4 Character plate suggestions?
Discussion in 'Gen 2 Prius Main Forum' started by efusco, May 24, 2007.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I currently have a pretty cool personalized plate (see below) "TOGOB4". But just very recently my alma mater got Missouri to adopt a "Go Hogs" license plate with an Arkansas Razorback. This is, by default, a personalized plate. But instead of the usual 6 characters to custom number you only get 4 characters due to the space taken by the 'hog' image.
    So, I'm considering a switch to these nice tags but would like to retain a prius theme for the plate number. I'm looking for suggestions for a logical number....any thoughts?
    UPDATED--The New Plate!
  2. larkinmj
    larkinmj New Member
    1,996
    You're going to give up a cool plate like that, just so you can have a hog on your plate? :blink:
  3. Dan-Wolfe
    Dan-Wolfe Member
    166
    31
    North Canton, Stark, Ohio, USA
    <div class='quotetop'>QUOTE(efusco @ May 24 2007, 01:52 PM) [snapback]449183[/snapback]</div>
    0MPG
  4. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    You could just drop the "TO" and make it "GOB4". It maintains what you've always established. You just lose the preposition.
    It may not be a strict translation, but it's in the spirit.
  5. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Proco @ May 24 2007, 12:57 PM) [snapback]449188[/snapback]</div>
    Ok, I like that thought and it would still make sense to other Prius people "in the know'.
    Still open to other suggestions!
  6. emtownsend
    emtownsend New Member
    111
    Post Falls, ID
    <div class='quotetop'>QUOTE(efusco @ May 24 2007, 01:00 PM) [snapback]449190[/snapback]</div>
    Hum... GODC, as in go electric?
  7. larkinmj
    larkinmj New Member
    1,996
    How about HBRD ("hybrid" without the vowels)?
  8. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I'll let you borrow the last four of mine: NIMH
  9. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Initially I was thinking 5 characters, LO CO2, but it sounds that 4-char limit is set in stone.
    I'm not sure of your view of South Park, but PIUS might work? or SMUG. There's other 5 chars options, but for 4 chars, I think GOB4 is the most reasonable change for you.
  10. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(JimboK @ May 24 2007, 11:17 AM) [snapback]449204[/snapback]</div>
    National Institute of Mental Health (as in Mrs. Frisby and the Rats of NIMH)? :D
    How about PRII?
  11. ystasino
    ystasino Active Member
    793
    Tucson, Arizona
    How about
    THNK as in THiNK
  12. Tideland Prius
    16,611
  13. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Tideland Prius @ May 24 2007, 01:51 PM) [snapback]449239[/snapback]</div>
    Another viable option..maybe a 2nd choice since I'm supposed to list several...also I like NIMH.
  14. TheForce
    3,461
    537
    Wheelersburg, Ohio
    200V or any voltage you like ;)
    WATT
    VOLT
    ACDC Could mean the they way electricity is transmitted or it could me you like the band.
    ECAR
    NERD
    JERK <_< :D
    I should have more when I get home tonight.
  15. Tideland Prius
    16,611
    Gen2
    2GP (P for Prius, G for generation)
    1NZ (first 3 no. of engine code)
    PZEV
  16. Trendy2
    Trendy2 New Member
    25
    Plano, Il
    How about "SMUG"? :D
  17. priussoris
    priussoris New Member
    1,005
    Since being a Dr. skip the "hog" and go with
    2DRESQ as (to the rescue)
  18. efusco
    19,891
    1,196
    Nixa, MO
    PZEV's good too. Glad you guys have some good ideas!
  19. RobertG
    RobertG New Member
    166
    Northern California
    I think a good plate, at least for some areas, would be:
    • UBIQ
    since the car is so ubiquitous.
  20. efusco
    19,891
    1,196
    Nixa, MO
    Thanks for the great ideas everyone. I sent in the app. today with GOB4 listed first, HBRD second, PZEV third and NIMH as my 4th choice.
    Promo video Here:
    http://www.hogtags.com/hogtags.mov
