Failed Navigation System
Discussion in 'Gen 2 Prius Audio and Electronics' started by Sugar5, May 26, 2007.
  1. Sugar5
    Sugar5 New Member
    I'm new on the prius forums. recently purchased an 05 Prius with a C package. It is an American car but purchased in Canada where I live. Since this seems to be the place to get answers on the Prius Nav system I hope you will have an answer to my question. While parked on the side of the road my partner noticed that the nav could not find the highway that we were on. So he went into the section where the override is and hit the top right button. Then hit Yes..it deleted everything on the right side of the nav box. We have called every dealer we can find in Canada and the USA for an answer on how to fix it. The only thing that comes up on the screen is... Please insert the map DVD. We inserted it and nothing happens. Do you have any idea how we can repair this?
    Please feel free to reply to me directly or on here. I hope i can find your replies...lol
    Thanks in advance,
    Sandi
  2. Family Hybrid
    Family Hybrid Junior Member
    87
    <div class='quotetop'>QUOTE(Sugar5 @ May 26 2007, 11:44 AM) [snapback]450404[/snapback]</div>
    I would recommend disconnecting the 12v battery for 30 seconds. This will erase any memory presets and possibly reset your Nav system. The other option is to unplug the head unit/MFD for 30 seconds, but disassembly of part of the dash is required.
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :) Hi Sandi (Sugar5)
    Hope you got the NAV Manual with your '05 Prius. Your post was not detailed enough to determine just what "upper right" button your pressed. the 'upper right' button is different for different MFD screens. You may have been on the "split screen" which usually shows a more-detailed view on the right for turns. One good resource for NAVigation system information is an online DVD for the Lexus - same Toyota Navigation system, just a little different dashboard button placement. This DVD runs better if you have a high-speed Internet connection, like DSL.
    http://www.lexus.com/lexus-share/demos/LS/.../Lexus_nav.html
    Another helpful source of information is John's web site and his "User Manual" written in more friendly terms than the Toyota Owner's Manual. Go to "Prius Info - User Guide H"
    http://john1701a.com/
  4. qbee42
    3,079
    This is a silly question, but I assume you inserted the NAV DVD into the drive under the driver's seat, and not into the CD player.
  5. galaxee
    galaxee mostly benevolent
    9,810
    470
    MD
    ooh... not good. did it perchance change the map region to a different continent?
  6. Sugar5
    Sugar5 New Member
    Thanks everyone for the help...we have just disconnected the 12 Volt so will let you know what happens. And yes we did put the DVD in the unit under the seat...:)
    <div class='quotetop'>QUOTE(Charles Suitt @ May 26 2007, 10:32 AM) [snapback]450456[/snapback]</div>
    Yes thats exactly what it did...it wanted a map from a different region.
    <div class='quotetop'>QUOTE(qbee42 @ May 26 2007, 10:46 AM) [snapback]450463[/snapback]</div>
  7. galaxee
    9,810
    470
    MD
    uh oh. there is no simple fix for this.
    check out this post, and if you've got the situation i think you have... that's how you fix it.
  8. Sugar5
    Sugar5 New Member
    <div class='quotetop'>QUOTE(galaxee @ May 26 2007, 05:43 PM) [snapback]450568[/snapback]</div>
    Thank you so much galaxee....now to find the jam to go ahead and do that fix...the vehicle is still under warranty so i think i'll take the fix to a dealer in WA and see if they will fix it. Another poster did that and had good luck. Scares me too much to go playing with all those wires..LOL
    Sandi
  9. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Perhaps you should reread Sandi's post. Her parter went into the service menu section of the navigation system (keywords: "where the override is..."). The navigation system manual does not instruct in the use of such hidden service menus.
    <div class='quotetop'>QUOTE(Sugar5 @ May 26 2007, 08:44 AM) [snapback]450404[/snapback]</div>
  10. galaxee
    9,810
    470
    MD
    sandi.... i hate to tell you this but digging into the hidden menus and screwing up your nav system isn't exactly a warranty covered item. chances are the dealership will only offer to replace the nav unit (at high cost). techs are being told in training classes that customers have done this and that it is not a computer glitch, it is from tampering with the hidden menus.
    i wish you all the luck in the world, but remember where those instructions are should you have to do it on your own.
  11. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    So disconnecting the 12 volt didn't work? I thought I read that would reset the DVD load on a message once. Might also matter where you disconnect the 12 volt, as disconnecting it at the player will probably not power down circuits elsewhere.
    Again, only a guess, but considering the alternative, probably worth pursuing.
    So, did you disconnect the 12 volt at the battery or the player?
  12. IsrAmeriPrius
    4,333
    Southern California
    I think it was htmlspinnr who experienced a similar problem. He solved it by disconnecting the internal NAV DVD player backup battery. I don't have the time to do a search, but he posted quite extensively about this problem and how he solved it. Perhaps he can point you to the relevant topics if you were to PM him.
  13. Godiva
    Godiva AmeriKan Citizen
    10,339
    How can it be that easy for a passenger to inadvertantly cause so much damage to the Nav that is has to be replaced?
  14. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    <div class='quotetop'>QUOTE(Godiva @ May 27 2007, 07:50 PM) [snapback]450765[/snapback]</div>
    Remember, this is a hidden service menu that the owner is not supposed to know about... So not supposed to be easy at all.
  15. Godiva
    10,339
    <div class='quotetop'>QUOTE(Wayne @ May 27 2007, 06:53 PM) [snapback]450767[/snapback]</div>
    So how did the passenger find it? Seems like it wasn't that difficult.
  16. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    <div class='quotetop'>QUOTE(Godiva @ May 27 2007, 08:42 PM) [snapback]450798[/snapback]</div>
    She probably read how on this board.
  17. Sugar5
    Sugar5 New Member
    <div class='quotetop'>QUOTE(Wayne @ May 27 2007, 05:45 PM) [snapback]450800[/snapback]</div>
    Ok so we disconnected the 12V at the battery not the DVD player. It didn't help...:(
    I did go the post where the fix is and have printed it out in case we can find a dealer who will do the work for us. I think we will have to got Seattle to have it done..but if they will do it, it will be worth the trip.
    BTW i was told how to get to the override by a sales person at the Seattle Toyota dealer!!! We really wanted to be able to have the passenger using the nav system as we drove across the USA..from one coast to the other...esp the POIs
    Thanks again for all your input. I'll keep ya posted. We will likely go to Seattle on the 17th of June.
  18. vkykam
    vkykam New Member
    27
    Been there, done that, made the same mistake...
    BUT, I did take pictures the last time. I've posted them in a new thread HERE.
    If you're not the type with 10 thumbs on your hand, you could be in and out in less time than to drive to a dealer. I did mine in about 20 minutes if I remember correctly.
    Good luck!
  19. Sugar5
    Sugar5 New Member
    <div class='quotetop'>QUOTE(vkykam @ May 28 2007, 01:18 PM) [snapback]451092[/snapback]</div>
    OMG...I can't thank you all enough. We followed the instructions and have our great Nav system back up and running. We were really concerned about having to put out a ton of money...that is if we could find someone to even do it. In the end it was really very simple.\
    So again...THANK YOU ...THANK YOU :D
  20. vkykam
    vkykam New Member
    27
    Don't thank me, thank the original poster that found the solution. I just happened to have my camera handy. :)
    <div class='quotetop'>QUOTE(Sugar5 @ May 28 2007, 09:33 PM) [snapback]451230[/snapback]</div>
