i.e. going in progression -battle creek, traverse city, sault st. marie, goodrich, battle creek (all MI) in the winter takes 3 tanks of fuel, and in the summer (without any major head winds) takes 2 tanks. The gas prices right now range from 2.62 to 3.12 for the cheapest fuel in those locations.
    The rest areas are generally about 40 miles apart but can range anywhere from 27-76 miles. If you park at the farthest parking space from the rest room it allows you to get some exercise, but they don't sell gas at such convenient locations, and if they did it sure wouldn't be as cheap.
    I realize from this discussion that it would likely take more time and money than it's worth...and that was the purpose of this discussion. I needed to tap other minds to help understand the logistics of trying to make it happen. As inconvenient as it may be, at times, the prius just won't be as easy to add an auxillary fuel tank as a dodge 2500.
    Thanx for your posts, information, and opinions.
  20. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
