server too busy?
Discussion in 'PriusChat Website Questions' started by galaxee, May 14, 2007.
  1. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    have we grown to the size where we are overloading the PC servers? :blink: i am getting this "server too busy" message more and more often.
    is there anything we as members can do to alleviate this problem?
  2. qbee42
    3,079
    You mean other than not logging on so often? :p I've been getting that error a lot too, or one of the related MYSQL database errors. We need a bigger hamster for the wheel, maybe a bigger wheel too.
  3. priussoris
    priussoris New Member
    1,005
    <div class='quotetop'>QUOTE(qbee42 @ May 14 2007, 04:47 PM) [snapback]441977[/snapback]</div>
    Instead of a bigger hamster make it a PHH (plug in hybrid hamster ) :)
  4. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    I've been doing my part by not logging in as often. Actually, I've been too busy. This will probably be the case for the next few months, at least. I'm hoping with my new laptop, I'll be able to catch up while watching TV with the wife and dog. ;)
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Well, obviously, someone needs to open 'er up and drop in a HEMI!
    _H*
  6. Tideland Prius
    16,549
    I got that message for the first time today! Needless to say, I was rather surprised.
  7. chinalfr2
    chinalfr2 Member
    234
    New England
    Just keep clicking the refresh button. PC is switching from EV to ICE and do have some time lag. :lol:
  8. Tideland Prius
    16,549
    maybe it's time for PC to switch servers?
  9. kdk84
    kdk84 New Member
    113
    Michigan
    I've run into this problem many times actually. I assume that the member base has reached a point where the servers can become overloaded. I usually just leave and try back in 15 minutes and it is fine.
  10. qbee42
    3,079
    <div class='quotetop'>QUOTE(kdk84 @ May 27 2007, 08:14 PM) [snapback]450773[/snapback]</div>
    It happens to me frequently during peak times, at which point 15 minutes isn't enough. I usually give up and come back a few hours later.
  11. Tideland Prius
    16,549
    Ditto... I had to wait a couple of hours.
  12. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(qbee42 @ May 27 2007, 08:33 PM) [snapback]450790[/snapback]</div>
    Me too, but yesterday (Sunday) morning wouldn't seem to be one of those. I couldn't get in until late yesterday afternoon.
  13. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    I couldn't log in at all on Sunday.
  14. orionll
    orionll Active Member
    1,115
    I couldn't get in Sunday morning and my server was down in the afternoon (will except for about 12 PM-1 PM) So I couldn't really get to PriusChat site yesterday.
  15. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    Yep, it seems yesterday was a really bad day for the server. I couldn't get on all day long from multiple locations. Anyone know if its the amount of users browsing, users logged on or perhaps just a general server error?
    We all need our PC fix for the day!
  16. FloridaWen
    FloridaWen New Member
    573
    Plant City, Florida
    :huh: Hopefully the Server is being properly BACKED-UP at least once a day................
    In case of a hardware failure or some jerk "hacker" ...............
    Just curious (since I am a fully-qualified computer GEEK) B) are the Server's hard drives running in a RAID 5 (striped) configuration or at very least a "dual drive" RAID 1 (mirrored) configuration ??
  17. jiepsie
    jiepsie New Member
    267
    Sounds to me the error should read "PC members not busy enough" instead of "server too busy" ;-)
  18. Neicy
    Neicy Member
    834
    Wakefield, MA.
    I had that message most of yesterday, then this AM again. Most of the time when I get it retry doesn't help. Mostly it seems to happen when there is general peak bandwidth use to me. I think we need more bandwidth available on the server but I am not up on that stuff. I only know it makes for a long day when I don't get my priuschat fix.
  19. bulek
    bulek Junior Member
    44
    The server is obviously not properly tuned. Error messages about mysql_pconnect() attempts and too many connections show clearly that maximum connections allowed parameter is set too low.
    Another thing... mysql_pconnect() (persistent connect) works fine and is faster than mysql_connect() (temporary connect) for less loaded web sites. It seems PC is quite popular so rather mysql_connect() should be used instead - it closes the connection to the database as soon as web page is loaded. In case of mysql_pconnect() the connection remains active even after whole page is loaded and cannot be reused by other users.
    - Piotr
  20. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    At first I was thinking that PriusChat was getting Denial of Service attacked.
    If the server really were being overloaded by too many users online, then we would be setting new records. As it is, the front page of the forums still reads, "Most users ever online was 890 on Mar 19 2007, 12:10 AM"
