What's this Warning Light?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tatania, May 2, 2007.
  1. Tatania
    Tatania Junior Member
    35
    S. Calif
    Hello Everyone;
    I have a warning light on my dash that I cannot find any liturature on. It's a wavey line and above it is an exclamation mark with 2 brackets around it. Kind of looks like this ( ! )
    What is it? This is the first time I've seen it and it won't go off. My tire pressure is fine, my battery seems to be charging normally.
    I afraid something is about to go KaBoom and I have a long drive ahead of me today.
    Thank you!!
    -Tat
  2. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
  3. Tatania
    35
    S. Calif
    Thank you so much!
    I just had a nail removed from my rear tire and a plug put in so I might have a slow leak.
  4. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :) Hi Tatania
    Owner's Manual, pages 6 and 7 detail the 'warning lights.' It's probably a good idea to take a look to know what one means if and when it appears. There's a lot more helpful info in that manual.
  5. John in LB
    John in LB Life is good
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(Tatania @ May 2 2007, 08:05 AM) [snapback]433990[/snapback]</div>
    May not be a slow leak. It may be that your sensors have not been reset properly. See the Galaxee thread... (of course, check your tires to make sure you don't have actual low pressure.)
