Conceptual problems
Discussion in 'Fred's House of Pancakes' started by eagle33199, May 1, 2007.
  1. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I rather enjoyed the recent physics questions we had here... and as luck would have it, my mom just sent me a long list of conceptual math problems that she wants to use for some sort of party (teachers... go figure)... The only problem is, i can only figure out about 3/4 of them for her.
    So i figure i'll post one, you guys can figure it out, then i'll post another, etc... Of course, anyone can post the conceptual problems, i just happen to have a nice long list here :)
    Here's the first one:
    Bridge Over Troubled Students:
    There are 4 men who want to cross a bridge. They all begin on the
    same side. You have 17 minutes to get all of them across to the other
    side. It is night. There is one flashlight. A maximum of two people
    can cross at one time. Any party who crosses, either 1 or 2 people,
    must have the flashlight with them. The flashlight must be walked
    back and forth, it cannot be thrown, etc. Each man walks at a different
    speed. A pair must walk together at the rate of the slower man
    Man 1: 1 minute to cross
    Man 2: 2 minutes to cross
    Man 3: 5 minutes to cross
    Man 4: 10 minutes to cross
    For example if Man 1 and Man 4 walk across first, 10 Minutes have
    elapsed when they get to the other side of the bridge. If Man 4
    returns with the flashlight, a total of 20 minutes have passed, and
    you have failed the mission.
  2. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    <div class='quotetop'>QUOTE(eagle33199 @ May 1 2007, 09:32 AM) [snapback]433163[/snapback]</div>
    Here's the order:
    1. Man 1 & Man 2 cross. (Time: 2 Minutes)
    2. Man 1 back across. (Time: 1 Minute)
    3. Man 3 & Man 4 cross. (Time: 10 Minutes)
    4. Man 2 back across. (Time: 2 Minutes)
    5. Man 1 & Man 2 cross. (Time: 2 Minutes)
    Total time: 17 Minutes
    What do I win? :)
  3. eagle33199
    5,122
    268
    2015 Prius v wagon
    The next question!
    I am an honest person, and am thinking of one of three numbers: 1, 2 or 3. You may ask me EXACTLY one yes-no question, I will answer truthfully, and if you chose the right question, you will know which number I'm thinking of! (HINT: if I cannot answer your question, I will say I cannot answer it).
  4. tleonhar
    tleonhar Senior Member
    1,541
    34
    Belle Plaine, MN
    <div class='quotetop'>QUOTE(eagle33199 @ May 1 2007, 09:17 AM) [snapback]433188[/snapback]</div>
    Is the number you are thinking of => 2?
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(tleonhar @ May 1 2007, 02:22 PM) [snapback]433407[/snapback]</div>
    Then it could be 2 or 3 if he answered "yes"
  6. jeneric
    jeneric New Member
    442
    Redmond, WA
    Do you have to cut a whole pie to separate it into one fewer pieces than your number?
  7. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    <div class='quotetop'>QUOTE(jeneric @ May 1 2007, 02:17 PM) [snapback]433487[/snapback]</div>
    Wouldn't the answer to this be "no" for numbers of both 1 and 2?
  8. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    <div class='quotetop'>QUOTE(eagle33199 @ May 1 2007, 07:17 AM) [snapback]433188[/snapback]</div>
    That hint is what makes the puzzle possible at all, else it's irresolvable - you can't get 3 outcomes from a binary input. So the question must be framed such that a yes-no response is impossible for one of the numbers. Something along the lines of "This is a False statement" must be incorporated. The best I can do so far is something like:
    If you are not thinking of 2, you will say Yes if I ask are you thinking of 3.
    Now, that's a statement, not a question, but you either affirm it, deny it, or can neither confirm nor deny it, so I hope it qualifies.
    If you're thinking of 1, the first clause is true, and you won't say yes to 3, so you say NO.
    If you're thinking of 3, the first clause is still true, and you'll be truthful about 3, so you say YES.
    If you're thinking of 2, the first clause is false, rendering the rest of the statement moot, so it can't be confirmed or denied, and you'll say you can't answer.
