Awesome start of a tank
Discussion in 'Gen 2 Prius Fuel Economy' started by Tadashi, May 22, 2007.
  1. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    Either I have a broken fuel gauge or I will have an awesome tank. I am at 178 miles and still on all pips. I just switched my route from the highway to back roads (max speed is 40 mpg but avg 30) and it only adds about 5 min on my 17-mile commute. This is probably a good thing since 87 octane is now $3.01 a gal.
    Any ideas how much gas is in the first pip? The MFD says 63.8 mpg so far but that is usually way off.
  2. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Tadashi @ May 22 2007, 06:24 PM) [snapback]447724[/snapback]</div>
    I seriously doubt that it's consistent. However, 177 miles for the first pip is what I got for my all time record on a tank of gas. MFD miles said 69.9 mpg and calculated said 66.7+.
    Dave M.
  3. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    Until last week, I had not seen more than 226 miles on the first pip. This tank I thought my gas gage had broken as I went 265 miles on the first pip. I am now at 80.1 mpg after 380 miles on this tank. I think I have a shot at 1000 miles for this tank.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    There is nothing like the feeling of hitting 200miles and still on the first pip. Since I drive 98% freeway it is tough for me to see those numbers often. Good luck on this tank! :)
  5. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    It finally went down :( at the 210 Mile mark. Although, that is a personal best. :)
  6. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    <div class='quotetop'>QUOTE(Tadashi @ May 24 2007, 11:38 PM) [snapback]449575[/snapback]</div>
    Tadashi,
    Keep up the good work; you are on your way to a 800 mile tank.
  7. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(Tadashi @ May 24 2007, 07:38 PM) [snapback]449575[/snapback]</div>
    I see your general mileage this year has been a lot more than mine.
    If the gauge is consistent between your car and mine, you should get about 830 miles on your tank.
    Congratulations on a great start.
    Dave M.
  8. kdk84
    kdk84 New Member
    113
    Michigan
    $3.01 a gallon?? thats a steal it is $3.65 here in michigan
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(VABeachPrius @ May 25 2007, 08:21 AM) [snapback]449800[/snapback]</div>
    I'm not sure why you guys are blessed with such large tanks or if you chose to run a tank to the dangerously low level. Even when I can get 200miles on the first pip I still end up having to refill before the 500mile mark to play it safe. I usually do this when I am down to two pips. Are you guys going much lower than that?
  10. kdk84
    kdk84 New Member
    113
    Michigan
    <div class='quotetop'>QUOTE(F8L @ May 25 2007, 02:09 PM) [snapback]449944[/snapback]</div>
    I've taken it down to a blinking single pip... and the tank still only took 9.5 gallons
  11. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(kdk84 @ May 25 2007, 02:17 PM) [snapback]449952[/snapback]</div>
    I take it down to the blinking pip as well, usually will take about 10.3 - 10.9 gallons from flashing.
    <div class='quotetop'>QUOTE(Tadashi @ May 22 2007, 09:24 PM) [snapback]447724[/snapback]</div>
    the fuel gauge is quite odd, I have seen it lose a pip as early as 70 miles, and I have seen me go 180 miles and not lose the first pip.
  12. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(F8L @ May 25 2007, 11:09 AM) [snapback]449944[/snapback]</div>
    On my last tank, I got down to two bars at 460 miles, down to one bar at 569 (yes, 109 miles on the ninth bar) and it started flashing barely seven miles later. I filled up at 583.6 miles and it took 11.04 gallons. The most I have ever managed to pump in was ~ 11.5 gallons.
  13. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ May 25 2007, 03:35 PM) [snapback]450093[/snapback]</div>
    Well. That beats most of us. I was starting to think 11.9 gallons was an outright lie.
    Well not really, but I've never gotten in more than 10.5 gallons, and that includes the one time I ran out of gas.
    Dave M.
  14. kdk84
    kdk84 New Member
    113
    Michigan
    <div class='quotetop'>QUOTE(dmckinstry @ May 25 2007, 10:33 PM) [snapback]450176[/snapback]</div>
    Approximately how far did you travel on a blinking pip before you exhausted your remaining fuel supply?
    For curiousity's sake :p
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    That is the kind of info I was looking for. Thanks :)
  16. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(kdk84 @ May 25 2007, 07:55 PM) [snapback]450189[/snapback]</div>
    The time I ran out of gas, it wasn't more than 15 miles, but I was on an up hill when I ran out.
    The last time I filled up I'd got about 40 miles (without running out) before I filled up. Basically, I don't trust the pips at all.
    Dave M.
  17. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    F8L,
    I usually pump between 11.3-11.7 gallons of gas on each fill. I did pump 12.138 gallons a few months back; and I am wondering how that was even possible. It was one of the few times I used a different pump than what I normally use.
  18. hill
    8,718
    <div class='quotetop'>QUOTE(kdk84 @ May 25 2007, 01:24 PM) [snapback]449910[/snapback]</div>
    $3.65 a gallon?? that a steel, it's $3.89 here in south orange county, CA :(
    You can always travel 30 miles when the pip begins blinking
    spell corrected ~ whoops
