Check your Cabin Air Filter Today!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, May 5, 2006.
  1. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    I made no comment on the quality of WIX or any other filter manufacturer. K&N has such a lot of advertising, they must be the best, right?
    I think you can find some interesting oil filter discussions here on PC from a couple of years ago.
  2. Charley
    Charley Junior Member
    Kerrville, TX
    <div class='quotetop'>QUOTE(Bill Merchant @ May 3 2007, 03:22 AM) [snapback]434593[/snapback]</div>
    You implied that in order to buy quality, I should buy Toyota. I just wanted to point out that there are quality filters other than OEM. According to some of the studies I found on the web yesterday, the Mobil 1 filter found at Wal Mart is one that meets or exceeds the OEM specs.
    BTW, I queried WIX about various of their filters as to where they were made. They replied that the #51394 oil filter for the Prius, et al, is still made in the Dillon, SC plant. This filter is sold by NAPA as the NAPA Gold, premium filter. The first two oil filters I bought from my Toyota dealer were made in the USA and looked like WIX premium filters.
    WIX haven't replied about the air filters yet.
    CR
  3. Bill Merchant
    4,096
    87
    <div class='quotetop'>QUOTE(Charley @ May 3 2007, 07:14 AM) [snapback]434691[/snapback]</div>
    Not to beat this horse too much more, but I was talking about buying a quality manufactured product, regardless of manufacturer. Toyota designs and manufactures good products. The products they design and have someone else manufacture, as WIX does for NAPA, are still backed by Toyota as a quality product.
    Does WIX offer that flat-pleat Toyota design of the internal filter media? Please post your filter findings.
  4. Charley
    Kerrville, TX
    <div class='quotetop'>QUOTE(Bill Merchant @ May 3 2007, 06:40 PM) [snapback]435102[/snapback]</div>
    So I pursued this a bit. Apparently Toyota bought the USA - made "Toyota" filters from Purolator, one of the original USA brand oil filters. WIX was the originator of spin-on filters. There are many surveys and studies of oil filter quality. One has only to look.
    Its all very interesting to look at. There are only a few filter manufacturers in the USA. Not many more in the world. The variation in quality is where it's at.
    CR
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    the Toyota filters that have the US stamp on them are made in the Denso factory in the US. The OEM filter is made it the Denso factory in Japan, almost all other Toyota filters are made in the Denso factory in Thiland. This topic was researched back in 2004 here on PriusChat.
  6. Charley
    Kerrville, TX
    <div class='quotetop'>QUOTE(Frank Hudon @ May 3 2007, 08:33 PM) [snapback]435166[/snapback]</div>
    I looked at all the Denso plants in the USA. None of them list oil filters as products that they manufacture.
    CR
  7. bulldog
    bulldog Member
    224
    CA
    The Prius uses the same cabin filter as can be found on many other Toyota vehicles. To be honest I have been very dissapointed in the OEM filter performance with my 4Runner (which uses the exact same filter as the Prius). My 4Runner gets operated in very dusty and sandy conditions and I found that the OEM filter allows way too much dust (and even fine sand) to come through, even on the first offroad trip.
    I used to make my own cabin filters out of 3M house filters, by cutting them. I then discovered the Bosch filters (made by MicronAir). They are far better quality and priced very similar to the OEM filters. I have used them for the last year or so in the 4Runner with no more cabin dust or fine sand issues.
    Go ahead try them for yourself and see the difference in quality and filtration. Sure the Prius won't see the conditions my 4Runner is exposed too, but still it is better to get a far superior filter for the same price.
    Bosch part # P3785. Can be found at Rockauto ($15 or so and shipping) or other online stores. Or you can order it at your local Autozone. Best to order a couple online, if you like the quality, to save on shipping.
    Side by side pic. The picture actually doesn't do it justice. The Bosch filter also seals the edges much better than the stock filter.
  8. gussom1
    gussom1 New Member
    36
    SFV
    Thanks for the info, my filter was a mess. Took less than 5 minutes to change.
    Thanks
  9. k4141222
    k4141222 New Member
    Trust me. Save your money folks. Vacum filter out. Run filter under water ring it out (Brand New Done.)
