So, does your Prius need a power boost?
Discussion in 'Fred's House of Pancakes' started by ozyran, Apr 28, 2007.
  1. ozyran
    ozyran New Member
    695
    Clicky cicky!
  2. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
  3. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(ozyran @ Apr 28 2007, 07:01 PM) [snapback]431921[/snapback]</div>
    Okay. I give up. What's it supposed to do?
  4. iaowings
    iaowings New Member
    450
    The power band which refers to the range of operating speeds under which the engine is able to operate efficiently. A typical gasoline automotive engine is capable of operating at a speed of between around 750 and 6000 RPM, but the engine's power band would be more limited. The engine would typically not generate maximum torque until higher operating speeds of perhaps 2500 RPM, after such, the torque drops off. The peak power (horsepower) might be closer to 5000 RPM. Such an engine would be said to have a "power band" of 2500-5000 RPM (another example would be from torque peak to redline: 2500-6000 RPM).
    A more precise definition of the power band: the rpm range where an engine makes at least 75% of its maximum torque.[citation needed]
    This can be applied to any engine and establishes a reliable quantification of the above notion "the engine is able to operate efficiently".
    Power band considerations with a CVT vehicle
    Because a CVT vehicle has the capability of keeping RPMs within the crest of the power band under acceleration, a peaky engine is optimal. Under full acceleration 100% of the available power can be extracted at all times. There is no shifting, and no moving out of the power band. This type of transmission is more efficient than others due to power band issues mentioned previously, but is not favored by many due to the lack of apparent power. Drivers are accustomed to the sudden lurch off the line and the shifting of the transmission. Though these are only actions of less efficient transmission, some vehicle manufacturers have computerized such events in to the transmission to add to the perception of power and torque.
  5. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(daniel @ Apr 28 2007, 07:47 PM) [snapback]431939[/snapback]</div>
    Pssst.... notice the "Blinker fluid" and "seasonal tire air" for sale as well. It is still April....
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Are those punk wheel-well inserts, or something? Or do you just
    clip them around your "ohshit" bars?
    _H*
  7. jewelerdave
    jewelerdave New Member
    77
    Well they have blinker fluid...but what about my low headlight fluid???
    Its nice to find a source of good muffler bearings. I got a guy drive 70 miles once to get replacement muffler bearings cause locally they were "out of stock"
  8. tochatihu
    tochatihu Senior Member
    9,762
    3,761
    Kunming Yunnan China
    2001 Prius
    Kale also offers radiator insulators, which won't seem so odd to some Prius drivers.
  9. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(darelldd @ Apr 28 2007, 08:45 PM) [snapback]431961[/snapback]</div>
    Okay. :D Since I read it as a scam rather than a joke, I didn't even connect "blinker fluid" with turn-signal blinkers.
    So the "power bands" and "torque bands" pictured on the site are just a silly pun on the mathematical power bands and torque bands IAO explains in the above post.
    I get it.
  10. iaowings
    iaowings New Member
    450
    <div class='quotetop'>QUOTE(daniel @ Apr 29 2007, 10:07 AM) [snapback]432081[/snapback]</div>
    Lol I thought you were asking about an engines power band more than about the joke power band for sale. It was late and I had just taken a sleeping pill about 30 min beofe that so I was a little off, actually I was mostly off at that time.
  11. ozyran
    ozyran New Member
    695
    I found a great way for the ICE to have clean oil at every change!
    Alas, I made the mistake of not buying the blinker fluid in time - now my blinkers are running two ticks two slow. I did, however, get a great deal on those cans of seasonal tire air!