    I'm not 100% convinced I've framed the question absolutely correctly, but that's the gist.
    Mark Baird
    Alameda CA
  9. jeneric
    jeneric New Member
    442
    Redmond, WA
    <div class='quotetop'>QUOTE(San_Carlos_Jeff @ May 1 2007, 02:42 PM) [snapback]433506[/snapback]</div>
    I don't think so; to me that would mean you can separate it into 0 pieces without cutting it.
  10. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    How about: "Is it a prime number greater than two?"
    If yes, then it's 3.
    If no, then it's 2.
    (Assuming 1's not prime, not being divisible by one AND itself.)
  11. efusco
    19,891
    1,196
    Nixa, MO
    I'm pretty sure 1 is considered prime.
    <div class='quotetop'>QUOTE(airportkid @ May 1 2007, 04:46 PM) [snapback]433511[/snapback]</div>
    I think you're right in concept, I've heard this similar question before where you had ?3 people, one always lies, one always tells the truth, something else and you had to ask one of them a question to figure out which is the liar. This is along the same general idea.
  12. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    <div class='quotetop'>QUOTE(efusco @ May 1 2007, 06:59 PM) [snapback]433568[/snapback]</div>
    I'm not so sure. A prime number, by definition, has exactly two factors. The number 1 has only one.
  13. jeneric
    jeneric New Member
    442
    Redmond, WA
    <div class='quotetop'>QUOTE(hyo silver @ May 1 2007, 04:10 PM) [snapback]433579[/snapback]</div>
    Interesting, but 1 is not greater than 2 anyway, so the answer would still be no. It's not a prime number greater than 2, whether it's really prime or not.
  14. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    OK, I'm wrong. Never mind. :)
  15. Sufferin' Prius Envy
    3,998
    If you subtract one from the number you picked, then divide your number by that one less number, is the product an even number?
    1 - 1 = 0. You can't divide a number by zero. The person would have to say they cannot answer.
    2 - 1 = 1 so 2 / 1 = 2 (an even number) The person would answer yes.
    3 - 1 = 2 so 3 / 2 = 1.5 (an odd number) The persons would answer no.
    Three answers from one yes/no question. :D
  16. airportkid
    2,191
    538
    I've always heard primes described as a number "divisible by itself or 1."
    Now, if that counts as "two" factors, then 1 has both those factors: "itself" and "1".
    1 is most definitely a prime number, even if it isn't so hot as, say, a weekly salary in Manhattan.
    MB
  17. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    <div class='quotetop'>QUOTE(airportkid @ May 1 2007, 04:50 PM) [snapback]433593[/snapback]</div>
    WRONG.
    One is not prime. A prime number is evenly divisibly by exactly two numbers. "1" and "1" only counts as one number, so one is not prime. Sheesh.
  18. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
  19. airportkid
    2,191
    538
    <div class='quotetop'>QUOTE(priusenvy @ May 1 2007, 05:49 PM) [snapback]433617[/snapback]</div>
    I checked with Google. You guys are right, one isn't prime. It's its own category. My bad.
    MB
  20. priusenvy
    1,765
    Silicon Valley, CA
    <div class='quotetop'>QUOTE(airportkid @ May 1 2007, 02:46 PM) [snapback]433511[/snapback]</div>
    That's basically it, you have to ask a question that can only be answered yes/no/don't know.
    The most common answer is something like: "I'm thinking of either 1.5 or 2.5. Is your number greater than mine?" But it's really only limited by your imagination. The divide by zero mentioned a couple posts above is another question that works. You can even get really odd answers, like my answer the first time I heard it:
    "I have two helium balloons, each of 1.5 cubic meters in volume (about 1.5kg of lifting power). I tie 2kg of lead to one balloon. I tie (your number) kg of lead to the other, and throw them both off a five story building on a windless day. Does my balloon with 2kg of lead tied to it land before yours?" Yes - number is 1, no - number is 3, don't know - number is 2.
    Since this depends on aero drag, this only works if there is an atmosphere around your building, it wouldn't work on the moon.
