Do you have a little Play on the back of the Fin on the Hatch?
Discussion in 'Gen 2 Prius Main Forum' started by priusmaybe, May 4, 2007.
  1. priusmaybe
    priusmaybe New Member
    314
    Atlanta
    but after I get it down, I push it closed with my hand on the fin, if that is what it is called.
    I have noticed some movement/play when closing it.
    I have started trying to use the area around the Toyoto logo instead
  2. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(priusmaybe @ May 4 2007, 11:41 PM) [snapback]435845[/snapback]</div>
    yeah i dont think closing it with the spoiler is a good idea because it does give a bit. I have gotten used to using the handle on the inside and just pull it down hard enough that its momentum closes it all the way
  3. Tideland Prius
    16,539
    Yeah, don't press down on the spoiler. The Toyota logo is a good area.
  4. Sufferin' Prius Envy
    3,998
    Try using the license plate. It's a much larger target that the logo.
    To keep fingerprints off the back of the hatch, I use either the latch ring - the thing which sticks out the center bottom of the hatch, or the inside handle . . . THEN I use the license plate to add proper closing speed/pressure.
  5. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    Another Vote for the Toyota logo; you don't even need to push down; just push against it.
  6. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(morpheusx @ May 4 2007, 09:02 PM) [snapback]435857[/snapback]</div>
    Your solution may work for you but if someone is height impared as my wife is they may find this link useful.
    http://www.ultimatecupholders.com/trunkhandle.html
    It works great and was one of my first Mods.
  7. morpheusx
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(seasalsa @ May 6 2007, 08:47 AM) [snapback]436308[/snapback]</div>
    Oh yeah didnt even think about how alot of people may be too short. I guess another alternative would be a step stool. LOL J/K
  8. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    That is a clever idea. How about posting a picture of yours.
    Thanks
  9. seasalsa
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Tom 6850 @ May 9 2007, 03:26 AM) [snapback]438142[/snapback]</div>
    OK, here it is.
