Yeah! Another one of my incandescent light bulbs went out!
Discussion in 'Environmental Discussion' started by burritos, May 8, 2007.
  1. burritos
    burritos Senior Member
    4,946
    252
    So I replaced it with another cfc. Even though it's atmospherically wasteful to finish out the use of the incandescent light bulbs I just can't get myself to throw away perfectly functionally light bulbs. So as they go out one by one, they'll be replaced by cfcs. I'm rooting for the incand.'s to burn out, but I just can't chuck them.
  2. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    You should stop replacing your incandescents with CFCs (Chloro-Fluoro-Carbons) and start using CFLs (compact-fluorescents) :D
  3. Alric
    Alric New Member
    1,526
    87
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I've been doing the same, but recently starting to resent the fact that my home-builder used long-life (130V) bulbs. Most lighting in my home are the 60-75w floods in "multiples" (2-6) or the globe style bulbs in 1 or 2 sets of 4 (bathroom).
    It's the custom bulbs that tend to cost more, so I might just try to find a sale and stock up at some point knowing that I can either toss the "usable" incandescent or wait for a burnout.
    Now if I could only find some specialty sized dimmable CFL's, I could do a chandelier as well.
  5. Alric
    Alric New Member
    1,526
    87
    <div class='quotetop'>QUOTE(htmlspinnr @ May 8 2007, 10:10 AM) [snapback]437488[/snapback]</div>
    BTW, LEDs are dimmable.
  6. chogan
    chogan New Member
    590
    Vienna, VA
  7. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    I'm about to buy these and replace all my "in roof" lamps at home. I need them to be dimmable and these are the ones I've found:
    http://www.nolico.com/saveenergy/dimmable_lamps.htm#Items
    I like that they are dimmable, but the price is "steep".
    *) Do anyone have experience with dimmable CFLs? Do they work well?
    *) Anyone with a cheaper source of dimmable CFLs?
    *) Alric: Can you expand on your experience with LEDs? What type of lamps have you replaces with LEDs? My understanding is that they are still too weak for indoor flood light?
  8. Alric
    Alric New Member
    1,526
    87
    <div class='quotetop'>QUOTE(SomervillePrius @ May 8 2007, 12:52 PM) [snapback]437611[/snapback]</div>
    I haven't started buying them. Manufacturers can tell you the watt equivalent of an incandescent lamp. What I have noticed is that lately their intensity has increased recently.
  9. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    i used to want to sit around and wait for the old bulbs to burn out. then i wondered what the hell i was thinking.
    first, i assume you already bought the replacement CFLs... so it's not like there's a cost threshold. next, you have these efficient bulbs sitting around, yet you let these inefficient things light your home. third, it's not like the lifetime of the CFLs is even comparable to that of incandescents. so it's not like you're saving a substantial amount of money on lighting because that extra 3 months the incandescent lasts is another 3 months you won't have to buy a CFL. while this particular statement may hold true, CFLs last for years anyway, what's a couple months over that time period?
    that was my reasoning for dumping the old ones right away. but.. unlike many here, i decided to save them and when we move out, we will take our CFLs and put the old cheapies back.
  10. SomervillePrius
    944
    Somerville, MA
    My reason for not replacing the "cheapies" is that they where manufactured and transported from china to my door. I don't want to waste that "energy" by throwing them away and I'm thinking that this energy is actually higher then the energy the new ones will save.
    So I let them burn out but replace any burned out lamp with a CFL when possible
  11. Ichabod
    1,794
    Newton, MA
    The energy is already wasted! Stop the waste! And Galaxee, leave the CFLs in place when you move and hopefully we'll have another convert when the next moves in :)
    Anyone talking about dimmers, consider the fact that some dimmers work by resisting, i.e. throwing away electricity. If you have older dimmers of the rheostat type, and you want to save a little, upgrade your dimmers so you're not throwing power away.
  12. chogan
    chogan New Member
    590
    Vienna, VA
    <div class='quotetop'>QUOTE(SomervillePrius @ May 8 2007, 01:52 PM) [snapback]437611[/snapback]</div>
    Dimmable CFLs are only slightly dimmable, you can't get them down to a nice rosy "mood lighting" level. I tried one one (because there was already a dimmer), ended up replacing the dimmer instead. Possible others are better than what I tried, but I think that they all have a limited range of light output -- none are really full-range dimmable.
