HID fog lamps
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Green Hokie, May 13, 2007.
  1. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Hello again, folks. Anyone replaced their "yellow" stock fog lamps with HID or near HID to match the headlights? If so, what is a good brand & are there any that don't get so hot?
  2. kdk84
    kdk84 New Member
    113
    Michigan
    I was actually wondering the same thing. Any info would be appreciated!
  3. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    I did mine and used the Pilot 9006 4300K Xenon HID Conversion Kit JDM Phillips from pipi_stuff168 which I paid $165 for back in November. Easy job, hardest part (and not hard) was removing the front bumper to mount the HID transformer. Total job less than 1 hour and I love the lights now-they actually make a difference at night.
  4. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    <div class='quotetop'>QUOTE(cairo94507 @ May 13 2007, 09:47 AM) [snapback]441021[/snapback]</div>
    Thanks, Cairo. If possible, I want to avoid installing an entire kit (with a HID transformer). So, I'm hoping a simple bulb replacement will get me something that will closely match the HID headlamps and at the same time doesn't get terribly hot.
  5. Tideland Prius
    16,623
    HIR bulbs? That's an option but someone here mentioned he had some issues with them (can't remember if it was short lifespan or sth).
    You can try Sylvania Silverstars too.
  6. cairo94507
    923
    36
    Auburn, CA, USA
    <div class='quotetop'>QUOTE(Tideland Prius @ May 13 2007, 11:40 AM) [snapback]441083[/snapback]</div>
    In my limited experience with those bulbs, they are junk. They do not do anything to provide better lighting, they make the car look like one of those kid's cars with the large fart can exhausts and neon lights in the fender wells, etc. I guess if that is the look one desires.....
  7. Tideland Prius
    16,623
    <div class='quotetop'>QUOTE(cairo94507 @ May 14 2007, 07:54 AM) [snapback]441626[/snapback]</div>
    <shrug> she wanted regular bulbs. Those were the only ones I could think of. Do you have any other suggestions short of going for a kit? I wouldn't mind a nice set of foglights that are actually worth something and don't overheat. The OEM ones are ridiculously hot and I don't know if Toyota replaced the lens on the 06+ models cause it seems like we don't have any more cracked lens issues.
  8. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Will these Silverstar bulbs make the fog lights look more "white" like the HID headlights? If so and these Silverstars do not get terribly hot, then I'm going to try them. I'm not concerned about the effectiveness or functionality of any replacement fog lamp. In my opinion, fog lights on almost all vehicles are merely cosmetic anyway.
  9. Tideland Prius
    16,623
    My headlights are white-ish. Well, let's just say they make my foglights yellow so I'm sure they'll match the HIDs better than any other bulb. Just note that they don't last long (unless you don't use your fogs very often). With a pair in my headlights (keep in mind we have DRLs), they last a year.
  10. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Thanks, Tideland. These Silverstars only last about a year? Darn! Guess I won't be trying them afterall. I always have my fog lights on with the headlights. By the way, what does "DRL" mean?
  11. Tideland Prius
    16,623
    Well, at least mine did. Perhaps I had bad luck? heh. My left blew out last Oct and the right a few weeks later.
    At Cdn$70/pair, by the time I go through two, it's almost the same as Cairo's HID kit.
    So you might as well give his method a shot.
    DRL = Daytime Running Lights
  12. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Thanks again, Tideland.
    I don't turn my head/fog lights on during the day. Therefore, perhaps the Silverstars are worth a try. I'll have to check what the U.S. prices are for these.
    Cheers!
  13. Tideland Prius
    16,623
    np, let us know how it turns out.
  14. NoMoShocks
    1,292
    83
    Camas, WA
    When used as Daylight Running Lights (Full Power) Silverstars only last me 3 months. The life seems fairly cosistant as on two cars, one burns out withing one or two weeks of the first one, so if you are not right on top of replacing them, you can end up with No Lights.
    For my Fog Lights, I am thinking about going with PIAA Yellow for true fog cutting. Not yellowish white, Real Yellow. I don't really care how the look to others as long as they aren't blinding others.
    I had very bright white fog lights on my Honda Civic Hybrid, and they only improved lighting close to the car, not out in the distance.
  15. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    <div class='quotetop'>QUOTE(NoMoShocks @ May 17 2007, 03:19 AM) [snapback]443994[/snapback]</div>
    Thanks for chiming in, Larry. Wow. I guess the saying is true. "They don't make em like they used to". Our other vehicle (4Runner) is over 10 years old and I have yet to have a headlamp go out on me. Before we bought the Prius, I owned/drove a Civic for 14 years and only replaced the headlamps once. Actually, only one lamp burned out but I decided to replace both since the difference in brightness between the old and new lamp was quite significant.
  16. Tideland Prius
    16,623
    Well the regular lamps last as long as you remembered. Our Camry was 5 years old and over 106,000kms. Only one headlight burnt out.
  17. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    I just put silverstars in my fogs last night. They do get rid of the yellow color, but they are only 4500k and hids are like 8000k. Not the exact same color, but they are white, not yellow.
  18. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    u could buy a 9006 HID conversion kit, and mount the ballasts on the radiator rack or something. I was thinking putting projectors in place of the fog lamps but i have no idea if it would fit.
  19. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Thank you, Slair & Statultra. I'll probably try the Silverstars first to see if I like them.
    Slair, Do your Silverstars get any hotter than the OEM fog lights?
  20. Tideland Prius
    16,623
    <div class='quotetop'>QUOTE(Slair @ May 18 2007, 07:54 AM) [snapback]444840[/snapback]</div>
    Stock HIDs are 4300K not 8000K. 8000K HIDs are blue and are dimmer than 4300K or 6000K.
