Cup Holder stuck
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Festus, May 22, 2007.
  1. Festus
    Festus New Member
    BEWARE! Has this happened to anyone else? I left a coin or 2 in my front cup holder. When I closed the cup holder, a coin apparently fell into the gap. So, now I can no longer flip the cup holder open. Anybody know how to fix this? (without tearing up my console)
    Thanks!
  2. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    The front cupholders are part of a subassembly that snaps off pretty easily. Take a look at the attached page from the repair manual to see how it's held in place. Once you get it off you should be able to hold it upside down to get the coins out, or if that doesn't work then do a little more disassembly to get at it.
    Good Luck.
  3. Dan-Wolfe
    Dan-Wolfe Member
    166
    31
    North Canton, Stark, Ohio, USA
    <div class='quotetop'>QUOTE(San_Carlos_Jeff @ May 22 2007, 12:38 PM) [snapback]447371[/snapback]</div>
    I spilled a little milk down there a few weeks back on a hot day. Smelled nasty when I got back, so I had to figure out how to remove the cup holder assembly. It's a breeze! Pulled it apart, rinsed it thoroughly, dried it and reassembled. No trouble at all!
    Dan
  4. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    That's pretty funny about the coins. I've actually wondered a few times whether leaving coins in there would get them stuck. I thought it might be ok, but I decided not to test my luck. Now I might just have to disassemble that console just to see how easy it is :)
  5. Festus
    Festus New Member
    <div class='quotetop'>QUOTE(Dan-Wolfe @ May 22 2007, 12:45 PM) [snapback]447403[/snapback]</div>
    Thanks! I'll try it.
  6. pkittie
    pkittie Junior Member
    LaLa Land
    When I first got my Prius, I put the coins in the front holder and immediately tried to close it. Coins started sliding down. From that point on, I put them in the second holder. But it's nice to know you can disassemble the front cup.
  7. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I've had to open mine up as well. Not hard. If I'm alone I don't put soda cans in the front holder since any drip is sticky and it is a lot easier to clean the rear holder. :)
  8. Rest
    Rest Active Member
    1,210
    53
    CA
    The Prius cup holder design is not very good. Toyota should have used the 2001 RAV4 design.
  9. Hibermuda
    Hibermuda New Member
    connecticut
    Men are very crafty and I know I'm late to the party here, but my solution is a bit elegant. I lifted the cup holder cover about a quarter way up and then used my tweezers to capture the coins. I do like learning how to assemble and disassemble, but I'm sleeping in Walmart's parking lot, 1st day of homelessness. Hope this helps someone. Original proud owner and very satisfied with 2008 Prius Base model
