External MPG display
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Bruski, Apr 29, 2007.
  1. Bruski
    Bruski New Member
    I'd like to find a remote or externial MPG display for my rear window. I'll bet someone can hack the computer and get the real time MPG numbers from the consumption screen. The we make a low profile display for the rear window on the driver's side. As they pass they see the numbers best.
    Bruski
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I can't tell you the number of times I've thought about that. Something in the corner of the lower window saying "real-time mileage: nn".
  3. brick
    brick Active Member
    1,083
    79
    Upstate NY
    When I went to visit Mike Dabrowski a month or so ago (he's the guy with the very tricked-out Insight, and who has plans to use a modified Prius transaxle to create an Insight EV) I found out that he had done this but had to take it down. Apparently some law enforcement officer somewhere took exception to it on the grounds that it was distracting or something. All I'm saying is check local laws first.
  4. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(Bruski @ Apr 29 2007, 09:03 AM) [snapback]432071[/snapback]</div>
    The easiest way would be to buy an OBD2 unit that can display the MPG (this puts a lower cost unit at risk). Then tap into it to drive a large rear display. You could ask the engineers at "ScanGuage" or the developer of the "CANview" about an external display feature.
    JeffD
  5. qbee42
    3,079
    You don't have to hack the computer. The information is available from the CAN bus.
  6. avdavsim
    avdavsim New Member
    24
    <div class='quotetop'>QUOTE(qbee42 @ Apr 29 2007, 09:52 PM) [snapback]432321[/snapback]</div>
    If this thing does get produced, instead of 99.9 MPG, it should read >100 MPG or "Infinity" just so someone following you doesn't think that you are actually getting exactly 99.9.
    We Prius owners know what 99.9 really means, but I don't think we can count on everyone else knowing that.
  7. NoMoShocks
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(avdavsim @ Apr 30 2007, 11:27 AM) [snapback]432657[/snapback]</div>
    I am looking forward to when Toyota feels the need to add another diget to the display. Hopefully a full digit, not a half digit that can only display a 1. This will obviously be needed for the 100+ MPG Prius which will be had by all current owners with a free battery pack upgrade and firmware update.
  8. Rest
    Rest Active Member
    1,210
    CA
    When my Prius Display shows 99.9mpg, my scangauge2 shows 9999.99mpg when the engine is off. But other times when the engine is still running only at idle the SG2 might show numbers like 120mpg. The SG2 provides me with higher limits than the Prius display.
  9. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Taking the OP's suggestion a step further: How 'bout the external display being user-programmable with text capabilities: "Get off my a**."
  10. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(qbee42 @ Apr 30 2007, 11:52 AM) [snapback]432321[/snapback]</div>
    The CAN message does not have a direct MPG number.
    You have to do complex math to get the MPG number.
    <div class='quotetop'>QUOTE(Rest @ May 2 2007, 03:13 PM) [snapback]433784[/snapback]</div>
    The ScanGause tells us a truth, 9999.99 mpg when the engine is off at below 42 mph.
    But, it tells us a lie, 120 mpg when the engine is fuel-cut mode at above 42 mph.
    Ken@Japan
  11. Hobbs
    Hobbs New Member
    Glasgow, UK
    This remainds me of the NASA pen USSR pencil thing.
    Why not write your MPG on a bit of paper and Bluetac it on to the window. A good time to do this is just before you fill up.
  12. tochatihu
    tochatihu Senior Member
    9,670
    3,731
    Kunming Yunnan China
    2001 Prius
  13. JimboK
    2,817
    188
    49
    Chesterfield, VA
  14. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
  15. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I did something similar when I had an Insight:
    [​IMG][​IMG]
    It was very basic, I found some very large 7-segment displays, I connected both displays to ground and I attached a 12V lead to each segment I wanted illuminated to create numbers. It was very primitive in terms of electronics, but it worked (until segments began to burn out because I didn't use any resistors... d'oh!).
