RDS option
Discussion in 'Gen 2 Prius Audio and Electronics' started by cireecnop1, May 19, 2007.
  1. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    I noticed that the RDS option on the Prius stereo is WAY different from other systems, It doesn't display the song or artist but it does display what the station name is.....is this normal or is my stereo on the fritz?
  2. Tideland Prius
    16,615
    The station name shows up in the AUDIO screen (with the 6 presets showing). The song title/artist is shown by pressing MSG.
  3. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Tideland Prius @ May 19 2007, 09:37 AM) [snapback]445693[/snapback]</div>
    ....and the car cannot be moving for it to be displayed.
  4. cireecnop1
    338
    Pueblo, CO
    <div class='quotetop'>QUOTE(Vagabond @ May 19 2007, 01:52 PM) [snapback]445778[/snapback]</div>
    Then thats the problem, althought my message button never has anything in it. thanks guys
  5. Renocat
    Renocat Member
    363
    Rochester, NY
    On my 2006, the radio station, artist and title all show up on the audio screen while in motion
  6. Rest
    Rest Active Member
    1,210
    CA
    Shows up in my 2007 while moving too.
  7. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    Question for LA people:
    Formerly, K-Mozart, is now a cowboy station, but still shows "K-Mozart" on the screen. Does yours do this?
    Also KUSC (Classical) is stuck on "Elgar", no matter what is playing. What does your KUSC say when the display is on?
    I know the displays are controlled by the individual stations, not the car, but these two have me puzzeled.
  8. aaf709
    3,862
    2022 Prius Prime
    In my 2005 when I cut the speed sensor wire for the BT (and installed a switch), I had access to the MSG while in motion.
  9. Manksgloob
    Manksgloob Member
    243
    The message is whatever the radio station is broadcasting. If it's sending Artist, Title, Station, then that's what you'll get. If it's only sending the Station, well, then that's all your radio will say. Sometimes it's corrupt and doesn't say anything at all.
    Also, make sure that your radio hasn't only received a portion of the message rather than the whole thing. Sometimes it takes a couple cycles for the entire message to (be received) and shown.
  10. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(aaf709 @ May 22 2007, 01:06 PM) [snapback]447505[/snapback]</div>
    Hmm, I should do this. For the BT.