  10. suelipton
    suelipton New Member
    does anyone else have a problem with mold growing in their A/C evaporation pan? I've had the system flushed, probably with nasty chemicals I'd prefer not to breathe, and the filter changed; a couple weeks later and the stink is back. Thanks!
  11. patsparks
    10,664
    567
    Adelaide South Australia
    I used air to blow the dirt from my filter.
    No smell in my AC but the air here is dry. Check the drain isn't blocked.
  12. geminirat
    geminirat Junior Member
    32
    Downriver, Michigan
    Always a day late (in this case a few months) and a dollar short (in this case more than that!)
    Just came from the dealer where my my friendly service rep recommended replacement of my Cabin Air Filter (this was the first time and @ 35,000 miles) for a mere $23.60 + $1.42 sales tax + $10.80 labor = $35.82. Why do I have to be the one pumping more money into the economy?
    Thanks for all the advice on this thread - next time.
  13. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(bulldog @ May 19 2007, 04:53 PM) [snapback]445819[/snapback]</div>
    I just bought a Bosch filter at Autozone and they charged me $21.00 not including tax. If I like it I'll try ordering several to save on shipping as that's probably cheaper than buying it at AutoZone. And I can't imagine Pep Boys or Kragen having it much cheaper. They're all pretty much the same.
  14. Clar
    Clar Member
    151
    DC/MD/VA
    I bought 3M filters after I saw this at fatwallet:
    http://www.fatwallet.com/forums/messagevie...337&start=0
    I bought 2 and paid $35 after entered coupon code. That's about $17/piece that includes microfiber cloth and glass cleaning cloth.
    Bad thing about this mail order is that it didn't mail you a confirmation or anything. You wouldn't know when you will get it. I received mine 3 weeks after I ordered. It came in two separate priority mail boxes.
  15. prius2008
    prius2008 New Member
    <div class='quotetop'>QUOTE(Tideland Prius @ May 5 2006, 08:16 PM) [snapback]250565[/snapback]</div>
    remember me, the prius2008
    do you change the cabin air filter yourself and bought it from canadian tire store ?
    do you get toyota service your car since new ? oil change....etc..
  16. Tideland Prius
    16,588
    <div class='quotetop'>QUOTE(prius2008 @ Nov 28 2007, 11:52 PM) [snapback]545571[/snapback]</div>
    Changed it myself. Super easy. Takes 5 mins tops.
    1. Open the glovebox (remove items from the box if necessary)
    2. Locate the strut on the right side of the box.
    3. Remove the connector arm thingy that links the strut to the box
    4. Push in the sides of the box and lower the box (did you take out the items?)
    5. Locate the air filter holder and remove it.
    6. Replace air filter
    7. Replace holder. Take note of which side is the top
    8. Locate the strut and connect it back to the box
    9. Push the sides in and replace the box
    Done!
    Yes I've had all services done at Toyota. The only difference I did was rotate the tyres at the 2nd oil change (16,000km). Toyota links the tyre rotation to the full maintenance but since the first 3 are oil changes, you skip the 16,000km rotation (I rotate them once a year or 16,000km). That way, I get even wear and my tyres have worn evenly.
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    https://www.autohausaz.com/Changed my engine air filter today and boy was it dirty! I thought I'd TTT this thread for others who might be looking for cheap filter replacments. I'm going to order more filters from AutohausAZ again. The last ones worked great and were cheaper than from the dealer. :)
    In case you don't see my post about modifying the air filter to work, you don't need a Dremel tool. A pair of dikes or gargen clippers will work fine.
    The engine air filter part # I used is: 17801-21040P
    *EDIT*
    Hell with it. They changed the part # and now the filter is $15.96/ea. I'm just going to order a K&N from Crutchfield lol
  18. etyler88
    etyler88 etyler88
    450
    Dover, DE
    Re: Check your Cabin Air Filter Today!
    What if I just removed the cabin air filter and did not replace it. I am used to breathing unfiltered outside air and I would not complain. Would the car complain? My first thought is I am decreasing the load on the blower motor which is good right? I would probably put in some screen material to prevent big leaves or other getting in the system.
    Any problems tossing the filter and using a screen?
  19. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    yuck
  20. etyler88
    etyler88 etyler88
    450
    Dover, DE
    Thanks for the input Bubble Boy.
