Strange Sound Coming From Under Dash?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by warcat507, May 15, 2007.
  1. warcat507
    warcat507 Junior Member
    17
    I noticed when I first start my Prius in the morning that it makes a squealing noise. It sounds like a small electric motor with a bad bearing is running under the dash to the left, possibly up by the windshield. It stops after about a minute or so and I usually only hear it when I start the car after it has set for awhile, like overnight or several hours. Has anyone else heard this sound coming from their vehicle?
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Is your cat missing? :) Sorry, I couldn't resist.
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    It's the chipmunks living in the air box.
    ... but seriously ...
    Is it squealing, like metal on metal or rubber, or an electronic
    beep? Does it start before or after the engine's running? Can you
    hop out of the car right after powering up and try to locate it
    more closely?
    Someone in another thread recently described the brake-pressure-fail
    alarm as a "squeal", so it's become too broad a word to really nail
    down what you're hearing...
    _H*
  4. warcat507
    17
    <div class='quotetop'>QUOTE(lenjack @ May 15 2007, 08:32 PM) [snapback]442917[/snapback]</div>
    Which one? I've got 5! :)
    <div class='quotetop'>QUOTE(hobbit @ May 15 2007, 09:56 PM) [snapback]442977[/snapback]</div>
    It sounds like metal on metal -- like the sound a fan in a computer case makes before it goes out. It only happens after I power up the car in "Ready" mode. It definitely is not an electronic chirp as it sounds like something is turning. Is there maybe a little fan that samples air for the cabin temperature that could be going out?
  5. ktsujimoto
    ktsujimoto New Member
    I have noticed a similar problem - a "whirling" sound just as I press the start button when the engine is cold. It lasts for 5 to 10 seconds, then either stops on its own, or when I put the car into reverse or drive. It has been going on for a few weeks, and I finally decided to bring it in to the dealership today. They weren't able to duplicate the sound, so they are keeping it overnight to see what happens in the morning. I'll let you know if they figure it out.
    <div class='quotetop'>QUOTE(warcat @ May 15 2007, 03:06 PM) [snapback]442777[/snapback]</div>
  6. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    Is it possibly the hot coolant transfer pump? Some people have found that it squeals like a banshee when it's about to give up the ghost. Plus, it's certainly worse when the engine is cold. Or, do you hear this sound independent of the coolant transfer pump?
  7. ktsujimoto
    Yes, it was the COOLANT TRANSFER PUMP. Thanks to the person who mentioned it here, after reading the various posts on the topic, I called the service guy this morning, and mentioned to him that this might be the problem. When they turned it on this morning, it did make the sound, and he thanked me for pointing them in the right direction. They are ordering the part (covered under warranty), and I will get it repaired when I get a chance in the next few weeks (will take 3 to 4 hours). He said it was not an urgent issue to repair this week.
    Karen
  8. haggart
    haggart New Member
    <div class='quotetop'>QUOTE(Betelgeuse @ May 23 2007, 10:43 PM) [snapback]448745[/snapback]</div>
    I have the same noise is a 2005 Prius and my dealer keeps telling me that this is normal. Looks like it is not normal at all. Mine makes the noise when first turning the car on and then makes it again when the car is turned off - lasting 5 to 20 seconds. If the dealer I bought the car from says its normal - what next - another dealers?
  9. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(jayhawker @ Jun 18 2007, 08:40 PM) [snapback]464468[/snapback]</div>
    jayhawker, welcome to Priuschat. :)
    STEPS TO RESOLVE THE PROBLEM:
    1) Open up the hood.
    2) Start the car.
    4) Quickly go the the engine area and stick your head in near the driver side.
    5) That "whirring" sound which lasts for around ten seconds is the pump moving hot "coolant" liquid from the storage container to the engine before it starts.
    6) Close hood, turn car off.
    [If the "whirring" sound wasn't so loud that you felt the need to plug your ears, proceed to step #7]
    7) Call your dealer and apologize for not believing them.
    Relax, it's a Toyota.