    <div class='quotetop'>QUOTE(SomervillePrius @ May 8 2007, 02:38 PM) [snapback]437642[/snapback]</div>
    I had a good reference on this -- life cycle costs -- but couldn't find it. But a commonsense (and true, in this case) argument is the following. The cost of the bulb covers at least the cost of the energy used to manufacture and transport it, at least in the long run. Plus other items - other inputs to manufacture other than energy. The cost of an incandescent 100 watter is maybe 60 cents. So energy cost in manufacture, transport, and retailing of the bulb is under $0.60. With 1500 hour life it'll use 150 KWH = $15 of electricty, at 10c/KWH (my rates). That's all energy cost. So the ratio of energy in use to energy in manufacture must be greater than 15.00/0.60. Almost all the energy is in the use. Toss them now without regret.
  13. SomervillePrius
    944
    Somerville, MA
    <div class='quotetop'>QUOTE(chogan @ May 8 2007, 04:37 PM) [snapback]437778[/snapback]</div>
    You might be right. The site claim they can go down to 20% of full power (i.e "75W"X0.2=15 watts). Probably not as low as I would like but should work at least in living room.
    So there are dimmers that can handle dimming "any" CFL? Need to look into that! Might be a better solution?
    You argument make sense and I should have thought about the cost. I think that settles it... Time to go buy abunch of CFLs :)
  14. richard schumacher
    7,664
    1,044
    United States
    Long-life incandescents are especially evil. They achieve their long life by being designed to run cooler than ordinary bulbs. But as they are essentially "black body" emitters, lower temperature also means that they produce proportionately more heat and less light per unit of energy used. Note that the same thing happens when any incandescent bulb is used with a dimmer.
  15. SomervillePrius
    944
    Somerville, MA
    Interesting. I didn't know that. Are dimmable CFL equally inefficient?
    I will def. replace al my bulbs now!
  16. ozyran
    ozyran New Member
    695
    Here are some nice LED bulbs as well; I think I'm gonna start with the bulb I need to buy for my drop light :D.
    Thanks, Alric, for pointing out the LED bulbs. I'd been thinking about them for some time but didn't know that LED bulbs even existed.
  17. burritos
    4,946
    252
    My closet light went out. We were using it as a night light to help us while scrambling to prepare formula for our baby in the middle of the night. When I undid the covering, there were 3 60 burnt out watt light bulbs. I had no idea. I replaced it with 1 20 watt CFL and it's nearly just as bright and just as functional. Can you imagine that? 180 watts to 20 watts? That'd be like the prius suddenly going to 500 mpg in one fell swoop.
  18. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    I would like to convert all/most of my lights to CFL bulbs (and am slowly doing it), but does anyone have recommendations for CFLs that produce "nice" light? I've managed to convince my S.O. to change a lot of the lights in our apartment to CFLs (office, kitchen, closets), but there are some places where she insists (and I agree) that incandescents give a much better light. In our bedroom, we have one of those "Reveal" incandescents that give a very nice (closer to solar spectrum) type of light. Is there anything like this for CFLs? It seems like the bulb companies should be able to find filters that would make the light more pleasing. Are there any "magic bullet" bulbs that people are aware of or am I just going to have to be content with trying to sneak CFL bulbs in and hope she doesn't notice?
  19. Wildkow
    Wildkow New Member
    5,270
    37
    36
    OK what about the mercury that each CFL contains? Is that an issue as far as the enviroment? They do still burn out and have to be disposed in the landfill right? I like the LED's but geeeeez the initial cost is frightening! :blink:
    Wildkow
  20. Essayons
    Essayons Essayons
    Richmond. va
    <div class='quotetop'>QUOTE(Betelgeuse @ May 23 2007, 12:06 PM) [snapback]448264[/snapback]</div>
    In the kids bathrooms I put a bunch of 'daylight' CFLs. They seem to put out a good white light. I think they are from GE.
